Case Mod - Complete Project: Assault Machine
Discussion in 'Project Logs' started by Hardbox, 11 Jul 2019.
  1. Hardbox
    Hardbox Member
    14 Sep 2017
    Quero muito agradecer aos patrocinadores pelo confiança e pelo apoio depositado em mim neste meu projeto para a Campus Party 2019.
    Muito obrigado COUGAR, Player ID, ASRock
    I want to thank the sponsors for their trust and support in my project for the 2019 Campus Party.
    Many thanks COUGAR, Player ID, ASRock
    My other casemod Projet Ghost Recon
    https://forums.bit-tech.net/index.php?threads/ghost-recon.339953/
    Project: Assault Machine Project
    Segue abaixo o hardware e periféricos usados no projeto
    • Cougar Panzer G https://goo.gl/PPNY2b
    • Fonte COUGAR CMX 1200 W https://goo.gl/Quz791
    • Teclado DEATHFIRE EX https://goo.gl/CzUtjA
    • Headset IMMERSA https://goo.gl/36a8aj
    • COUGAR Gaming Mouse Pad – Arena https://goo.gl/Kmrrxv
    • Bunker https://goo.gl/7itwTC
    • Placa mãe AsRock A320M-HD https://goo.gl/WRwz41
  2. Hardbox
    Hardbox Member
    14 Sep 2017
    I started the gatling construction project soon the design of the project in autocad.
    Iniciei o projeto da construção das gatling logo apos a elaboração do projeto no autocad.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Dot_Kappa and kim like this.
  3. Cheapskate
    13 May 2007
    Neat!
    Hardbox likes this.
  4. Hardbox
    Hardbox Member
    14 Sep 2017
    Thanks
  5. Hardbox
    Hardbox Member
    14 Sep 2017
    A litle update for in the project.
    Motherboard details.
    This was the part that gave me trouble, watercooler didn't fit, I needed to cut a little bigger
    Cheapskate likes this.
  6. Hardbox
    Hardbox Member
    14 Sep 2017
    And now the case.
    Cougar Panzer G, all glass sides, will be remove everything and make new.
  7. Hardbox
    Hardbox Member
    14 Sep 2017
    And de laser cut begins
  8. Hardbox
    Hardbox Member
    14 Sep 2017
    After the laser cut, I will do the assembly to see if the holes are really right
    it seems that everything really worked out according to the project
  9. Hardbox
    Hardbox Member
    14 Sep 2017
    Now it's time to start painting, the project theme is Assault Machine, so I thought about making a snow camouflage.
    First it was all painted black, with the pieces all assembled, then with some tree branches on the pieces, was given a light painting on top in white.
  10. Hardbox
    Hardbox Member
    14 Sep 2017
    24 hours later ...the painting had to be done with everything assembled so that the camouflage works because there are so many separate pieces so at the time of assembly everything has to be in harmony.
    Time to separate everything to assemble all the parts as it should be, already with the screws
  11. Kiyosen
    Kiyosen New Member
    17 Jul 2019
    Love it, great idea with using the leaves for a real pattern and leaving them at different distances to give it a more blurry look rather then pressing them on, looks absolutely fantastic
    Hardbox likes this.
  12. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Those laser cut pieces came out great! Can't wait to see the finished project.
    Hardbox likes this.
  13. Hardbox
    Hardbox Member
    14 Sep 2017
    Thank you @Kiyosen
    I also really liked the look
  14. Hardbox
    Hardbox Member
    14 Sep 2017
    Thank´s @500mph
  15. Hardbox
    Hardbox Member
    14 Sep 2017
    It´s time to create a VGA holder
    looks like it'll be fine.
  16. Cheapskate
    13 May 2007
    :lol: I see what you did there.
    Hardbox likes this.
  17. Hardbox
    Hardbox Member
    14 Sep 2017
    And now open a window to see the power supply :D
    a little bit of carbon to make it look beautiful
    And the final touch...
    [​IMG] [​IMG]
  18. Hardbox
    Hardbox Member
    14 Sep 2017
    it's time for the final project updates
    Backplate for VGA
    Another backplate
    now let's assemble everything
  19. Hardbox
    Hardbox Member
    14 Sep 2017
    This photo is already at the Brasil Campus Party event
  20. Yury
    Yury Member
    7 Mar 2019
    This one I know closely, fine work
    Hardbox likes this.
