Scratch Build – In Progress Project: Big E (March 2: Side panel about |---this---| much done)
Discussion in 'Project Logs' started by llamafur, 8 Jan 2010.
  1. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    I'd prefer cutting a chunk of copper to buying a overpriced water block any day. What you saw up there was nothing compared to this...
    I swear, this is smooth as glass.
    Don't worry, these will be lapped.
    I wonder what will be next?
    We finally got the lathe up and running.
  2. stonedsurd
    11 Mar 2009
    You can't leave us hanging like that!
  3. llamafur
    27 Jul 2009
    Don't worry, it goes on the front of the computer. I'll have updates tomorrow.
  4. llamafur
    27 Jul 2009
    This is the power button. The design I'm shooting at is one of the vandal resistant switches. I worked for two periods then had to go to art. I will post some more after school.
  5. llamafur
    27 Jul 2009
    Where should I put the button? I was thinking of placing it on the orange strip towards the bottom.
  6. skunkmunkey
    skunkmunkey Minimodder
    15 Jul 2007
    Loving the custom block, been toying with the idea myself.
    Just a word of warning, my good friend Ryan slipped whilst doing some hot glue work, the glue burnt his pupil area and his pupil now looks like a 3 piece pie chart. Didnt blind him but watching him trying to get his keys in the car is painful.
  7. llamafur
    27 Jul 2009
    Sorry about your friend, that's a weak accident to be in. As for the water block, if you have the right tools or access to them (mill, drill press...) I say do it. The walls on my block are at least 3mm thick. So l know this thing can hold some serious pressure.
  8. skunkmunkey
    15 Jul 2007
    Im glad I read your log because it got me looking for local CNC companies, turns out there is one directly opposite the Unit where I work... guess the name should have given it away, Acutech engineering lol
  9. clocker
    clocker Shovel Ready
    21 Dec 2003
    Your wall thickness is totally irrelevant because:
    A) Your loop isn't really under that much pressure and
    B) If it's going to leak, it'll be at the joints or fittings, not bursting through solid metal.
  10. llamafur
    27 Jul 2009
    The making of the GPU block.
    5 minutes later.
    And finally this is how it will mount. More to come tomorrow.
  11. llamafur
    27 Jul 2009
    First coat of polyurathane.
  12. DeadP1xels
    30 Nov 2009
    Looking sweet! :thumb:
    i wish i could use the mills and lathes for stuff outside of college :(
    they have 2 manual mills 2 cnc 1 cnc router and 5 lathes
    and alot more you think they would let me use them for hobby purposes :p
    Loving how this is turning out
  13. llamafur
    27 Jul 2009
    Thank you very much.
    Well, today I added the light ring around the switch, I canabalised the leds from some old pci networking cards. I couldn't power them up while taking a picture, but they do work.
    I etched my own circuit board with copper(II) chloride.
  14. llamafur
    27 Jul 2009
    Ok, I've got a gpu block update. The mounting plate if from the extra hardware that came with my swiftech water block in my gaming rig.
    I still have to figure out some mounting hardware for the cpu block.
  15. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    Damn , those blocks look nice , could have a better finish on them.. continue with this !
  16. llamafur
    27 Jul 2009
    Thanks Raiden, I will be finishing the GPU block. I can't believe how fast this build has been going. I still need to get a hold of some ram and a larger hard drive.
    Got the power button mounted. Its like the epicenter of the whole build.:lol:
  17. llamafur
    27 Jul 2009
    The CPU block is now mounted! The computer is going to weigh so much especially when the water is added.
    I used mounting hardware from an old p4 air cooler I got several years ago.
    Here it is all tightened down with arctic silver ceramique
    And finally I am done with the bulk of the water cooling.
  18. llamafur
    27 Jul 2009
    Little update here.
    I made some "sleeving" out of some multimode fiber optic cable. I got the cable when I was shadowing (career day) at a data center. The fiber was laying in the trash, so I asked and received.:thumb:
    See that yellow fuzz, that's Kevlar. Its used to keep the cable from stretching.
    Here's a better angle to show you the size of the fiber. The glass thread is around .1 mm and it's actually hollow.
    First step is to chunk off the crimp on connectors.
    Now I get to fish the wires through the orange tubes.
    All soldered up.
    First wire inserted. Same with the second.
    And finally heat shrinked.
    Final results. I am pleased with the results.
  19. llamafur
    27 Jul 2009
    No comments?
  20. Boxcarr
    Boxcarr Will use any tool available.
    3 Dec 2009
    comment
