Scratch Build – In Progress Project: Beyond The Grave [It Has Been Done!] [18th June 2007]
Discussion in 'Project Logs' started by Edvuld, 19 Nov 2006.
  1. atanum141
    22 Jul 2004
    Yep...totally pimp
    Brandon Heat F T W!!!!!!
  2. Fozzy
    Fozzy New Member
    25 Jan 2005
    nice. too bad on the watercooling
  3. Edvuld
    Edvuld New Member
    2 Aug 2005
    I don't get it why some ppl think it's a bad thing to not watercool your project.
    Ok, it gives some performance boost that you may want when overclocking.
    It looks cool.
    That's it.
    That's not reason enough to go through the trouble for me.
    Watercooling weights a lot more than aircooling.
    It sucks to clean it
    It sucks to be somewhat worried that it might leak over all your TB of HDDs
    It's way more complicated to change your MB, graphic card or CPU
    It's not even that much quiter than Zalmans line of Fan-cooled solutions
    This rig won't be overclocked to the max. I want my data safe, not corrupted.
  4. AJB2K3
    AJB2K3 New Member
    12 Dec 2005
    Im getting my rig water cooled by a shop because its much quiter then fans.
  5. Edvuld
    Edvuld New Member
    2 Aug 2005
    Update #04 [Corners] [2007-01-14]
    Welcome back =D
    Last time I forgot to bring the camera, so no updates then :(
    I continued to make the corners that the acrylic will be fastened to. This is a very time consuming job, and makes me realize why I work in aluminium instead. 21mm iron is a biach, and filing through 11mm isn't that fun either :/
    Threading. A broken screw tap would be devastating at this stage, so I took it real slow and careful. Good threading paste is a great way to assure that the screw tap doesn't snap.
    Got myself some nice black bolts that should fit the project nicely.
    I drilled right through the iron so it would be easier to thread afterwards, some welding tidies it up a bit.
    Completed. Took me a good 10hrs :eyebrow:
    Finally I can start to try out the acrylic to see if I managed to get everything straigt. Well, I didn't exactly, but some small adjustments solved most of it.
    Someone made a mistake somewhere :duh: , so the support for the HD-cage was very tense, which isn't good. I could either make an entierely new part for the support, or solve the problem some other way. I chose the latter.
    The way I see it a fixed problem is a non-problem, making the problem disappear, so basically noone messed up. :clap:
  6. exo²
    exo² New Member
    22 Dec 2006
    nice mangreat work i love it
    do you have a working office in your house?
    keep going
  7. Edvuld
    Edvuld New Member
    2 Aug 2005
    Thanks man!
    I'm using my uncle's workshop. He's got pretty much all the tools for metalworking I need, and the place is huuuge, I'll post a pic next time =D
  8. Ryderman
    Ryderman New Member
    4 Jan 2007
    it looks really nice. keep up the good work!
  9. SnOof ^^
    SnOof ^^ New Member
    7 Dec 2005
    nice duude ;D, keep up the good work ^^
  10. SlappKnutts
    SlappKnutts New Member
    28 Jan 2007
    Great work so far! I loved NOD so I'm gonna keep a close eye on this one!
  11. Edvuld
    Edvuld New Member
    2 Aug 2005
    Update #05 [Disassembly 01] [2007-03-10]
    Well, Hi.
    I've been busy with other stuff, so I haven't really found the time to work with this project over the past months, and the work I've done doesn't make that big of an difference visually, so here's a small combined update.
    THe last things I've done is to make small adjustments to all the internal parts, so that the acrylic should fit well. I also started on a part of aluminium that will be positioned under the top acrylic, to provied more stability to the case, as I felt this was needed.
    At the moment I'm taking everything apart to clean it and spray it with a protective layer, to prevent dust and fingerprints to stay on the aluminium.
    After this has been done, I will put everything together again one final time, and then start working on the acrylic, and the front.
    Here's some pics of the top plate under construction: (not finished yet)
    Here's some pics of my uncle's workshop as well, it's perfect :dremel:
    Still not much, I hope I'll get it together and make some progress soon :/
  12. Supra55
    Supra55 New Member
    10 Oct 2006
    Its good to see this project back up and running again. I was worried you might have left it to die.
  13. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    wow i am your new best friend if only you lived near me i would break into that workshop every night! looks like a great place to do a mod!
    gald to see you back aswell! your mod looks to be going well so keep it up!
  14. TapperSwe
    TapperSwe New Member
    20 Nov 2006
    Looking good ,keep it up
  15. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    That workshop's insane, dude! :O
  16. itsjustacompaq
    itsjustacompaq Member
    7 Sep 2006
    it is really cool, but i wouldnt put it at the level of deity! :D
    j/k dude.
    this realy is looking great, those corner blocks are works of art.
  17. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    That my friend is the single greatest picture i have seen whilst modding and following modding
    i myself have been looking into a datastore (for media/backups/document sharing) and was initially going to go Matx but that picture has opened up loads of possibilities
    whislt its not shiny curvy or anything completely elaborate its a very functional way of incorporating a fast disk swapping method into a non factory made server case.
    i cant wait to see how you model the front of the case to maybe incorporate the fast switch interface.
  18. TapperSwe
    20 Nov 2006
    lol i sometimes forget that there is 2 oo in good ,it has been corected .
    Amen.
  19. Edvuld
    Edvuld New Member
    2 Aug 2005
    Update #06 [Disassembly 02] [2007-03-31]
    I took some time yesterday. I'm done with the disassembly of the internal parts of the chassis, and also remade the top plate.
    I've disasembled all the internal parts for cleaning and clearcoating, to give the parts a better finish and to protect from fingerprints. This is the last chance to make any adjustments to the parts, if I do it after the painting, it'll look like ****, so I took my sweet time fixing the finish of all parts.
    Here's some of them before cleaning:
    Last time when I worked on the top plate, I wonder what I was smoking. It must have been some good **** for me to make it like that, because it looks like ****. Vastly different thickness of the curves doesn't help achieve good looks, so I decided to tidy it up...
    Before:
    After:
    So now I'm happy with that part...
    Next time I'll start on the front acrylic hopefully.
  20. Edvuld
    Edvuld New Member
    2 Aug 2005
    Update #07 [Assembly & Acrylic] [2007-04-07]
    So I'm done with all the cleaning and spraypainting, so I spent a few hours putting everything together again - finally for the last time.
    ^ Rubber feet are always nice :clap:
    Now that everything is put together, I can finally start with the acrylic. I measured at least twice, and drilled once. =D
    The washers won't be there when I'm done, so pay no attention to them not beeing perfectly aligned. (They're M5, I used M4 screws.)
    Will cut the front open next time...
