Scratch Build – Complete Project AXE-R 1st place CMWS2018
Discussion in 'Project Logs' started by neSSa, 10 Jan 2018.
  1. neSSa
    neSSa Active Member
    11 Aug 2014
    New parts of the aluminum elements are ready to be made :)
  2. neSSa
    neSSa Active Member
    11 Aug 2014
    From the EKWB we got new acrylic RGB tops for GPU blocks, bit thanks, and we have successfully engraved the project logo on them :)
  3. neSSa
    neSSa Active Member
    11 Aug 2014
    Acrylic front window fits perfectly :)
    _Prometheus_ likes this.
  4. neSSa
    neSSa Active Member
    11 Aug 2014
    The new EKWB acrylic RGB tops are mounted on a GPU, it looks great :)
  5. neSSa
    neSSa Active Member
    11 Aug 2014
  6. neSSa
    neSSa Active Member
    11 Aug 2014
    To continue :)
  7. neSSa
    neSSa Active Member
    11 Aug 2014
    Go to assemble :)
    hand-made brushed aluminum :)
    mounting radiators, reservoire and fans :)
  8. neSSa
    neSSa Active Member
    11 Aug 2014
    Assembling, day two :)
    Cheapskate and _Prometheus_ like this.
  9. _Prometheus_
    _Prometheus_ Active Member
    2 Jul 2017
    :rock::rock::rock::rock::rock:
    neSSa likes this.
  10. neSSa
    neSSa Active Member
    11 Aug 2014
    Day 3, RGB :)
  11. neSSa
    neSSa Active Member
    11 Aug 2014
    Day 4, 5 days left :)
  12. neSSa
    neSSa Active Member
    11 Aug 2014
    Day 5, 4 days left, me and my crew today finished tube in the backstage :)
  13. kim
    kim Active Member
    10 Jan 2016
    :clap: great work and greeeat pictures, you guys are having a real fun it seems :grin:, I can understand it, and the tower is absolutely amazing...:rock::rock::rock:
    neSSa likes this.
  14. ifohancroft
    ifohancroft New Member
    11 Jul 2018
    I am loving the project!
    How would you be powering the Arduino?
    Would you mind sharing your measurements for the PCI-E Shield Cutouts?
    neSSa likes this.
  15. neSSa
    neSSa Active Member
    11 Aug 2014
    Thanks, we're fine, but we're in a hurry about the end of the project :)
    Thanks, I'm glad you like it, ARDUINO I'm supplying with 5v moolex, as far as the design for the project is concerned, they are absolute ownership of the SS PC modding.
    ifohancroft likes this.
  16. Cheapskate
    13 May 2007
    neSSa and ifohancroft like this.
  17. neSSa
    neSSa Active Member
    11 Aug 2014
    3 days left, a lot of job is done, system work :)
  18. _Prometheus_
    2 Jul 2017
    Врло леп посао! Врло! :clap::clap::clap::clap::clap::clap:
    neSSa likes this.
  19. neSSa
    neSSa Active Member
    11 Aug 2014
    The project is finished and ready for photo shooting :D
  20. neSSa
    neSSa Active Member
    11 Aug 2014
    Project is finished! Enjoy :)
    CMWS2018: https://www.cmws.global/blog/axe-r-project-by-nessa
    Two years ago today, AXE-R was project was initially conceived as a drawing, and today, it was finalized into the state-of-the-art full-aluminium chassis, combining the latest technology and the stunning hexagonal design.
    AXE-R is divided into two sections - the cooling segment and the hardware section. The cooling segment is also divided in two loops, for CPU and GPU, which greatly enhances the performance efficiency of the components. This time, with the help from my brother Nemanja, and my friend Dušan, such a vast project was so much easier to take on, whilst providing handbrushed aluminium, as well as the nickel in the fittings, waterblocks, and much more to achieve the Premium look. The AXE-R case posesses an Arduino unit that measures the humidity and temperature, during which it's programmed to open the lid and circulate air throughout the chassis, should the overheating of the components occur. Therefore, we can say that AXE-R, regardless of the latest hardware that's implemented, is a true smart case.
    Hardware which I've used in this project is:
    Case: Custom AXE-R case by neSSa
    CPU: AMD Treadripper 1950x
    RAM: ADATA XPG 8x8Gb DDR4 RGB
    SSD: XPG SX8000 PCIe Gen3x4 M.2
    MB: Gigabyte AORUS X399 Gaming 7
    GPU: Gigabyte Vega 64 CF
    PSU: Cooler Master V1200 Platinum and CM 120 AP RGB fans
    Cooling: EKWB full custom dual-loop water cooling system
    Thank you all for support!
    BR neSSa :)
    ifohancroft and _Prometheus_ like this.
