Case Mod - In Progress Project Black Copper: Lian Li P80 & PA140.3
Discussion in 'Project Logs' started by aka_gk, 24 Feb 2010.
  1. aka_gk
    aka_gk What's a Dremel?
    12 Feb 2010
    Hi :)
    My name is Kirill and I am not new on modding related forums, but first time posting here. Hope you will be enjoying this log ;)
    Note: some work is already done that is why I will keep related parts of the work together and do not follow chronological order sometimes.
    This project has been going for 6 months (OMG) already, it moves slower than I would like to have it but anyway here is the little introduction:
    Summer 2008 I bought Tt Kandalf LCS with built-in WC so it was my first water experience and since then I am addicted, forever :D But that case and WC was literally piece of crap and after a year with it I sold it to start from the very beginning.
    Aim of this project is to build clean-looking and dead silent case. Also I'll try to push my CPU as far as possible.
    Hardware list:
    CPU: E8500
    MB: Asus Maximus Extreme
    RAM: 2x 1Gb OCZ Platinum 1600Mhz
    GPU: Gainward 4870x2
    PSU: Antec Signature 850W
    Case: Lian-Li PC-P80
    HDD: Seagate Barracuda LP 2TB
    SSD: Kingston SNM225 80Gb
    WC parts list:
    CPU block: Aquacomputer Cuplex HD - changed to Watercool Heatkiller Rev. 3
    GPU block: Watercool HEATKILLER GPU-X² 4870-X2 LT
    Pump: Swiftech MCP350
    Radiator: Thermochill PA140.3 with Yate Loons D14SM-12 and Noiseblockers PK3
    Reservoir: EK Multioption Res 150 Rev. 2
    BP barbs, Primochill Pro LRT tubing
    I've started with sleeving:
    MB 24-pin
    [​IMG] [​IMG] [​IMG]
    ^^Here you can see old CPU block
    8-pin power
    Yate Loons
    Ok, then here is early layout of the case (it didn't significantly change though :))
    [​IMG] [​IMG]
    As you can see there is only one free 5.25 slot, that is why I had to change 2 my WD HDDs I initially planned to SSD mounted somewhere else
    Next some dremel work.
    First of all marked the holes
    Do not forget to use protective gear :)
    A hole for 24-pin power cables
    Bottom hole for GPU power and all other cables like Buttons, LEDs etc.
    After dremelling I rounded the edges with handfile so that they were smooth, no cable fraying here
    Next step is preparing case internals for powdercoating, I've drilled out most of the rivets and removed metal struts inside of the drive bay because they didn't allow to fit radiator normally.
    [​IMG] [​IMG]
    started with handfile, finished with 180, 600 and 1200 sandpaper
    later removed second pair too
    Drilles new holes in Lian Li rad brackets to fit 140mm radiator
    Some other parts prepd
    UN pump bracket
    OCZ XTC RAM cooler
    And finally heap of hardware waiting to be powdercoated
    Turned out nice!
    [​IMG] [​IMG]
    I decided to change CPU block, ordered in chilledpc and asked them to powdercoat it
    now it blends in perfectly with GPU block
    That's not the end for today, I'll put the rest of the work a bit later.
    And I am very sorry for thumbnails, it is not so convenient to click everytime you wanna see the picture, but I already have all my pictures uploaded in 1024x768 (that's too much here, right?)
    Thanks for reading, any thoughts, comments and advices are highly appreciated :thumb:
  2. aka_gk
    12 Feb 2010
    Ok, moving further
    Took some nice countersunk and dome headed rivets
    Some tape onto the tool to not scratch the rivets
    Assembled the case back
    and mounted aluminum casters
    Then to drives mount
    There was a plate in the box of the accessories for the case, as I remember it calls Xeon mounting something, don't really know what is it for
    I am gonna use it like that
    First of all mounting holes
    Minor tweaks with handfile to align perfectly
    This piece has to be cutted
    Done!
    Polished the edge and rounded the corners
    And shortened standoffs a bit
    This how it looked like before painting
    Slightly sanded and primed (screws are to protect the threads)
    And after million rounds of priming sanding repriming resanding painting sanding repainting etc. it is finally done. I am a noob in painting, ya know :p
    HDD I will use for storage, low rpm Seagate Barracuda LP 2TB
    SSD will simply be mounted on MB standoffs (spare from case package)
    Something like that
    Some watercooling stuff in the next post.
  3. stonedsurd
    11 Mar 2009
    Your pictures are great and that sleeving is PERFECT! How did you get the heatchrink to line up like that? Just lots of careful cutting/measuring?
  4. aka_gk
    12 Feb 2010
    Well, now some watercooling.
