Project: Black Death 9August2006
Discussion in 'Project Logs' started by Vito Corleone, 12 Oct 2005.
  1. Vito Corleone
    Vito Corleone What's a Dremel?
    10 Oct 2005
    Hi
    After a long time of watching a lot of great mods in this forum, i also wanted to start my own project log of my LianLi V1100B.
    This case is very noble, so i decidet to make an very discreet mod.
    A composition of black aluminium, carbon and uv-plexiglas inside of the case.
    Except of the radiator and the pump all water blocks will be home-made.
    The name of the project is according to the pest plaque in the 14th century
    (why? i dont know :D )
    Sorry for my bad english but i am from Germany.
    So lets start:
    First of all the case:
    At the beginning i removed all useless parts in the case
    then i used a dremel to cut a 120mm hole in the bottom of the case
    (quite ugly but later you cant see it)
    this hole is for the fan of the aqua-computer airplex evo radiator
    mounted here
    now it was time for the internal space
    here i use mirror plexiglas to get a bigger and cleaner look
    i wanted to have an very special reservoir in front of the mainboard
    so i cut some plexiglas
    this is the first test
  2. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Love the case, we don't see many of these ones around.
    Nice Res!
    Custom work? :)
  3. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Cool looking res, hope the rest of the project turns out that awesome.
  4. FanatiK
    FanatiK What's a Dremel?
    25 May 2004
    WOW!! I`m impressed and its barely your first post. You`ve already done some cool clean things no one else has done really.
  5. ralph.pickering
    ralph.pickering What's a Dremel?
    6 Apr 2005
    Nice res. Look forward to seeing where you go with this.
  6. Vito Corleone
    10 Oct 2005
    yes the res is custom made
    everything part of the water cooling system will be custom made
    tomorrow i will glue the parts with acrifix 192 and the rest of the interior will be done with the mirror plexiglas
  7. Vito Corleone
    10 Oct 2005
    the next step are the waterblocks
    first the cpu block
    i took 5mm copper and drilled 16 holes in it
    then i made the first plexiglas top
    then the last top and all other parts
    (first i made blue plexi parts, they´ll be orange later
    the first test of all parts
    at night
    i also made some flow tests
    looks good
    then the first test in my old case
  8. Rocket733
    27 Dec 2003
    Awesome mod, what did you use to make the waterblock and what program are you using to model the flow?
  9. matu
    matu What's a Dremel?
    11 Dec 2004
    Same question about the flow testing. :D
  10. Vito Corleone
    10 Oct 2005
    the programm that was used for this was Flowworks, a programm of SolidWorks
    all parts are made with a metall handsaw, a rasp, sandpaper and a borer
    only simple tools
  11. Vito Corleone
    10 Oct 2005
    today i bought a new aquastream 3.5 from aqua-computer
    this is a great pump
    my ram is very hot so i made a fan holder
    this are 2 stripes of uv-plexiglas and one 1mm plexiglas
    it fits perfekt in the 4th ram slot
    now i went on to build the water blocks for my x800xt and the nf4 northbridge
    first i made a positioning device
    then i saw some chopper
    after some soldering
    it is very thin
    the same with the northbridge cooler
    the mounting is made of uv-plexiglas
    and now the final water block in my old pc for some testing
    now i have to mount my aquastream...
  12. Shadowed_fury
    21 Nov 2003
    WOW.
    That is some damn impressive work. Any chance of some more pics of the Ram-cooler? :)
  13. FanatiK
    25 May 2004
    Yes very nice job on the homemade blocks. What are your temps for you card before and after watercooling?
  14. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    You're doing a great job on the wc blocks. One thing about the mounting though. In my honest opinion, it would look better if you had taken a larger plate, instead of multiple small plates. Just one larger plate, mounted all over the top of the block. Not too sure how to describe it though...
  15. Vito Corleone
    10 Oct 2005
    thanks
    @Shadowed_fury
    which ram cooler do you mean
    the corsair ram cooler or the ram cooler of the x800xt?
    @FanatiK
    i only have temps of my cpu water block
    a64 @ 2600mhz @ prime95 @ max 42°
    but you know, you cant trust temp sensors
    @ReFredzRate
    i know what you mean, but this was exactly what i didnt want to do
    a lage plate would not match visual to the "small" and thin ram cooler block
    everybody mounts his blocks with large plates, this is something new and special :)
  16. Shadowed_fury
    21 Nov 2003
    Sorry yes, the Corsair ram cooler :)
  17. Vito Corleone
    10 Oct 2005
    i´ll post some with ne next update
    but the construction is very simple :)
    it is only one stripe of plexiglas for the ram slot and two stripes for the 80 papst fan
    they are sticked together with acrifix 192
  18. MiLwOrkZ
    MiLwOrkZ What's a Dremel?
    6 Feb 2005
    Love the RES and love the Blocks! Anyone who makes there own blocks gets in A++ in my book!!! loving the orange pleci mounting brackets WOOT!
  19. Shinuza
    Shinuza What's a Dremel?
    13 Oct 2005
    This is pretty good, I love the way you make your own watercooling parts.
    Your fan holder is a pretty good, what's temp do you get with this?
    Shinuza San
  20. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    wow... this is really good!
    And more photos please! :D
    p.s. where did you get that fluid dynamics software? is it your work or is it available for consumers?
