Project: Binary *56K* BEWARE!
Discussion in 'Project Logs' started by GFORCE, 18 Oct 2003.
  1. GFORCE
    GFORCE What's a Dremel?
    18 Oct 2003
    Hey.
    Well this Modification First Started as a DVD Player PC, But it turned out that the Chassis I was Originally going to use was way too small to fit a ATX Mobo. Since this was goin to be made out of old Components or Free Components that I could get my Hands On.
    This is what has happened so far in the Modification.
    That is a Picture of a Section of the Intial Casing. That is the Bottom with the Sides and bottom all in one peice.
    Just Another Shot of the section of Casing
    Another Shot with my Nokia 6100 As a Scale Comparison
    The Unit will be (WxDxH) 443mm x 438mm x 185mm
    So the Unit is pretty HuGE!
    The Specifications of this Unit are:
    Intel Pentium !!! 733Mhz
    Gigabyte (Unknown Mobo)
    256MB PC133 Ram
    30Gb Western Digital Hard drive
    Pioneer DVD-120S Slot DVD Drive
    Aopen 250W Powersupply
    Matrox Millenium G400 Dualhead Videocard
    Winfast TV2000XP Deluxe TV Tuner
    Advance ALS4000 Sound Card
    Cooling will be taken care of:
    1x Papst 12V 120MM Fan
    1x Sunon 12V 120MM Fan
    1x YS-Tech 60MM Fan off Thermosonic Thermoengine
    Thermal Take Volcano 7 Heatsink with Above Fan
  2. taliban_raider
    taliban_raider Just some guy; you know
    28 Feb 2003
    What is that material?
    Edit: Welcome good to see more Ausies on the board!
  3. GFORCE
    18 Oct 2003
    That is Perspex that was Sourced off a Faulty Harmon Kardon amp from my Dads Shop.
  4. fump
    fump What's a Dremel?
    14 Aug 2003
    its gona look sweet when its finished, make sure u post plenty of pics of the finished article. i was thinkin of doing somthing simular to a CD ROM so i can see the insides workin through the top window of my case.
    yay 75 posts!!
  5. GFORCE
    18 Oct 2003
    Well I dont think its right to call it a DVD PLayer PC anymore since the fact that there isnothing being used off a DVD Player.
    Sure the Unit has a DV DRom but do you call you PC a DVD Player PC?
    I really need to get a Soundcard that Supports DTS, Dolby 5.1, Dolby ES and THX
  6. GFORCE
    18 Oct 2003
    Well here is another Update. It is just some 3D Sketch Drawings of What I am planning to build out of Perspex
    3D Casing :clap:
    The DVD Mount :dremel:
    The HDD Mount
    For What i can say for my Modelling is that im a :hip:
  7. GFORCE
    18 Oct 2003
    G-gnome where did you get your Stepped Drill bit from?
  8. G-gnome
    G-gnome Peter Dickison
    8 May 2003
    Gasweld in Newcastle. Expensive though - $90 I think. I have gotten my moneysworth though. :)
    It's certainly useful. :dremel:
  9. GFORCE
    18 Oct 2003
    I need one for the Rear panel of my Case.
    This case is for my Year 12 Design and Tech Project but is really a prototype for my fathers store www.campsiehifi.com.au
  10. GFORCE
    18 Oct 2003
    Do you mind if i use your plug and socket connection idea?
  11. BadOldMan
    BadOldMan What's a Dremel?
    15 Oct 2003
    hehe join the que, I think half the people on this forum with exposed bits will be using G-gnome's ideas for the next 2 years..
    I know I will
    and DONT forget to give credit!
  12. GFORCE
    18 Oct 2003
    im gonna wait for his Permission FIRST!
  13. GFORCE
    18 Oct 2003
    Well im getting the perspex tomorrow and goin to start marking up and **** on monday when i have design and tech
  14. GFORCE
    18 Oct 2003
    UPDATE TIME!!~~
    Ive Started Cutting and Building the Casing.
    I have also bought enough sunset red leds to light up all the Perspex Rods.
    Pictures are attached below. Excuse the Photo Quality as the camera is 3 years old but perfect size for 56K'ers like G-gnome.
    This is the Base of the Unit. It is 6mm Clear Acrylic
    That the front panel clamped down and ready to be filed to the right height
    Me Filing the Front Panel. As you can see this is being done at school. Yr12 Project
    More Shots of the Front Panel
    More Shots of me. Arnt I big? :D
    The Front Panel Masking Taped to the rest of the Body to check sizing
    Joint Shot of the Front panel and rest of body
    The Rods that are to be cut up for Mounting Supports
    Filing down of the Rods
    Another Shot of me. Just to show you how BIG i am. :eeek:
    I am 6ft 7 and only 17
    The Finished rods ready for mounging
    Drilled hole in the Base
    Base Completely Drilled and Ready for Mounting
    Like I said. Please excuse the Bodgey Images. :wallbash:
  15. Pistol
    Pistol Guest
    Dude, this is coming along nicely.
    You're about teh same height as my friend Mase...albeit (and no offense intended) you're a bit heavier. How the hell did you get so tall man, is everyone in your family tall (everyone in his is, thats why I ask).
    So far, so good. I wish my school had a shop...stupid Texas private school was so backwards I barely graduated with a 3.7 gpa...ugh.
    And I realize you might not be at a private school, its just that uniforms haven't kicked in around here. Awesome shop, everything at your disposal, I assume :dremel:
  16. GFORCE
    18 Oct 2003
    Yeh both parents are tall. I am 150Kgs but its mostly muscle. :rock:
    I am at a Private Sk00l. Downstairs there is a Metal Working room and i am in a Plastic Working room. Above me is a wood working room with each class having a range of different Rooms.
  17. LCDNinja
    LCDNinja What's a Dremel?
    22 Oct 2003
    6'7"?!?!?! :eeek: :eeek: :eeek: that's amazing. I bet no one messes with you :D
    Good luck on the case, it looks pretty interesting, so I'm gonna watch it closely
  18. GFORCE
    18 Oct 2003
    Building it is Stage one. I have to Design and Build Circuitry for the Front Panel and ****
  19. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    hope you goto a chiropractor :eeek: anyways nice work.. my school butchered the shop classes. they saved the jewelry shop tho -_- nothing like buffing a heatsink in a room full of 30 girls making necklaces and earings. Anyways great project I love to see people hand fabricating cases.
  20. GFORCE
    18 Oct 2003
    Well since it is al prspex i only hvae to stay in one class.
    I am waiting or g-gnome to move this thread into Project Logs
