Project BatCase **R.I.P.**
Discussion in 'Project Logs' started by Ediejo, 15 Aug 2005.
  1. G69T
    G69T CNC Modder
    6 Jun 2004
    Great metallic carpentry work! :rock:
    Gian
  2. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    Big cases, bigger cases and Ediejo cases! I think you have to sell your van and buy a truck to transport this one Ediejo :hehe: If I wouldn't know you were working on a computer I would say you were building a ship, seeing you do this metalwork. Great stuff again.
  3. Snakez
    Snakez What's a Dremel?
    23 Dec 2005
    Ediejo , why are you keeping some things back from the forum??
    Show them please , don't keep the guys waiting:)
    Love your work m8 :rock:
  4. Goth
    Goth What's a Dremel?
    17 Oct 2004
    i have the same videocards :D '
    nice pyramid :)
  5. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Small update. ;)
    Excuus for the bad photograph :blush:
    The rad's to come on the they side such as you in the setup could see. On the following photograph to see, how I hide them partly
    Thus it sees then if you look at of the they side. At the right-hand side I need the opening. In following update you will see why.
    The same for the other side.
    A bit further with the advancement of the body.
  6. Ediejo
    31 Jul 2005
    Small update.;) In these small update the last hand to the metal part of its body. Head and wings come in the following update.
    Here too improvise. Bit welds strip.
    And of course polish. Right the upper bit strip there.
    From another angle.
    To the tanks look at how I go further with its head and how high goes he becomes I rate 1.30 meter;)
  7. Ediejo
    31 Jul 2005
    Update 5
    This way said this way done further with its head. Or I must say its mouth; it belongs in any case to each other;)
    Bit round welds.
    Make it hot . })
    And it is really red-hot.
    Piece round to make the opening of its mouth.
    And again make it red-hot...
    Place it on his body.
    From another angle.
  8. Ediejo
    31 Jul 2005
    Update 6
    I was not in the position to upload new photos because removal my site to an other provider.
    Result no acces to my site and 75 euro fine. Even with the fine it is 250 euros cheaper in a year by MeHost than by BeHosted :p
    Time for a update.
    No iam not going to move on with his head, I remaining with his claw.
    I make the nails of iron round 16, using a barn bank.
    And there we go with the burner.
    After a couple considerable applaud with a hammer stands he nice in the direction.
    Then weld and the altitude of the nails is there.
    Thus on both sides weld a blade.
    The bottom nail.
    And then just as considerably sharpen, however, with an polishdisk.
    The form starts income there already.
    Put on the they side a blade to close the last opening. And 2 concludes rings to imitate claw the contour in them.
    In its whole.
  9. Snakez
    23 Dec 2005
    Nice claw man , great job :rock:
  10. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    WoW! The first i said when i saw the hw and the case! Its getting huge :eek:hmy:
    But great work man, looks very very promising! Kutgw!
    A question: Some people here is takling about an other great mod, would it be able for you to give a link to the log if you have one? Or maybe som pics or something? :)
    Thanx
    Dj Ovin
  11. Snakez
    23 Dec 2005
    Look at the project log Extreme Lian li.
    Thats his other project:)
  12. customh
    customh conflagration.
    22 Oct 2005
    dude, your are insane to be able to make something like that a reality. Best of luck and hope to see another sweet mod. What color and any windows (like in the eyes)?
  13. Dj Ovin
    7 Nov 2005
    Thanx man :)
  14. Ediejo
    31 Jul 2005
    Update 7
    In these update the first bit of its head. There are some strange forms in its head but. That part from his eyes seen quite round on the poster. What ends up then quite? A small range ball.
    Those I have cut along the seams.
    Than some time to shape it.
    That starts seem quite.
    Still one not this way dark.
    Whole weld each other.
    In the following update building in the tanks
  15. Ediejo
    31 Jul 2005
    Update 8
    Now the breaches sign where the tanks come, which also are his eyes.
    After what sharpens work the opening for the tanks sits.
    Except a moderate quality of the photograph, some are also more vaporous. Sorry
    What must i think of this? Mhhhhh
    Just to look how it corresponds to the image on the poster. Large well only the position is not good.
    The score of the tanks is not well. A bit from its mouth sharpen does wonders.
    Just looking or it is appropriate.
    The tanks are appropriate still and the position is from the tanks is now better.
    With iron of around 8 I bend its contour of its cheek.
    Only weld
    Seen it from the back. That bar iron sits there only for the support. Is is temporary.
    The first bit cheek. Now you see also where that ring serves for.
    On its cheeks sit also still what bulges. Also that are made of perforated steel plate.
    Seen from the back. Bit of the tank is still visible.
    Also that has is closed.
    To be eyes (tanks) sit there for me as an orientation point. From there I work further. That piece perforated plate what is on the ring, it is the beginning for the second bulge which a piece is larger.
    I leave forgot that simply in the cupboard a tool is to bend iron. :wallbash:
    To be ears.
    Now I know also the height of the bat 119.7 cm without wings.
    And do you get now already an idea concerning large of this Batcase? In the following update we will see more.
  16. JamesM
    JamesM What's a Dremel?
    8 May 2005
    Looks more like a duck at this stage :D
  17. antoniohawk
    antoniohawk What's a Dremel?
    21 Oct 2004
    It looks like Darth Vader ate a duck lol. Lookin' pretty sweet though.
  18. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    I'll always applaud someone willing to give something different a try. To be honest it was looking a little questionable at the beginning but that's to be expected with all computer mods.
    Your fabrication skills are pretty good by the look of it. Those claws are no mean feat. Keep it up. I'd like to see how this one ends.
  19. Ediejo
    31 Jul 2005
    Update 9
    There are of those days. That you have a good camera. ;)
    In these update completing its head. At least the iron work there of. The beginning of its cheek.
    Beginning of connection head on body.
    On the other hand a piece for its cheek. And the contour made on its mouth.
    Then the back I have of it absolutely no example, then what improvises.
    This is it on its tooth after, that to see you in next update.
    The other side of its head.
    The back.
    And a close upie. ;)
    One Claw still to make and iron confirm for its wings. Then we go direction polyester. ;P
  20. Ediejo
    31 Jul 2005
    Update 10
    The advancement of its head is well almost ready, bit ear still to do. Time to start with the wings. It saw the tube.
    The first bit sits.
    Iron tube to weld
    Then I make them a bit longer. Saws under an angle, weld and polish.
    Maybe this is something for the people from American Choppers. :+
    Still a bit perforated plate under its wings.
    For the rest of the wings I must have thinner tube. Therefore I must go to the iron farmer. Then the nails for the next claw sharpen. Still 8 to go.
