Case Mod - In Progress Project Black Copper: Lian Li P80 & PA140.3
Discussion in 'Project Logs' started by aka_gk, 24 Feb 2010.
  1. aka_gk
    aka_gk What's a Dremel?
    12 Feb 2010
    thx guys, really means a lot for me!
    okay, finally managed to do something.
    Resoldered pump from 4-pin to 3-pin, quite straightforward:
    found that it's good to paint the connectors with permanent if wires are of the same color
    and result! I had to adjust pump case a bit to let the pump fit with new wiring
    btw, I sanded off the dents and repainted the pump case, now it is nice black and smooth :)
    this is where it is going to be
    and the magic snap caps worked great
  2. aka_gk
    12 Feb 2010
    it's been a while since I posted here last time, time to update
    Did some more cabling and sleeving, now the lights - cut 4-pin molex, crimped 3-pin fan things to hook it up to the built-in rheobus
    (фотки - кликабле, если кто-то хочет чуть покрупнее)
    and sleeved (zip tie mount is temporary)
    lights off, LEDs on :)
    and sleeved door fans power as well, goes right up to the koolance control stuff
    Then to the radiator.
    I decided to abandon Noiseblocker PK3 fans, because they are suprisingly do not work well with Koolance TMS-200 tach signal goes crazy, they work well only on max (12v)
    So, I got 4 more Yate Loon fans.
    LOL check this out (prices from popular US store):
    Noiseblocker NB-BlackSilentPro PK-3 140mm x 25mm Ultra Quiet Fan - 1700 RPM $24.99
    4 x Yate Loon 140mm Medium Speed Silent Case Fan - D14SM-12 - Sleeved $23.80
    What a bargain
    Immediately started to cut, crimp and sleeve them
    this will be the central part in the case, so I did everything with utmost care, digital caliper Cheesecake LOL
    Did some soldering for the rad, spent 3 days for this thing
    Filed down rad bracket a bit, to let the cables pass freely (p-clip will be holding them)
    then sleeved the fans and assembled everything, enjoy :)
    those soft rubber gaskets are from Noiseblockers PK3 kit, atleast some benefit from non-working $25 fans :D
  3. Gtek
    Gtek Doesn't raise the bar; he IS the bar.
    10 Oct 2009
    A lot of work on details... that's how it should be... good job :thumb:
  4. The boy 4rm oz
    10 Apr 2008
    I agree Gtek, a ton of work on the details.
  5. aka_gk
    12 Feb 2010
    update time :)
    made some progress yesterday, finished soldering stand off to the koolance splitters
    got some missing stuff: flux (Goot paste), solder and torch
    whole setup overview
    doing that for the first time, not everything went well
    results are not perfect, but I'm glad I didn't wasted anything :D those joins will not be visible afterall
    The overall idea is as following: when we have watercooling in the case and a whole bunch of expensive stuff we don't want it to get wet, right? So, when we have draining or filling ports near the hardware we have quite a good chance to spill coolant on it, all this mess is to reduce the chance :D Also this is the way to make WC look neat and clean, a part of build's idea too.
    Let's start from the bottom, pump outlet goes behind the 5.25 bay to the splitter and here is the first thing, drain port.
    Sorry about the terrible tubing - I used old tygon cut outs for this first mockup
    As you may notice due to the construction of splitters drain outlet is slightly lower than inlet - exactly as it supposed to be for easy draining.
    Then tubing is going straight to the top to the fill port! Idea is the same as with drain port, but upside down
    But here is a small problem - tubing won't go easily under the stiffening bar due to the 5/8" outer diameter, also it bends under then back to the bottom splitter - that doesn't look cool
    Now it's fixed with the dremel :D snaky rotary passing tubing to the rad
    for now front piece is just hanging freely, but I'll fix it with stand-off later - don't have proper size right now
    View from the top
    Basically this is it for draining and filling, but I have one more interesting thing for ya, take a look, do you see anything behind the bar? just a tubing with angled barbs?
    But there is a flowmeter actually :D it was supposed to be a part of the tubing going behind the 5.25 bay, but when I'd heard about the issues with vertical placement of this flowmeter, I changed my mind
    And again view from the top
    Supposedly this week I'll take apart my open stand to finally start putting hardware into the case, but still there are some work to do such as painting, sleeving finishes and lots of tiny tweaks and details.
  6. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    epic thread ressurection!
  7. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
  8. pistol_pete
    pistol_pete Air Cooled Fool
    7 Jan 2008
    Nice loop design so far. Most people seem to ignore a drain port!
  9. subby
    subby Me...just like you...only better
    5 May 2009
    any updates fella?
  10. ice breaker
    ice breaker What's a Dremel?
    29 Sep 2011
    any updates?
  11. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    This is so damn subbed!, nice soldering on the koolance splitters! i got a new iea now !
  12. aka_gk
    12 Feb 2010
    sorry for the absence pals, now it's up again!
    changed sleeving to b-magic
    and in place
    some cable management
    and resleeved 8-pin
  13. bruce_rob
    bruce_rob What's a Dremel?
    18 Apr 2010
    That is some seriously tidy cables
  14. Nemezis-87
    Nemezis-87 What's a Dremel?
    4 Jun 2011
    Good Job
  15. KoSoVaR^
    19 Dec 2010
    Omnom nomnomm nomnom nomnom!
    Eye Candy!
  16. KoSoVaR^
    19 Dec 2010
    Comeon, Give us more updates!
  17. subby
    5 May 2009
    bump - any updates?
  18. KoSoVaR^
    19 Dec 2010
    I want a update!!!!
  19. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Me toooo! ^^
