Project: Black Hazard 2 - Its been a while ;)
Discussion in 'Project Logs' started by sc4mpi, 22 Sep 2005.
  1. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    [OFF TOPIC:] i never said the way you have your blocks was bad i was mearly refering to the size of pump compared to your rad and how you have them in your loop, u got to think of the pressure drop that huge rad has.
    after seeing the problem you had filling it at the lan i was thinking that with a bit of thought and a replumb it could be so much easier to fill and cooling performance might go up
    for anyone who hasnt seen it and that hasnt got a clue what were all chatting about
    Boswells rig
    [/OFF TOPIC]
  2. koola
    koola Minimodder
    11 Jul 2004
    I would comment on Boswells rig, but because the pics are too damm large I couldn't be bothered to wait for them to d/l.
    All I can say is please stop thread crapping! PM Sc4mpi if you wanna rant lol
    [Edit] I did end up waiting for the hugh pics to download to find an ill thought out PC 75 will an OTT rad with 2 fans on it!!! LOL Before you diss others, get your own sorted out! [/Edit]
  3. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Do you not have problems lifting that thing sc4mpi? There's a heck of alot of water in there :eeek:
  4. sc4mpi
    16 Jan 2005
    dfi gear grip is all i need :thumb: , its not that heavy when compared to say my v1000 of the cube. as it only takes a 1/4" - 1/2" of a liter to fill :)
    anyways bk on topic
    http://forums.bit-tech.net/showpost.php?p=1082696&postcount=5
    comments would be handy. nexxo can u assist with your laws of thermal triggernomitry :p <-- meh that man no's his stuff :hehe:
  5. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    Woah! My hat to you sire.
    You are fitting more blocks and more rads in a much smaller case than I have, and i'm using a CM S4000 4U server case!
  6. SGT_Snacks
    SGT_Snacks What's a Dremel?
    3 Jun 2004
    It's looking fantastic Sc4mpi, as usual :) Will have to come see it in November when I bring the PC7 =D
  7. sc4mpi
    16 Jan 2005
    had some spare time today so i got the bip dual fitted, took about 6 hours in total but it fits ( :clap: :clap: :clap: )
    the rest of the parts for the conversion havnt arrived yet. so theres no much more i can do till tommorws.
    umm. evo 240 grill :D
  8. sc4mpi
    16 Jan 2005
  9. frodo
    frodo What's a Dremel?
    1 Nov 2003
    looking good homie, keep it up!
  10. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Nice job!
    All piped in? If so what sorta improvment? :)
  11. Firehed
    15 Feb 2004
    Very nice work. Clean up that fan wiring hanging all over the place though, it's so out-of-place with all the tubing and whatnot. Not that you see it through the window, but as modsquad would say, it's in the details!
    BTW, is that the 2405fpw or 2005fpw? That thing's fecking huge! If that's the 2005fpw I'll crap myself, I'm saving for one and couldn't possibly imagine it being THAT big.
    Love the Evo240 there. No interference with the PSU? And do you just lose the top drive bay or top two?
  12. sc4mpi
    16 Jan 2005
    its not fully plumbed in , as the res is not fitted, but its been up for a leak test and was playing black and white 2 for 4 hours and the case was cold to the touch, the gfx were reporting back 31c and 32c after 4 hours of solid gaming :) cpu stated 29, much better over the old load temps
    err the wireing in the pics is not the final pic, there not even the proper fans at the back, there were in there for a test when i first plumbed it up, ill sort out all the wireing ones i good the cooling sorted properly. (window will be lit from behind with 2 white cathodes to highlight stuff)
    its a 2405fpw aka 24"
    the rad is a black ice pro dual 120mm but i manged to fit a evo 240 grill to it.
    it is almost 0.5 of a mm between the rad and the psu, i might see if i can find a 140mm deep psu as the tagen is 175mm deep and i lost the top bay only and thats with fans and fittings on the underside :)
  13. Shadowed_fury
    21 Nov 2003
    Get a Hiper Modular! Sorry... They rock :p
    Great temps though, considering how much your cooling, Very impressive.
  14. frodo
    1 Nov 2003
    a hiper modular wouldnt handle his hardcore rig!!!!
    lol
    looking good tho'
  15. Leeum
    16 Feb 2004
    Enermax Noisetaker 600W tbh :)
  16. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    i'm with either a Tagan or a Seasonic tbh :)
  17. jakenbake
    jakenbake full duplex
    5 Jun 2005
    you should water cool the PSU b/c it would be badass... that would eliminate some heat too
  18. MrBean
    MrBean Minimodder
    21 Apr 2004
    Hello Sc4mpi,
    Mod looks great,always does :) Keep up the good work, very nice and tidy. I would think you are having some issues with flow restrictions in those loops. Are the pumps labouring, or not really?
    Question for you, if you don't mind....where did you source those nice 90deg connector Sata Data cables from? I need some for a new project I am buzy with, but cannot find anything local in South Africa.
    If I have to, I'll import some, so if you could point me in a direction it will be appreciated.
    Thanx.
    Br,
    MrBean.
  19. sc4mpi
    16 Jan 2005
    well i lot has happend since the last update the new psu arrived, that now fits in between the rad and the case. the dual bip is in, along with the rest of the stuff , did some wiresorting and braiding :) , ow and one of my seagates decided it was about time to pass on to hard disk heaven (it has been going over 2 years) so they got replaced with 2 74gig raptors <- that are silent i havnt herd anyhting high pitched from them, were as i no the 36gig ones squeel.
    Looks a lot better now,
  20. sc4mpi
    16 Jan 2005
