Project Black Narcissus: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 28 Jun 2004.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Once again Mr. Firehed you are 100% correct. My Aqua-Computer Aquaero VFD will let me monitor 6 temps and an H20 flow rate (plus CPU and MB temps via MBM), and I plan on using all of them. The probe in the reservoir would give me the coolest H20 temp. The inline probe (pictured below) would give me the highest H20 (installed after the CPU and GPU blocks). The other two probes are from Innovatek and made for there HD cooler, but I am going to see how they will work for an internal case temp and (mounted via an PCI slot cover) ambient room temp.
    AQ included flat 2-wire probes with the Aquaero (yet to be cable sleeved/heatshrinked)..
    So, one for pump temp. and one for hard drive temp.. That should keep the Aqua-Computer Aquaero VFD occupied.
    Chrome DVD drive up-date soon..................
  2. TheDon
    TheDon What's a Dremel?
    21 Oct 2003
    Still looking nice. I hope the chrome on the DVD cover doesn't give you any problems. When you get it back tho it is going to look really nice.
  3. modsquad
    27 Feb 2004
    I picked up my chromed DVD drive cover yesterday. I was wondering how it would come out, when I dropped it off the chrome guy said "not much (metal) to work with". But he did a great job.
    I have to work tonight, but I will get the unit back together/tested/installed in the case over the weekend..
  4. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    Sweet! I think it looks a lot better than the CF. Can't wait to see the drive reassembled and back in place.
    MS- How much does that chrome guy charge you?
  5. modsquad
    27 Feb 2004
    I had a few parts chromed so it was a "package deal" but I would say it was about $60US for the DVD drive cover.
  6. greywolf
    greywolf What's a Dremel?
    15 Oct 2004
    $60US for just the DVD drive cover...that's a lot of duckage!
    Out of my range, cost wise:miffed:.
    Your case is coming along nicely, chroming the DVD and loosing the Carbon Fiber is a good move.
  7. M0RPH3US
    M0RPH3US What's a Dremel?
    20 Aug 2004
    note to self : send adoption papers to modsquad ... :jawdrop::jawdrop::jawdrop:
    /me bows before his master ... ;)
  8. modsquad
    27 Feb 2004
    Chrome plating is not cheap gentlemen. As I said $60 is a guess, I had three items chromed (the DVD drive cover, a AQ full metal jacket and a 4"x4" mounting plate) the damage was $140US. Worth every penny to me.
    I will get the drive back together tonight...
  9. greywolf
    15 Oct 2004
    Well I hadn't seen the pics, before I posted last (too shocked at the price to scroll down). The DVD drive covers do look fantastic. The cost threw me cause I've had this idea floating around that would require chroming the outside of a case...then reality struck. :)
    Now that mirrored plexi might work...
  10. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    something which would nicely accompany this lovely case, is a special edition iPod.. they must have read my mind when they came up with this colour scheme
    nice eh.. id just have my name on the back if i could like, instead of the sigs
  11. [ShoNuff]
    [ShoNuff] Minimodder
    10 Sep 2004
    I have to agree, the chrome mod is sweet.
    I think you are now at the most challenging point. Putting all this stuff in the case while finishing the wiring in such a way that compliments the job you have done thus far. Hiding the psu wires in this case isn't easy. I'm looking forward to the next step. :thumb:
    Where did you get the carbon fiber "sticker" from? I think I saw it at pcmods (ie., frozencpu.com)?
    I'm off for the holiday and I would like to get that done.
    edit: I found it at mnpctech. Do you think one 15x12 inch sheet is enough for two drives?
  12. modsquad
    27 Feb 2004
    Thanks Cleaner..I was thinking about getting an iPod, that one is perfect!!
    Sho, you can order direct http://www.polygfx.com/
    One of the abstract green/black or the CF would look cool in your case. I just did a quick measurement, you need about 16"x9" for each drive (top-bottom-two sides-back).
    It was a little challenging just getting the DVD drive back together, but I just tested it and it works!! Pictures tonight.
  13. modsquad
    27 Feb 2004
    Chrome DVD drive part2
    Lets get this thing put back together. The chrome made for a tight fit (it was much EZ'er to take apart). I will also need to glue the 2.5" thin aluminium plate back over the hole in the top of the case that covers Plextor's disc stabilizer.
    The chrome added a little thickness to the cover which made getting the plastic face and bottom plate a little tuff to get in place. A little time and light persuasion later.
    I used Dow Corning silicone rubber sealant to bond the 2.5" plate to the drive cover.
    Next up..Does it work?
    YES.......
    I need to wait 24 hours for the silicone to set-up before I can polish the chrome and install in in the case. So that is it for today (time for some cold beers).
  14. Fyberwire
    Fyberwire What's a Dremel?
    14 Sep 2003
    Simply Beautiful. Good work.
  15. koola
    koola Minimodder
    11 Jul 2004
    WOW - thats gotta be a first!
  16. modsquad
    27 Feb 2004
    No.. it's been done more than a few times (G-gnome's Orac comes to mind). He chromed about everything you could chrome.......It is a great project you should check it out..His work is the reason I started doing what I do....
  17. modsquad
    27 Feb 2004
    Chrome DVD drive Installed
    I could not wait to see how the chromed drive would look back inside the case. With the silicone sealant set up I polished it up (and removed the million finger prints I put on the thing while assembling). I aslo re-installed the acrylic bottom cover for the area inder the drive.. It looks great!!
    I also made up the top plate (but need to cut out for the two hard drives). I just propped it up in place to see (more/less) what I will end up with.
    That will work. Chrome & Mirrors. Until next time...
  18. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    Ow ma gawd, that is realy sweet!!
    Great shine, on everything!!
    Keep it comming!!
    \\Balder
  19. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Well, IMO I think the white/chrome Ipod looks cleaner.
  20. TheDon
    21 Oct 2003
    Nice looking drive there. I just hope that the cdrom actually reads the disks and functions properly. I have run into a few problems with reassembled CD drives. I hope you don't have my misfortunes.