    First in the line, Koolance controller (and additional temp sensor)
    aluminum bracket asks for some matt black paint :thumb:
    here you go
    It doesn't sit perfectly in the drive bay - need to fix this
    Adjusted mounting holes
    Much better now
    There is some tight cabling though
    Then black bitspower connections I am going to use
    Some more (got new blue o-rings to match my colors)
    o-rings fun :D
    Ok, next part is Koolance splitter (they call it Koolance brass body) and flow meter
    ^^Shiny parts? Not in this build.
    Temperature sensor
    Painted and sleeved
    Splitter
    Sanded and thread protected
    Same with flowmeter
    And finished!
    oh, forgot to mention tubing I will use, Primochill Pro LRT ID 3/8" OD 5/8"
  5. aka_gk
    12 Feb 2010
    Copper blocks tend to oxidate with time
    eww
    Find a good solution to clean them :thumb:
    Assembled test loop
    and did some overclocking, hit 4.5GHz with nice temps, that really was my goal :lol:
    Then stripped GPU down, removed all paste and thermal pads
    Applied new ones, leak tested, installed and checked the temps
    As you can see on test loop picture, there are Medium speed Yate Loons as a rad fans, but I decided to change them to Noiseblockers PK3
    Next I received some new things to play with, it is Mayhem dyes.
    Small review is coming soon, for now just one picture from my homemade $20 DIY lightbox :D Probably I'll use this color in my loop.
    Well, that's it for now, I am waiting for cooling gear for motherboard and some acrylic to make a window.
    Once again thanks for reading, comments are welcome :thumb:
  6. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really really nice and clean job my friend!! Mod on brother! I cant wait for my next build, less art, straight details!!! :)
  7. aka_gk
    12 Feb 2010
    Thanks. Well yeah lots of measuring and cutting, but I use kind of template made of packaging foam to cut equal pieces.
    And while it is on the wire I shrink bit by bit adjusting its position according to one already made model wire.
    Love your userpic :hehe:
    Thanks dude :thumb:
  8. Jipa
    5 Feb 2004
    Nice and clean work so far, keep it up! Black is the new black, the old black, and the future black for times to come, can't go wrong with that ;)
  9. stonedsurd
    11 Mar 2009
    Cool idea. :thumb:
    Haha, a lot of us have this picture around here. It's a joke that spilled over from the Demots thread :D
    What did you use to clean the block? My HK blocks are both beginning to get that copper crud on them, so any help would be appreciated.
  10. Seeks
    Seeks Minimodder
    13 Feb 2010
    Great build i love the details. Looks like it will turn out really well for you :) good OC too
  11. aka_gk
    12 Feb 2010
    Jipa, Seeks
    thanks a lot :)
    Dunno how to navigate you, this thing is being produced locally and is not exported. Called "Solution for metal surfaces cleaning", it's pretty cheap (like $1 for 300ml bottle) and work better than CILIT for example.
    Probably you can just try different solutions like tomato paste or cola (I heard they work well but not sure) as well as different chemical things for metal that can be found in nearby supermarkets
  12. Djayness
    Djayness phwupupupup
    7 May 2008
    Cant believe I havent come across this project till now, very clean work!
  13. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Nice and clean work, keep it up
  14. aka_gk
    12 Feb 2010
    Djayness, Beast thanks!
    More updates very soon, I hope.
  15. el2k
    el2k Modder
    18 Jan 2010
    Lovely work, Such attention to detail - Even braided the ethernet?!?!?
    Also quality pictures. Nice work mate!
  16. Pashtet
    Pashtet MonstaMods
    18 Feb 2009
    hello, aka_gk!
    love your idea with the home made softbox
  17. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    love the work mate.
    Do bitspower supply those additional colours of o-rings, or did you find them else where?
  18. Krog_Mod
    Krog_Mod What's a Dremel?
    23 Sep 2003
    lol i didn't notice the braided ethernet cable until you pointed it out. I really like how it looks. Cable braiding is awesome.. it's just so dang expensive if you need a lot of it. I sort of go for any old crap i can find laying around.
    I've never seen the motherboard power cable braided like that (each individual wire), but I suppose with a water-cooling system nobody really needs to worry about airflow too much anymore so it's all for the looks now. Btw, it looks great so far! Keep up the good work and welcome to Bit-Tech!
  19. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice work. I'm gonna follow this one
  20. aka_gk
    12 Feb 2010
    Thanks mate :)
    LOL yeah, I just did not like the look of ugly grey cable sticking out of my laptop blah blah... actually I was bored :D
    Hey dude
    it is dead simple but works nice. And cheap for sure, you know much about cheap homemade things, right? :naughty: :D
    probably you've already seen, but anyway here it is
    Thank you.
    Nope, they are sold separately, about $2 per 10 pcs. I got mine in perfomance pcs
    Thanks, glad to be here :clap:
    cheers, hope the final result will not disappoint you
    Have some new things arrived today in a huge box, but I'll show it once installed :rolleyes:
