Project: Black and White wavemaster: CPU Magazine Front Cover
Discussion in 'Project Logs' started by THEkorean, 1 Jul 2006.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    first of all thanks for the quick comments guys, right now, i think im leaning towars painting the from pannel mesh black, rad mesh black, and side pannel mesh black too, and miror finishing the innards
    please keep the sugestions flowing :)
  2. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    Hell yea, do that :rock:
  3. THEkorean
    THEkorean 42
    10 Jun 2005
    ok so i got another update today, i finaly finished bondo'ing the spinner and i attached it to the fan here are the progress shots
    Stock cooler master fan, which i undervolted to run slower and quieter
    then i cut a strip of mesh and glued it on with hot glue
    heres the finished spinner
    spinner placed on top of the fan just for a look see
    heres teh fan ready to get glued
    and heres teh final shot with it all mounted, i opted for an external mount because otherwise you cant see the nice mesh i put on, and by mounting it outside, you can fully see the moded stock grill, which has been cut out and filed down to acomodate the spinner :D
    heres a further-away shot
    edit: i just realize that i forgot to mention the hair ties that i "borrowed" from my sister, you can see then on the Res mounts, they are nice, soft, and black, they are also REAALY tight, so they do a MUCH better job than the rubber bands i had before
    well thats it for today, when the weekend begins, im going to start stripping the entire case and painting everything, i even have somethig special planned for the righ tpannel of the case, so stay tuned!
  4. THEkorean
    THEkorean 42
    10 Jun 2005
    i spent a total of 12 hours getting this thing stripped, repainted, polished, and installed dual-boot Vista RC2. Now this thing is ready for competition (Coolermaster 2006 modding competition). The deadline for entry is in a week, so im going to finish up the right side pannel by tomarrow and ill have a formal worklog made by thursday hopefully. Here are the pictures
    first of all, i removed the original metal plug with a LED plug on my Res
    then i took the RAD off, it was CAKED with dust
    Then all the hardware out..
    half taken apart...
    heres a picture of how i mounted the mobo tray cover on the bottom screws on the PCI brackets, i believe i havnt posted a clear picture of yet.
    Case, Rad, Radgrill, front cage, all taped off and ready for repainting
    theres the grill repainted, cant really see the black because of the lighting situation..
    heres the front cage, same lighting situation
    heres the new paint, SO SHINEY!!!
    heres a mock fit
    another mock fit
    wired some LED's for the front cage, in the end, i opted for only one
    shakey picture of everything put back together
    a better picture of the carbaon fiber on the PSU backplate
    shot of the back
    shot of the rad
    front, (omg the cage look so COOL)
    closeup of the LED situation
    heres a picture of the POLISHED SCREW, it looks so shiney, i polished every visible screw on this machine (except for the side pannel ones, which i forgot to do, and will do tomarrow)
    anyways, this project is coming to a close, but there is still one LAST surprise, which will be included in my final update. thanks for all the support guys, and stayed tuned for the final update!
  5. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    this looks AMAZING. i love car-inspired mods, but this is just awesome. it has given me a couple of ideas for my own case (i always say that, but its true!). that paint looks really good, and the front grill- :jawdrop:
    great job, subscribed
  6. accro
    accro What's a Dremel?
    21 Aug 2005
    Mod is amazing, but hey, can't you even try with the pics? it's not hard to put cam on some stabile thing, or just hold it still when youre taking a pic.
  7. THEkorean
    THEkorean 42
    10 Jun 2005
    i finished the painthing, here we go:
    step 1: print design from computer on the back of a sheet of XXXmain paint mask
    step 2: prime the pannel, and spray a coat of white near the bottom
    step 3:carefully cut the letters out and apply to the pannel
    (i know i says wave mater, it was cause i left the room fan on while i was cutting andthe S got blown away, i eventualy cut a new one)
    step 4: mask of racing stripes with blue painters masking tape
    step 5: paint the entire pannel with a coat of gloss black, then let it dry (sorry no progress shot :wallbash: ) then spray with multiple coats of metalic black, then top it off with clear coats
    step 6: peel back letters and stripes
    step 7: instal pannel into computer case
    step 8: marvel at its beauty :D
    well ..first of all id like ot apologize for the delay, i had to attend a theater cometition (which me and my group won 2nd place for set design) and i had to do quite a bit of reading for school, anyways, this brings most of my project to a close, i will still be posting after i make some final adjustments to the case, and after i take soem high res pictures. thanks for reading, id like to hear your comments :thumb:
  8. itsjustacompaq
    7 Sep 2006
    that paint really looks good. i like the little touches you do to make the case stand out (the fan, the mesh board cover, etc.). keep it up and i hope you do well at the case competition.
  9. THEkorean
    THEkorean 42
    10 Jun 2005
    heres my setup as of now:
    the second image is a 3072x2304 @ 7 mega pixels, it was almost 4mb, photobucket reduced it to 527kb :sigh: , anyone know know where i can get a photo host that will allow me to upload full quality images?
    EDIT: thank you direwolf, quality is better, but not full :\
  10. sui_winbolo
    sui_winbolo Giraffe_City
    25 Sep 2004
    I love it, I also own a wave master, awesome job! :thumb:
  11. gideon
    gideon What's a Dremel?
    27 Feb 2006
    I like your mod although it's not my cup of tea.
    I also have a wavemaster, great case but still thinking of something original for it :D
  12. THEkorean
    THEkorean 42
    10 Jun 2005
    Some stuff i did for the CM case mod contest:
    I finally found time to have a proper photo shoot to show, as close as possible, to what my case looks in person, and get a decent shot of me, here are the results:
    Picture of me smiling w/ the sign and my modded backpack (same theme as the case)
    The only decent of me not smiling, I held the sign the wrong way in the picture, so I used paint to type it in.
    Well the brings my work log to a close, and I hope you enjoy my log as much as I enjoyed making it.
  13. PA!N
    16 Jul 2005
    Uhh you look soo badboy :hehe: ;)
    Nahh just kiddin...awsome mod m8!
  14. THEkorean
    THEkorean 42
    10 Jun 2005
    lol thanks, thats the look i was goin for, koreans can look pretty "bad" if they try LOL
  15. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    really great mod, like the total mesh look very very good :rock: :clap:
  16. Jipa
    5 Feb 2004
    I don't see much of a smile in the other pic either :eek: There seems to be some flaws in the mesh-job but otherwise nice mod :)
  17. Evenge
    Evenge Minimodder
    16 Sep 2006
    That is a nice looking wavemaster! :thumb:
  18. Ener
    Ener What's a Dremel?
    17 Oct 2005
    wow your really short... or the case is huge...
    lol it looks good, the stripes arnt my thing but everything else looks fantastic
    p.s does your bandana have pirates on it?
  19. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    excellent work..
  20. THEkorean
    THEkorean 42
    10 Jun 2005
    LOL naw man i still dont have a camer tripod so i had to put the camera on my bed, and my bed is really close to the ground so i had to kneel down and duck my head so the case, the sign and my face would all fit in the picture. And the banda... i originaly had a nice white bandana ready, but ilost it so i was forced to use the bandana i got from korea, it has a map of Jeju island as well as some cartoon pictures of villagers, i know its lame, but that all i had and i wasnt about to spike my hair up again after showering (gotta look good for the contestant pics ya'know? LOL)
    thank you all for you comments! Its REALLY cool to have some of the most awesome modders on the site comment on my work and once again thank you all for supporting me Bit-tech rules :thumb:
