Project: BGAIOC 2T Monster : 19th MAY Log :"SCRAP TIME"
Discussion in 'Project Logs' started by CrazyModder, 14 Jun 2006.
  1. A3D
    A3D What's a Dremel?
    14 Oct 2005
    Wow looks great so far man, Keep up the good work. Nice job dude.
  2. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    dang that is one hell of a sight...the green uv plexi on the smoked...*drool*
    very nicely done!
  3. OldY
    OldY What's a Dremel?
    10 Mar 2006
    Great work!! Keep it up :thumb:
  4. Journeyer
    Journeyer Minimodder
    31 Aug 2006
    Sweet work on the PSU-rack :D I did something similar myself once, though only with two PSUs. Have a question though; why did you keep them on separate switches? Though then again - I can see the attraction in having to turn them all on in sequence :D
    Nice work so far.
  5. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    The PSU rack looks awesome especially with the metallic handles on the sides, keep it up...
    And Im glad to here that the hurricane missed you, and didn't wreck that masterpiece...
  6. CrazyModder
    CrazyModder What's a Dremel?
    13 Jun 2006
    TK for your comments guys
    Those are not switches to turn on the power supplies, those are to turn off the PSU when you want to install a PCI card or other stuff with out having to unplug the PSU or can be use as a reset switch after a short or power outage. Some power supplies come with those and that is why I choose them. I didn't like the idea, to reach behind the case so I move them to the front. They give me the option of chossing what PSU will be on, when I don't need all of them on, at the same time. All the PSUs will turn on when I press one single power buttom, but they can be switch off independly. I'm in the processes of wiring them, also the power rack is not going to be a junction box.
    See you guys at the next post......CrazyModder ....out
  7. Journeyer
    31 Aug 2006
    Of course :duh: should've thought about that. :blush:
  8. rbxgt2
    rbxgt2 What's a Dremel?
    2 Sep 2006
    i think i'm gonna explode.
    the best rack yet next to a blond bimbo :rock: :clap: :rock:
  9. CrazyModder
    13 Jun 2006
    I'm back with some wiring managment, this is how the PSUs look inside the power rack with the stock PSU wiring.
    this picture is after adding the PSUs intake fans to the rear lid, lots of wires
    then I, extended the ATX plug wiring by 4 ft.
    took the extended cable and solder, the connections to the main PSU board
    I also extended the main leads for HDs, fans, etc by 4 ft. Now the interior of the PSUs bays look more organized.
    put back the lid and no wires from the PSUs are visible now
    the second lid has been put on, this one has the case intake fans
    two shots, with both covers on and showing the power leads cables
    notice the green led light on, at the side of the bottom switch, main PSU on
    Remember the darn thing, goes upside down inside the case and it not finish yet. I took me a couple of days of running wires and soldering and lots of cutting, in total I used more than 250 feet of wire. While doing the wiring it just occur to me to do the sleeving of the cables that way and I like it a lot. I might do the whole case wiring that way, that will change the plans I had, at the begining of this log, will see what happens. Those power leads are going to a junction box, that I haven't decided on the design yet.
  10. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    It's alive. Yikes lots of wire. Cool colors...and nice execution. Did yo ucrimp solder or screw clamp stirp them?
  11. huren
    huren What's a Dremel?
    14 Aug 2004
    When i first saw the last post, i thought i was watching a " Beatle Juice " cartoon.
    Looking good mate.
  12. CrazyModder
    13 Jun 2006
    Thanks for you comments guys..
    The ATX plug was uncrimp and the wires were solder directly to the pins. All other conections are solder and cover with heatshrink tubing, the molex plugs are also solder but with new molex pins and housings. I changed the wiring to a heavier gauge 20 to 16 , because of the longer runs and for safety.
  13. CrazyModder
    13 Jun 2006
    This are the plates that gonna act as grommets for the cables and cover the extra holes of the power rack.
    some of the green stuff
    green cover plates ready
    power rack goes here at the top of the case
    power rack is in place
    some bottom pictures showing the cables in position
    now some pictures with the cover plates in place
    added the cover for the PSUs
    then added the cover for the case top intake ports
    final shot everything in place
    There still room for routing cables across the case thru the power rack. The power leads cables are extra long, I still don't know how or where they are gonna plug into; they can be shorthen later if need it. I'm still trying to figure out the shape of the junction box, maybe one day I just start building it and see what it comes out of my head. I like how the power rack came out, never imagine it will look that way.
    P.S. I like the Black color, but I haven't been able to keep it dust free or without fingerprint marks, the case is in my rear porch ( modding zone ), is a nightmare.
  14. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    Christ, that is a monster :jawdrop:
    ueber wicked!
  15. CrazyModder
    13 Jun 2006
    I need to power the rear exhaust fans for the HDs and the Rads, so I came out with this little things to hold the jacks for the power plug.
    two screws will secure it to the case and the jack goes in the middle.
    it gets screw to the side of the fans airbox
    how the plug goes into it
    a shot from inside the case, plexi is clear, green LEDs behind will iluminate the green plexi
    Now I start building some plexi gromets for where the power leads enter the case
    they are made in two pieces, to make easy to install around the cables
    after some final shaping, I decided to paint them black
    now they are in place, left side for main PSU only
    right side for the other two auxiliary PSUs
    This will have to do for now, untyl I come out with a better idea...
    I still debating how to make the junction box, the problem is, that I had too many ideas and can't decide which one to choose.
  16. z4114
    z4114 FACE!
    25 Jun 2002
    Holy freaking hell CrazyModder! I remember reading this log when it was just the post that had the Hulk holding a cable. I thought that this mod was just going to be a standard job with a bunch of hard drives. My god how you have proved me wrong!
    I love your balls-to-the-wall mod first and then make measurements later approach. Your case is looking phenominal.
    Sir, I do believe you are crazy to be making a case like this... crazy-awesome! :rock:
  17. Laku84
    Laku84 What's a Dremel?
    6 Aug 2006
    wow! great job man.. looking forward to see the finished project :)
    Wish I also had 2.5 TB of HDD space :)
  18. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    I know you are going with aircooling, but, damn Some green watercooling, would look sweet.... :rock:
  19. CrazyModder
    13 Jun 2006
    Thanks for or your comments guys! :D
    My daughter told me something better, they look like snakes, great :wallbash: I hate snakes, shes just five years old.
    No enought, by the time is finished, I will need to double that storage capacity :waah: , this time the new case will be planned. Maybe a server with 24 or 36 or 48 hds :naughty: " HAL 9000 - XXT server "
    I'm going with water cooling, green of course, keep watching.
    Now you hit the nail in the head, you fully understand what I'm doing here. Can we call it free modding, no plan, no rules, just modding for fun. They only bad thing about it, is that the case has gone in a different direction of what I wanted to do in the first place. Also, with no plan I forgot to do some mods that I wanted and the building progress is very slow. I still have no idea what to do next :confused: tomorrow.
    Well thanks you guys for your support, see you at the next post...
    Disclaimer:
    Please don't try this at home, side effects are: headaches, nausea, imnsonia, a modding itch and an empty pocket.
  20. Mr_SCSI
    Mr_SCSI What's a Dremel?
    13 Apr 2004
    Holy mother of... :eeek:
    Now thats a monster in the making! :hip:
    Log makes great reading... looks fantastic, makes my full tower project look like a midiT!
    Look forward to the next update. :thumb:
