Case Mod - In Progress project [Black Label Society]
Discussion in 'Project Logs' started by do}{tor, 29 Jan 2014.
  1. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Very nice :rock:
    The lightbar/plate is very cool, I assume the (lasered) grid on the plexi is for better light distribution?
  2. do}{tor
    do}{tor What's a Dremel?
    21 Dec 2012
    Thx! :D
    Yes, for the best dispersion of light on a surface!
    I decided to go town, to feed bears :rock: yes to take a steam bath in baths, well and as weather allowed, I decided to look that turns out:
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  3. Father Fuzzy
    Father Fuzzy What's a Dremel?
    14 Apr 2014
    Very cool project
    Those gt's will rock that mo-ra
  4. hanssx2
    hanssx2 Minimodder
    1 May 2014
    I really like you leather work. It really brings style to a stubborn case.
    Unfortenatly your acrylic window is really scratch. Do you intend to smooth the scratchs out?
  5. do}{tor
    21 Dec 2012
    It is more than thanks, friends!
    At a window there are no scratches, it is a protective surface which I yet don't remove gives such effect, well and if to me has the luck" to catch scratch - that I it right there will undertake to polish it :)
  6. do}{tor
    21 Dec 2012
  7. Farsan
    Farsan What's a Dremel?
    1 May 2014
    I love the heavy metal theme!!! And skin does it job, looks awesome!! Keep going man
  8. Z0DIAX
    Z0DIAX bending alloys
    26 Jul 2013
    what are you going to do with the Arduino and those motors, it's quite intriguing... love to see what you're up to, keep use posted.. congrats with you MOTM nomination
  9. do}{tor
    21 Dec 2012
    Farsan, thx man!!!
    Z0DIAX, The light panel with the BLS logo is a door which will close the forward panel, controlers and tanks. Arduino, the engine and the panel for this purpose, чобы to organize all this.
    Well and now is closer to the project. I couldn't avoid the producer of guitars which plays Zakk so the power unit looks now here so.
    [​IMG] [​IMG] [​IMG]
    Well also I estimated as wires will be combined with the general concept.
    :rock:
