Project: Black Hazard Two - Finshed, just need to get some snaps.
Discussion in 'Project Logs' started by sc4mpi, 22 Jul 2005.
  1. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    Hello again
    Iv just be able to get hold of a pc-6077 black for a good price iv been after one for a long time. as a sequal to my shuttle mod that was done months ago.
    so after the faliure of the cube as a good gaming comp. this is going to be another lian li as i love them so .
    right time to cut to the chase. the specs are the same as before with some minor alterations in the cooling department.
    Hardware ~(updated)
    A8n sli premium
    A64 Fx-57
    2Gb OCZ pc3200 platinum
    2x XFX 7800gtx EE
    2xSeagate 80gig S-ata (Raid 0)
    Seagate 200gb S-ata
    Nec- 3500 dvd-rw
    tagan 2force 580watt sli
    Creative x-fi extreme music
    Cooling
    2xAquastreams
    innovatek XX-Flow Cpu Block
    2x innovatek Coolmatic nv-40's(modded to 7800 series)
    Black ice pro tripple
    3x Hd - o - matics
    Fass-o-matic res.. (innovatek version of the aquatube)
    aquero
    alphacoolchipset
    2x ram plex's
    alpha cool mosfet block a8n~
    2 innovatek gtx microcoolers for gtx
    right iv been doing stuff this morning. so heres some pics :)
    the insides :p, iv put blow hole on all the edges that will be seen
    Dremeled out a hole for the psu wires to follow , blow hole rubber around that to :)
    Dremeled the fan grills out and added rubber and antivibration washers on the holes, also drilled out the rivits on the lid, tapped the holes with a 5mm tap, and then secured it with hex bolts so its now removable :)
    close up. :)
  2. sc4mpi
    16 Jan 2005
    with two Adda AD0812LB-A70GL's fitted :)
  3. Arkuden
    Arkuden mow?
    9 Jul 2004
    looks like this will be pretty sweet! are those standard fan screws? almost look like hex bolts from here
  4. Chobbler
    Chobbler Running with a Spoon
    17 Oct 2003
    Your soooo weak man. Trust you....so much for not doing a log :D hehehe
    PC6077b!!! RAWWKKSSSS :rock:
  5. LOTTARO
    LOTTARO What's a Dremel?
    1 Jul 2005
    Let this beautifull case alone!
    dont touch this babe... DONT RIP IT!
  6. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    Copy cat ;) :p
    Looks great! What screws are they on the rear fans? and where vibe damps from?
    Oh.. why the wierd shaped hole for the wires to feed through?
  7. sc4mpi
    16 Jan 2005
    they are m5 hex bolts :) , the wierd shape hole is cause if u look on the other side of the pic. there are 4 random holes there. so i joined them up :)
    as for that case unreal hippie that looks like a pc-60 completly diffrent layout, this has no front intakes and its all 5 1/4 :D
  8. sc4mpi
    16 Jan 2005
    hehe im not going to be butchering it ill leave that to chobbler :p < i made him get the same case months ago.
    this will be a pure clean cut case :) i love its lines.
  9. hitman012
    hitman012 Minimodder
    6 May 2005
    Looks nice. I really like the rubber trim, it adds a lot to the look of the case. I also love the appearance of the exposed fan blades (grills are for wimps :D)
    Those Tagan PSUs come with too many cables! They should be good behind the tray like that, on mine they are just shoved into the CD bays :duh:
  10. LOTTARO
    1 Jul 2005
    Yes! , when i saw that lovely Lian Li case, i hate the idea of put a dremel on it.
    Anyways! subscribed!
  11. Chobbler
    17 Oct 2003
    Nothing wrong with my case :p its almost a 6077b....well it was once :D
  12. unrealhippie
    24 Jul 2004
    Havent you learnt yet that lian-li up until V series relied on the same model for like a decade using slight variations. On yours sure its all 5 1/4 and no front intakes, but at heart its the same. I recon those random holes are trying to confuse people into thinking its a completely different case ;)
    Still, must admit the 6077 does look better than the 60 due to 5 1/4. Also front intakes pretty useless... what detracts is those random holes! Also that HD caddy thing at base looks nasty. The lines on it ruin the effect. (by the way, if you need more blanking plates if you remove caddy.. pm..)
    Still, I cant justify starting a log for my work. Wiring is so neat sending it behind pc60 that I cant justify sleeving the tagan.
    By the way to person saying about wires, newer tagan models are much lighter on the wires I find, having replaced all those 4 pin molexes for 4x SATA. Leaves just 8 4pin molex and 2 floppy.
    Scampi, yours have the detachable 20/24 (remove 4 pins) ATX cable?
    Anyways keep us updated!
  13. Chobbler
    17 Oct 2003
    I've got quad 120mm Front intake fans on mine.....You saying its not a good idea? hehehe
  14. sc4mpi
    16 Jan 2005
    and were the wires will come through to the mobo :)#
    as for them bays ill see when the other bits come u might get a pm :D
  15. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    If this thingy will be same quality and level of skill as all your earlier projects... :rock:
    What else can I do...
    :~subscribed. :sigh:
  16. sc4mpi
    16 Jan 2005
    fitted the Fass-o-matic :dremel:
  17. unrealhippie
    24 Jul 2004
    Y'know all those wierd holes, it would be cool to have a window there to show how tidy wiring was! Red plexi or similar!
  18. Strategy
    Strategy Banned
    19 Jul 2005
    Prop's for the mods, but is there really any need to make a new thread each time you do a minor update?
  19. hitman012
    6 May 2005
    He's not. He's just changing the thread title to reflect the project's current status.
  20. sc4mpi
    16 Jan 2005
    i havnt. iv have 3 diffrent projects... there for 3 diffrent threads.. any hows bk on topic :dremel:
