Project - Black & Blue
Discussion in 'Project Logs' started by Don, 20 Nov 2003.
  1. Don
    Don Guest
    I had one these standard cheapo cases lying about only to discover its not so standard and has a few bits n peices not usually found on cheapo cases,
    Holder to put fan under Hardrives
    Grill to put fan on front of case on inside ( not that there would be anything there to cool cept a few wires )
    Front of the case has an extra plastic molding that can pop off and ide assume u could buy diffrent color ones.
    If anyone recognises this case plz tell me i wouldnt mine purchesing 1 or 2 more as they have a fair bit of modding potential.
    I didnt take any pics be4 i started to dremel it apart so u carnt really tell what it looks like but bare with me.
    Ive started sanding 1 of the 2 side pannels and the top which i had to drill the rivets out to get off.
    Here is paints im going to be using
    Here is the front of the case primed
    Pics of a few of the tools im using
    Heres the 2 front pannels after a second coat of black gloss, it either hasnt dried properly or ive done something wrong as it looks dull in some places and not in others
    Some of me goodies have arrived aswell 2 crystal led fans with sleeve bearings and 1 cc lamp.
    More to come, post your views plz
  2. ynema
    ynema What's a Dremel?
    27 Oct 2003
    Can't see much as of yet but hopefully we will soon.
  3. Don
    Don Guest
    its the painting thats ****ing me off if that was out the way ide fly thought the rest.
  4. pranks7er
    pranks7er mange tout
    25 Dec 2002
