Project: Big Brother, Phase2
Discussion in 'Project Logs' started by BoCoMoFo, 31 Dec 2003.
  1. BoCoMoFo
    BoCoMoFo What's a Dremel?
    30 Sep 2002
    Just as promised, here's the beginning of my new case project. This time around, I'm skipping the typical metal PC case and using this new end table instead. Here's a few pics before I get started on my PC's new home:
    The huuuge inside! :eeek:
    Here's a comparison between the new case and my Lian-Li PC-75, which I previously thought was big. :p
    More to come really soon!
  2. t.n.
    t.n. What's a Dremel?
    26 Dec 2003
    damn thats huge!!
  3. Xiliqueirn
    Xiliqueirn What's a Dremel?
    23 Dec 2003
    Wow...I must say that is quite nice. Going for a 'stealth' look?
    Lots of possibility in that...should definitely give you enough room to mound everything...and maybe some new stuff? =)
  4. BoCoMoFo
    30 Sep 2002
    The 'stealth' look is exactly what I'm going for. I keep my computer in my living room and a huge PC case doesn't exactly look good in here. Also, I've been needing a new end table for the side of my couch, so that's how the idea for this happened.
    When designing it I'm going to make sure I have room for more than one PC in there should I ever want to add another one. :dremel:
  5. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
    In the living room huh? you gonna have a monitor with it.. or are you going for TV-out?
  6. BoCoMoFo
    30 Sep 2002
    I have a 19" NEC FE990 sitting on my coffee table with a wireless Logitech MX Duo mouse/keyboard.
  7. Xiliqueirn
    23 Dec 2003
    Nice...you could even mod an old CD drive to be a cupholder? Eh? Eh? :hehe:
  8. KONIJN
    KONIJN What's a Dremel?
    30 Nov 2003
    going to watch this mods
    nice idea's
  9. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    Isnt it going to look a bit weird with case fans in the table? :worried:
  10. Xiliqueirn
    23 Dec 2003
    I was thinking the same thing...it would be really neat if you put all the fans on the bottom of the case, so it would be really stealthy.
  11. NexteR
    NexteR What's a Dremel?
    6 Nov 2003
    o ye? havent seen somthing for a long time now...
    More to come really soon! [/B][/QUOTE]
  12. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    as for the fans for the case... you could possibly use a set at the bottom to pressurize the box and then use some pvc risers to draw from the top inside to take the hot rising air and guct it back down to the bottom...
    Just use some sort of deflecter to control the hot air blast.
    also, later on, you could also hinge the top cover and hide a lcd under that.. and use a panel insert to seperate that from the pc compartment. also it could double as a secondary table while the screen was up...
