Scratch Build – In Progress Project: Black N' Blue - 6 May-FINAL PICS
Discussion in 'Project Logs' started by DluXe, 14 Mar 2012.
  1. DluXe
    DluXe What's a Dremel?
    7 Jan 2012
    Hi.
    Now its my turn to show my scratch build, please come with questions and criticism on the way
    For those who are familiar with Mod Men Show, will probably recognize it, its quite similer to their stratch build, but I fell in love with it, and wanted to make one myself:)
    The basic design is similar to theirs, but changed things here and there, to put my own stamp on it:)
    Everything is made ​​by hand or with manual machines, so no CNC equipment is used.:dremel:
    Spec.
    material: MDF, plexi, stainless steel, nylon,
    Hardware:
    Asus Gene-z
    Samsung 128GB SSD
    8gb Kingston RAM
    Zotac AMP2 580 3GB
    Intel i5 2500K
    Water cooling:
    2xSingle radiator
    XSPC raystorm cpu cooling head
    EK gtx580 block
    innovatek tube
    Laing DDC pump
    XSPC Laing DDC Reservoir Top
    Feser fittings
    Here is a rough drawing of the project, perhaps some things get changed underway:worried:
    The first steps
    4 pieces of 20mm MDF glued together and milled out with a router from a template, i made out of some thinner wood, However, it still remains some holes:)
    that's all for now, hope you like it:)
  2. KidMod-Southpaw
    28 Sep 2010
    The initial renders look fantastic, can't wait to see how you pull it off! Great start! :thumb:
  3. Black_Mummy_DK
    Black_Mummy_DK What's a Dremel?
    3 Oct 2011
    that render looks.....:jawdrop::eeek::jawdrop::eeek::clap:
    now get to modding!!
  4. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    hmmm... someone inspired by the idontrememberthenamebutcheapsandcpcandsomeguysmadeit ? :p really nice design! i take it as you have worked with mdf before? :p
  5. peteski
    peteski long live the pc
    8 Jun 2011
    sweet render mate cant wait to see how this comes along :rock: :rock: :rock:
  6. lucasrubini
    lucasrubini What's a Dremel?
    26 Feb 2011
    Subscribed!
  7. DluXe
    7 Jan 2012
    Thanks for the feedback:D
    as I wrote in the introduction, I have gained much inspiration from mod men show:D
    About MDF, I have worked a little with it some years ago, but not for casemodding:)
    A little update
    Spacers between the top and bottom plates
    Template to create the blue plexi-plates
    Done
    Test mount
    polishing of the plexiglass
    Thats all for now:dremel:
  8. bulldogjeff
    2 Mar 2010
    Very interesting. I think I'll be watching this one.
  9. DluXe
    7 Jan 2012
    Update 16/3
    New toy:dremel:
    Some stuff form Aquatuning.de:)
    -Colour for the water from Primo chill-steel blue
    -2xUV diodes
    -GTX580 backplate
    -Fancontroller
    2 lead-through for the tubing, 2 more is made for the pci-e cables
    the standoffs for the motherboard
    Well it all went so well, so did not really get so many pictures, but here is a test mount of the motherboard and optical drive, but as you se the top plate i done, and one of the plexi sides, some holes here and there are still missing:)
    Back to work:dremel:
  10. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Love that mobo, but your camera makes the ROG redness a bit too orange. Maybe play around with the white balance (if possible in your camera), or post process the pics?
    Also: "The Mod But Show"? I'm pretty sure I never heard about that one - is it a secret, parallel show to the "Mod Men Show"? Perhaps the bloopers reel? ;)))))
  11. DluXe
    7 Jan 2012
    haha my bad:wallbash::D
  12. DluXe
    7 Jan 2012
    Some sanding here and there, test mounting the psu and pump in the bagground, fits ok:rock:
    ready for the vinyl foil, to be mounted
    (bubbles are removed after the picture was taken)
    foil mounted on the bottom plate, shiny:clap:
    Waynio likes this.
  13. Nutman
    21 Oct 2008
    The Mod Men PC will have a run for its money with this one. Fantastic.
  14. kelmannen
    5 Feb 2011
    Great progression! ;)
    And nice new tool there! Got one of those myself :p
  15. Waynio
    Waynio Relaxing
    20 Aug 2009
    Excellent :rock: looking really good & love those mobo spacers. :D stars +rep
  16. DluXe
    7 Jan 2012
    Things are moving quickly
    Foil mounted, grid has been put in, and plexi ribs fit as they should
    The drive is in place
    Power button is mounted and the pci cables are in place
    :dremel:
  17. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    man that looks good :thumb:
  18. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    last shot looks great, its a nice idea using those fittings to route-cables.
  19. Nutman
    21 Oct 2008
    Yup, coming along very nicely. Shiny last shot!
  20. DluXe
    7 Jan 2012
