Scratch Build – Complete Project ATAACS - A Tiny All Aluminum CNC Server
Discussion in 'Project Logs' started by dan297, 18 Feb 2021.
  1. dan297
    dan297 Modder
    28 Jan 2021
    So in order to fix this, I had to bend the panel to the other side.
    I quickly made a makeshift 1200N press for this task :eeek:
    Pretty f..king accurate tool :grin:
    But with hindsight, rather than following the first impulse to fix this, I should have done this after drilling the holes...
    With the main three sides done, I can mill it to the correct length.
    After this 1828 holes needed to be drilled...
  2. dan297
    dan297 Modder
    28 Jan 2021
    Next came the window panel. Basically the same process with the sides and the edges.
    And cutting the window this is actually the last aluminum milling operation - yeah :clap:
    Actually a shame. The bucket is half full :eeek::eeek::eeek:
    Cheapskate likes this.
  3. dan297
    dan297 Modder
    28 Jan 2021
    And here we are so far:
    Arboreal, Cheapskate and Karrek like this.
  4. dan297
    dan297 Modder
    28 Jan 2021
    What do you guys think:
    a. crystal clear plexi
    b. tinted plexi
    If b., which color?
  5. miculago
    miculago Minimodder
    25 Oct 2020
    This is unbelievable, great work!
    Canardwc and dan297 like this.
  6. Karrek
    Karrek Minimodder
    7 Jun 2011
    Can you make the plexi interchangeable? Have a clear panel and a red panel that can be swapped out depending on your mood that year?
    And fabulous work - I love it
  7. dan297
    dan297 Modder
    28 Jan 2021
    Thanks, mate.
    Currently I plan to just fix it with a transparent double sided tape. So changing is no issue.
    There is a 15mm wide frame on the inside of the panel around the window, which I milled down to 1.5mm.
    The plexi will have a corresponding frame around the actual window.
    This will be white after milling, so the tape will not be seen...actually it will not be seen anyway, because this is on the inside :rollingeyes:
    As for changing colors to adjust to mood...there will be an RGB strip under the fan bracket on that side :thumb:
    Canardwc likes this.
  8. Cheapskate
    13 May 2007
    Apply boot: Yes, they are very versatile. :lol: They work on people even.
    If you can get it, something like a 5mm+ thick edge-effect plexi would be awesome. Think of it sticking out on the side with a rounded edge, with maybe even a beveled groove around the border on the inside.
    dan297 likes this.
  9. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
  10. Arboreal
    21 Jan 2011
    An amazing scratch build in aluminium! :jawdrop:
    I am deeply impressed, my NCase M1 is looking on and feeling unworthy...
    Brilliant work @dan297, thanks for sharing it with us.
    You ought to show the guys on SFFN, they'd be impressed
  11. dan297
    dan297 Modder
    28 Jan 2021
    Thanks guys. Your feedback is excellent motivation :thumb:
    Don't. :nono: The NCase M1 is a very well looking case - with a proper surface finish. :lol:
    And the guys know too, how to drill plenty of holes :cooldude:
    Hmm, I think about this.
    Honestly, I find the SFFN a bit too colorful and kinda confusing for my taste...but maybe this is due to my advanced age :eyebrow:
    Arboreal likes this.
  12. kim
    kim hardware addict
    10 Jan 2016
    It is merely the cutest ITX case I ever saw.... :eeek: freaking awesome :jawdrop:
    I would opt for a transparent window but that's nothing but an hardware addict opinion :cooldude:
    ... and to deal the last blow :grin:, and this even if I admire the accuracy of the holes lining on the side panel :clap:, I would probably go for windowed panels on both sides :lol:
    Arboreal and dan297 like this.
  13. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
  14. Canardwc
    22 Sep 2011
  15. dan297
    dan297 Modder
    28 Jan 2021
    Thanks, Kim.
    Right side will face a wall, and with a closed window panel, I would have a concern with airflow and temps..although, as a CNC server it will effectively run 100% of its time in idle, so showing of that side could be an option :thumb:
    kim likes this.
  16. dan297
    dan297 Modder
    28 Jan 2021
    Alright. It is up and running :thumb:
    To begin with I had to strip the old PC. This is always a somewhat emotional thing...
    This was my very first attempt to watercooling and basically I had no clue what I was doing :eeek:
    I haven't looked for ages into the PC and I was actually really surprised what an amount of absolutely meaningless sensory I put in there :eeek::eeek::duh:
  17. dan297
    dan297 Modder
    28 Jan 2021
    CPU, RAM and M.2 SSD saved and installed.
    This is my second ITX build and I have to say I really start to like this form factor...
    For whatever reason why, I felt at the time the "need" to watercool the RAM, so now the old heat spreaders are gone...
    The EK ones are too high for the Alpenföhn, so I go just with the bare PCBs
  18. Canardwc
    22 Sep 2011
    Itx are the best and SLI doesn't exist animore. If you just need 1 pcie, Itx is the best !!!
  19. dan297
    dan297 Modder
    28 Jan 2021
    Some work in progress with the cable management.
    I gave the PCIe and MB 8-pin a custom length, to have as little cables to tuck away as possible.
    The stock 24-pin from the PSU was actually quite alright in length...
  20. dan297
    dan297 Modder
    28 Jan 2021
    Cable management: done :thumb:
    But to be fair, there is not much to managed anyway in this build. :happy:
