Scratch Build – In Progress Project: Beyond The Grave [It Has Been Done!] [18th June 2007]
Discussion in 'Project Logs' started by Edvuld, 19 Nov 2006.
  1. ZenX
    ZenX How are you gentlemen?
    5 Aug 2005
    Excellent work, excellent project and excellent anime. Keep it up 'til the end.
  2. Guest-23315
    Guest-23315 Guest
    You know you're cool when you cut bits off an HDD.
  3. jegerjon
    jegerjon New Member
    10 Jan 2007
    wow! this mod is really good looking! Keep going dude.
  4. yakyb
    yakyb i hate the person above me
    10 Oct 2006
    hmm using the pcb of a HDD as a fan controller that might just work hmm i have an idea!!!!
  5. Edvuld
    Edvuld New Member
    2 Aug 2005
    Update #16 [Final Touch Before...] [2007-06-14]
    Sorry for not updating last sunday, but everything took more time than anticipated. As usual...
    For starters I've engraved the left side. First is how it's supposed to look like.
    I don't like engraving directly from the image, due to the small difference in height, so I prefer to paint the motiv on the acrylic, so I don't have to deal with that when I'm working live.
    I also got myself the text pre-cut to get the maximum possible precision, even though Wolverine will probably frown upon me ;)
    The outlines done:
    And a small sneak-peak (kinda crappy pic though).
    Front assemblied, and the fans attached =D
    I've finished up the right side as well:
    Some engraving in the circle:
    A few parts for that extra touch...
    Here's what's supposed to be the backlight for the motherboard. I hope it looks cool...
    And some small parts here as well:
    Over to the fan control that I was going on about before. It turned out great :clap:
    I added some lights, and I also somewhat polished the plate underneath, that you can see through the circular hole in the bottom. The cables and lights will get mirrored a bit there =D
    I engraved a small GG logo on it as well :dremel:
    I put the front I/O thingie together, I just hope it'll be working as intended when I power it up... :sigh:
    Over to the front, which I connected to the LEDs and buttons.
    Looking good...
    ...I thought, until I tried on the acrylic front on. Seems I made another stupid misstake. You see the small hole in the upper right corner? Most annoying. I guess that's what happens when you change someting without analyzing all the possible effects from doing so.
    While it might not be very notable, It'll annoy the crap out of me forever, so I made another front.
    This is what I've got at my disposal for lighting the case up.
    In the end I only needed 1 LazerLED, 4 small LED Aqua tubes, and 1 longer lava light tube.
    The back looked a bit empty, and certainly not red enough for my taste. This little acrylic piece should solve that. :D
    Oh, and here's my scratch-made power cables for all the HDDs! Pretty neat huh?
    Right now I'm unpatiently waiting for the silicone holding the lights to cure, so I can connect some cables and put all the hardware in. If nothing goes terribly wrong, the final pics will be upp on saturday evening.
    Cya around then.
  6. gvblake22
    gvblake22 mmm, yep
    7 Dec 2005
    Looking VERY good so far! Everything is very well planned and laid out and your cables look perfect. Great work man, can't wait to see some pictures of the whole thing!!! :rock:
  7. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    awesome!!!!! keep it up!:thumb:
  8. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    Your attention to detail is amazing. The wiring inside the hdd is a fine example.
    Looking forward to seeing more of this project!
  9. Clocked
    Clocked Yar! It be drivin' me nuts...
    11 May 2004
  10. Cheapskate
    13 May 2007
    hd fan controller? BRILLIANT!
    I can't belive how steady your etching is. I would have little tangent lines going everywhere if I tried this...
  11. dacust
    dacust What's a Dremel?
    10 Mar 2007
    This just gets better and better! Really REALLY awesome work.
  12. Infenro
    Infenro New Member
    7 Oct 2005
    This is amazing mod good luck on completing it.
  13. ComputerKing
    8 Sep 2006
    WOW the front look dam good and kickass.. hell :D love it too much
  14. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Bra jobbat :D !!
    You have very good metal and plexi working skills !!!
    You have my respect .
  15. Edvuld
    Edvuld New Member
    2 Aug 2005
    Glad you gys like it :rock:
    I'm currently installing all the HDDs, and trying to get those cables set up in an orderly fashion :/
    It seems everything is working, even the front I/O I was scared to plug in ;)
    I'll come around for some pics tonight.
    I absolutely love my remote =D
  16. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Simply Amazing...
    The electrical work is phenomenal!!! Well done. :rock:
  17. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Very nice indeed.
  18. wbdog206
    wbdog206 not me
    15 Jan 2007
    wow just wow :jawdrop:
    that is incredible work.
  19. Pfaffen
    Pfaffen New Member
    18 Mar 2007
    Great idea to use an old HD for the power switches... Simply brilliant.
  20. Edvuld
    Edvuld New Member
    2 Aug 2005
    Update #17 [It Has Been Done!] [2007-06-18]
    All done! Sorry yet again for the delays, I had a **** weekend. Skip next part if you're not interested ;)
    :grr: (1 HDD with all music and installs for programs decided to go AWOL on me which set me back about 15hrs restoring everything, and when all was installed and done for the photoshoot, my Diamondback decided to go die on me as I plugged it back afterwards >< )
    Anyways, back on topic!
    Sorry for the quality of some of the pics. I took about 90 of them, but still I didn't get enough good pics. Either the camera doesn't like red lights in the dark, or I need to get a tripod.
    Let's start with some pics with the sides and front removed:
    A pretty good shot of the engraving:
    All sides on:
    Here's some pics in the dark as well:
    And finally a few with extra long exposure:
    For those interested, here's some stats/info:
    Build time: ~250hrs +planning
    Cash spent: I didn't keep track ;)
    Weight: 20Kg with current system. Max weight fully fitted with 11HDDs will be 22Kg.
    Noise Level: I measured 38db 30cm from the case, with an ambience of ~30db.
    Cooling: 4xPapst 120mm@5V, 2xPapst120mm@7V, Zalman VF900, SLK947U with Papst92mm@8V
    Hardware: I know it's old stuff, but for what it's supposed to do, it works well.
    Mainboard: Abit AN7
    Sound: Soundstorm DDLive!
    CPU: AthlonXP2500+ @2,2Ghz
    RAM: Corsair TWINX1024-3200XL
    PSU: Antec NeoHE 430W Modular
    GFX: Sapphire Radeon1600PRO HDMI
    Cards: Promise Ultra100TX2, SATA300TX4
    DVD: NEC AD-7173A Labelflash IDE
    Extra features: 4xHDD activity LEDs, Shiny surfaces I'll spend more time cleaning than using the computer.
    HDDS:
    2x500GB Maxtor DMax11 16MB SATA2
    1x250GB Maxtor DMax10 16MB SATA
    2x200GB Maxtor DMax10 8MB SATA
    1x250GB Maxtor DMax9+ 8MB IDE
    2x200GB WDigital Caviar SE 8MB IDE
    ~2,3TB
    (I have a few others lying around as well)
    For comparision, my old watercooled Chieftec fulltower weights 30Kg with everthing fitted, and its noise level was measured to 50db. This makes the projects 3 primary goals completed; Less weight, less sound and more HDDs.
    This case is actually the most quiet case of all I've made so far :rock:
    Chieftec Fulltower > Temple Of NOD > mATX gaming system > Beyond The Grave
    Thanks go out to everyone that has supported me and helped me. This includes but is not limited to:
    Everyone at Tidaholmsvagnar
    The guys over at Åbergs Plåt
    You guys here at bit-tech.net
    Now, I rest :hip:
