Project: Black Hazard Two - Finshed, just need to get some snaps.
Discussion in 'Project Logs' started by sc4mpi, 22 Jul 2005.
  1. Chobbler
    Chobbler Running with a Spoon
    17 Oct 2003
    sc4mpi touched my special place. i mean erm nice mod
  2. Firehed
    15 Feb 2004
    Looking nice. I used to use a PC-6077 a while back, great case. You've managed to cram a LOT in there! I had trouble with a single 120mm rad and a D4 converted to 3/8". Then again, it'd be a load of fun trying to watercool the 3077, the 6x/6077's little brother.
  3. Idioteque
    Idioteque Telephasic Mongoose
    21 Aug 2004
    nice modding... although I don't think you should show the copper motor bits on that window fan... just my opinion...
  4. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    Nice mod m8.
    BTW I have the same board DFI nf4 LanParty board, I was wondering if I need to connect the 4 pin and floppy power connection on the board. I hard it was only if you are using more then one video card.
  5. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    The case wont have any blue fans in when im done. but at the moment there all i have :grr:
    As for the dfi , i have the 4 pin molex plugged in but not the floppy 4 pin :)
  6. Drexial
    Drexial Minimodder
    28 Jul 2005
    did you wrap the PSU cables, if not, what PSU is that, if so, where fif you get the hose for it, looks awsome.
  7. TMM
    TMM Modder
    12 Jan 2004
    It's an OCZ Powerstream and it comes pre-sleeved :thumb:
  8. sc4mpi
    16 Jan 2005
    its a tagan 2force 580watt sli it comes semi braided. but not entirly. :)
  9. Marquee
    22 Jul 2005
    The OCZ powerstream PSU are super slick. I really want a powerstream or a Ultra PSU, but I dont think they have them in ATX 2.0 yet.
  10. CaPs_On
    CaPs_On What's a Dremel?
    3 May 2005
    This looks awsome, great ideas.
    And the radiator placed in the bottom is just ace, dont have good enough words to suit this cleanlyness.
  11. sc4mpi
    16 Jan 2005
    just made a order up for one of the freezer chipset blocks and a mosfet block and 2 ram blocks haft to see if i can adapt them to fit 2sticks per block :)
    Mosfet block
    Ram
    Chipset block :)
    This should make things intresting :D means i can get rid of that big 120mm fan and zalman bracket :)
  12. vapb400
    vapb400 What's a Dremel?
    24 Feb 2005
    Awesome! Keep up the great work and kick ass parts!
    The 6077 is one of my favorite cases, and this thread inspired me to plan out a mod of one for 2 hours at work today :)
  13. Firehed
    15 Feb 2004
    Best way to spend time at work :D
    That's a lot of waterblocks... hope the rad can handle everything. But of course, the more that's watercooled, the better imo.
  14. Big SturL
    Big SturL What's a Dremel?
    15 Jul 2005
    Uhhh, dude, didn't you have a A8N aswell? Where do you get the money from?
  15. sc4mpi
    16 Jan 2005
    the a8n and 3500+ was sold and i got the dfi and a 4400x2 as the dfi is ment to work a lot better than the a8n with x2's
  16. MoOstick
    MoOstick What's a Dremel?
    28 Jul 2005
    Stupid question? Yes... indeed : what type of screws and bolts did you use for installing the fans in that pic?
    I found some that could've been cool but they didn't fit in the fans holes... Could you please enlighten me?
  17. sc4mpi
    16 Jan 2005
    m5 socket cap screws :)
  18. mattthegamer463
    26 Nov 2004
    cool, ive never seen ram water blocks before! nice job so far, keep it up :thumb:
  19. sc4mpi
    16 Jan 2005
    few things done. iv just got a rather tasty dell 2405fpw tft its HUGE :D, iv been having a lot of problems with the mothboard recently it wont post a screen when the cards are in sli :S, i also decided it was starting to look rather packed so i turn the hds around and they turned out pretty well :) sill havnt recived my delivery of blocks from watercooling.de =/
  20. Marquee
    22 Jul 2005
    How are your temps holding up with that type of CPU waterblock?
