Project: BagUd v2000
Discussion in 'Project Logs' started by BagUd, 2 Aug 2005.
  1. Hal
    Hal What's a Dremel?
    1 Feb 2005
    really really nice cuts! love it. are you planning on painting? or colors?
  2. BagUd
    BagUd What's a Dremel?
    5 Jan 2004
    no plans for painting... next thing to happen is the grill by the window
  3. BagUd
    5 Jan 2004
    just got the watercooling parts.
    Hydor L30 V2
    DD RBX A64 Lucite
    Heatkiller NB
    DD 6800 Video Card Cooler
    Thermo.2bChill HE120
    AC Aquatube (silver)
    ill have my cammera back on friday i hope!
  4. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    Doesnt it seem like the motherboard is on the wrong side?
  5. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    just a thought, dosent the AC Aquatube have 1/8 fittings making it a bit restrictive? either way i am subscribing to this thread!
  6. Firehed
    15 Feb 2004
    Well they're G1/8, but you can get up to a 10mm (~3/8") barb stock with it. That said, without boring out two of the holes to 1/4NPT or G1/4, yes, it'll be restrictive in anything above 8mm or so.
  7. BagUd
    5 Jan 2004
    it's not the wrong side... :p it's BTX.... not ATX
    PSU in the bottom and the motherboard in the top.
    they just turned the cabinet around.
  8. c.u.later
    c.u.later What's a Dremel?
    16 Apr 2005
    its not extended atx, its btx form factor, eatx is just longer than normal boards.
  9. BagUd
    5 Jan 2004
    thanks for clarifying that for me... :)
  10. [<x>] Kiyusoma
    [<x>] Kiyusoma Deus Ex Machina
    16 Jun 2004
    its not btx either... just an atx board flipped upside down and mounted on the left side
    can't have btx without a btx mobo
  11. Bluefan
    Bluefan test 123
    25 Feb 2005
    yep, BTX is mirrored, this is just turned over. extended ATX is only deeper then ATX.
  12. Firehed
    15 Feb 2004
    It's not BTX, it's Extended ATX flipped over. BTX actually needs the PCI slots to be to the right side of the mobo (assuming you'd consider where they are now to be the left). And as was said, EATX is just longer (for the 12"x13" server mobos, not the 12"x9.6" or whatever a standard ATX board is)
    uBTX case and mobo.
  13. arkadur
    arkadur What's a Dremel?
    3 May 2005
    Nice skills and staff
    cant wait for the next update!
  14. leviathan18
    leviathan18 What's a Dremel?
    17 Mar 2005
    this is upside down position atx eatx case is BTX style the cpu down to catch the cold air etc
