well my last Project kinda stopped.... just didnt have the time..... i just got this lianli v2000 and now i want to get some modding done. her is the case. And after some photoshop'ing i came op with this. It will all be water cooled.... the setup is: Asus A8V Deluxe Amd64 3500+ Leadtek 6800gt 2*1GB Kingston HyperX 2* WD-Raptor 74GB RAID-0 Any feedback is welcome....
lol i thought that was real Tho i think its dis-proportionate to the rest of the case, i think it should start closer to the bottom making it taller overall nice photoshopping btw
wouldnt you be able to bring the window further down if you didnt stick the window on the inside of the case, but instead used rubber grommet to fit it perfectly to the case?
Yeah he probably could, but thats a lian li, it needs a clean window, rubber just looks like crap on such a nice case.
Not to mention, if it would be bigger, it wouldn't look as neat as it does now. The window would reach over the plates, dividing the case, and as such it would just look like hole in the case and not like well designed window. Besides, what's there to see but nest of wires? Maybe you could put something like horisontally mirrored BAGUD text below the window and put an tinted/smoke plexi behind it so that it would not disturb the clean look of the main window? That way you could still extend the cut without braking the view.
Image time here we go.... Cutting hole made i made the window a little smaller to better hide the drives. now i just need to clean up the edges.
Good job cutting, although I'd suggest you pull out the card support thingy unless you actually need it. Makes it feel kinda crowded in there imo.
been thinking of duing that... i think it looks i little flat on the side so just photoing a little again just with out the fan's.
