Case Mod - In Progress Project Black Copper: Lian Li P80 & PA140.3
Discussion in 'Project Logs' started by aka_gk, 24 Feb 2010.
  1. TotalGaos
    TotalGaos Stainless steel.. hmm..
    16 Dec 2007
    Yeah good Q by Phinix. What camera and possibly extra equipment do you use?
  2. aka_gk
    aka_gk What's a Dremel?
    12 Feb 2010
    I have Canon Powershot G10, tiny Unomat tripod , homemade lightbox and that's it :D
    ghetto lightbox can be found on the first page, yesterday I built bigger one for motherboard shooting.
  3. TotalGaos
    16 Dec 2007
    Yeah I guessed you needed a bigger one for the last pics.. Anyway nice to see you are putting extra effort in the pictures, its a real plus on the worklog!
  4. eBarazzetti
    eBarazzetti Sorry for my english, i'm brazilian
    6 May 2010
    I pretty liked the way that you disposed the hard disk and the ssd drives, this is an inspiration for me. :D
  5. aka_gk
    12 Feb 2010
    :thumb:
    good to hear :D
    new memory has finally arrived!
  6. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    i love those ram heat sinks !!!!!
  7. Volund
    Volund Am I supposed to care?
    16 Sep 2008
    The ram and that board together are just amazing :D
    beautiful
  8. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Neat ram sinks, they definitely go with the mobo sinks
    Great mod
  9. TotalGaos
    16 Dec 2007
    Sweet combination of hardware!
  10. Monkey Puzzle
    Monkey Puzzle Minimodder
    18 Feb 2009
    you, sir, have almost exactly the same choice of hardware/colour scheme I went with. Good choice! :)
  11. Matticus
    Matticus ...
    23 Feb 2008
    This looks fantastic! I can't wait for your next update.
    Those fan stickers you bought from zazzle, are they the standard small sized 3.8cm stickers?
  12. aka_gk
    12 Feb 2010
    disturbed13, Volund, The_Beast, TotalGaos, Monkey Puzzle, Matticus
    thanks, glad you like it!
    yep, it is small 1.5" stickers
    now little update, finally I have managed to finish the PSU by 95%
    At the beginning I heatshrinked sleeving just near the PSU output but it turned out not good, at all. I remade it and now it's much better, let's watch step by step:
    Slightly widened the hole, it was completely round at first. Bare metal edge can be fixed with marker :)
    Then put all sleeving inside and fixed with zip ties. Also snipped SATA cables and 4-pin motherboard power cable.
    But as my friends said, isolating tape sometime tends to peel off under hot conditions, so I remade it with heatshrink
    tiny heatshrink first
    then twist the wire and put bigger tube over it
    And now there is only 4-pin molex left naked, will do it later while prefinal assembly to cut it to exact length.
    thanks for watching! :thumb:
  13. The boy 4rm oz
    10 Apr 2008
    I really do love what you are doing so far, excellent clean modding. I actually had a similar mod planned with the slightly smaller variant of that case but now I may have to re-think my plans :D.
  14. aka_gk
    12 Feb 2010
    thanks for the kind comments :)
    okay, that was been awhile since I updated this log but I am still here and it is still going :D
    here is the new stuff:
  15. eVoPhantom
    eVoPhantom What's a Dremel?
    21 Jul 2010
    Looks fantastic so far
  16. Colossous
    Colossous Minimodder
    28 May 2007
    Great mods duder
  17. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    Very clean work mate it looks really good. In particular your sleeving, it's dead on!
  18. aka_gk
    12 Feb 2010
    thanks guys, I really appreciate your feedback :thumb:
    there is a thing that annoys me for a quite a long time, here it is (no, not the PSU :D)
    Fixed!
    I got some G3/8" to G1/4"adapter to put black barbs instead of chromed
    little bit of a teasing
    now I am basically measuring everything to make some more cuts due to the new hardware
  19. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    Heh. Great attention to sleeving, and nice pictures. Ive underestimated the use of a cheap lightbox.
  20. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    This looks freaking epic man!!! Love it!
