Project Black Narcissus: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 28 Jun 2004.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Status Report
    No problem. But I never got to see the pictures you posted..Why not just put the link (you have me wondering what I missed).
    Not a update, more of a status report.
    I will try to get the 6800Ultra installed tomorrow as well as the Vantec power supply (the tape on the sides of the unit is to protect it during installation, it's a very tight fit for a PSU in a LL v1000). Getting the power supply in is EZ, hiding all the wires will be a major undertaking (I need to look over Nexxo's log again, he did a great job with wire management).
    I also was able to locate some red cellophane to rap around the CCFL tubes in the hope of getting a more red color than I now have (looks orange). Firehed came up with this idea, I hope it works.
    The chrome guy is a little backed-up. I should have my chromed parts back by mid-week..
    MS
  2. Henrymonaghan
    Henrymonaghan What's a Dremel?
    6 Nov 2004
    lookin realy good man, keep it up :rock:
  3. PHILIP1193
    PHILIP1193 a Self Confessed HP Server Lover!!
    8 Dec 2004
    yea i removed the pics before i got loada of jip from peeps on thread jacking which was fare enough so here it the link to where i posted them in its own thread!!
    link to shiney fass-o-matic
    Phil
  4. shplade
    shplade What's a Dremel?
    10 Dec 2004
    :D
    I'll start a log as soon as i get a camera, which will be a little after christmas time.
    Any help with a name would be great because im stuck.
    You should see the log about a week or two after christmas when my next shipment of parts comes in.
    ta :)
  5. modsquad
    27 Feb 2004
    I wanted to get the BFG 6800Ultra and my Vantec PSU unit installed today..It did not happen. I have a busy week of real-world work ahead of me, so I will have to wait until next weekend. Perhaps that is best. By that time I should have my chrome stuff and will attempt to get it re-installed as well. A while back you may remember I installed innovatek's 5mm led plug in the res.
    After reading AC Aquaero VFD's manual it seems I can attach a LED to the unit and set it to become brighter/darker with the increasing temperature of the h20 loop (or blink on/off @ a given temp). What better place to put the LED than in the top-mounted reservoir's LED plug. That is pretty cool in my book.
    I wanted to get more done over last weekend, but.......
  6. kaotic504
    kaotic504 What's a Dremel?
    20 Jul 2004
    with all this stuff that you bought, your bankroll must be FAT! geez, i'm sooo jealous of all you guys.
  7. slame
    slame Pix, sonst glaub ich nix !
    13 Dec 2004
    Hi,
    no shame on AC .. :rolleyes:
    You simply mounted it wrong. :dremel:
    So ... how to mount it right ? You don´t have to use the metal bolts AC delivers. They are simply for emergency. First of all mount the aquagrafx with the plastic ones .. then mount the backplate and use the original bolts from the card with the backplate. How else should the bolts be fixed ??
    Got it ? Otherwise I try to shot some pics tomorrow.
    Cheers
    slame
  8. modsquad
    27 Feb 2004
    I got it.. AC should include instructions!! So the metal bolts AC gives you are not needed, and you should use the stock nvidia bolts. Measure them against the bolts Aqua-Computer supplies. The stock nvidia bolts are slightly longer. The "emergency" AC bolts are too short."How else should the bolts be fixed??" With the nuts and plastic washers Aqua-Computer also supplied. (you would think). I used longer metal bolts I had and the nuts/plastic washers AC gave me and then the plastic bolts for the other (8) mounting points. I am all set, but when you spend $100 for a H20 block you should not have to guess on how to install the unit. I still say Shame on AC.......
  9. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Slame is AC... :worried:
  10. slame
    13 Dec 2004
    psccchhht .. don´t tell anyone. :duh:
    just doing the shop for AC. I think they are right sitting on a manual by now. They simply thought it´s quite easy to install this block. :D sorry for the inconvenience caused.
  11. TheDon
    TheDon What's a Dremel?
    21 Oct 2003
    Run.... There is a spy among us...
    Welcome to the forums :)
  12. Shrapnill
    Shrapnill What's a Dremel?
    5 May 2002
    No offense Modsquad, but Im totally turned off following those red CCFLs in the front of the case. Its way over the top on the lighting in my book.
    Everything else looks amazing tho.
  13. modsquad
    27 Feb 2004
    You mean this shot
    Perhaps you are correct. It reminds me of a 1950's jukebox. The lighting for the front and the inside of the case are on separate switches and I did not plan on having either on all the time (only a few red leds will always be on). Thanks for the feedback..I will think about it...
  14. nissmo300
    nissmo300 What's a Dremel?
    19 Aug 2004
    I agree with Shrapnill, those lights mess it up. Great work so far :thumb:
  15. k3rnel
    k3rnel What's a Dremel?
    25 Nov 2004
  16. Fibbles
    Fibbles What's a Dremel?
    22 Apr 2004
    I think the lights look fine. If the modder likes them, then that's all that matters.
  17. Shrapnill
    5 May 2002
    Yes, exactly.
    As Puggy said, its all up to you, but I'm just giving honest feedback. I see what youre sayin about looking like an old jukebox (with those bubble lights)- to me it just reveals too much of the interior in an area that isnt made to show off. The LL V1000 suffers this when modding no matter what lighting you choose, but set up against the front panel like that just seems a bit gawdy to me.
    Everything else looks absolutely hot tho.
    I would just custom fab an oval of that sexy red plexi for that AC block to get rid of that ugly lit thing on the side.
  18. Fibbles
    22 Apr 2004
    I happen to think the lights look rather snazzy, especially in the dark, but I see what you're saying about the case, the holes all over the front panel give and inkling to what's inside already. After staring at it lit, it does seem on to show off the top part of the drive bay a bit too much in an unflattering way.
    When you say "area that isn't made to show off", are you referring to the drive cage area, or just the front end specifically?
    On the topc if "honest critisism", I'm not a fan of the side panel, but that's because the design isn't something I like or think is cool. Of course though, if I put a hippopotamus on mine, I probably wouldn't get many nice comments.
  19. Shrapnill
    5 May 2002
    Lighting the front is fine, but the drive cage to me isnt something I like attention on. Windows and lights are on the mobo/components because theyre interesting and tidy (if done properly). The backlit effect of the drive bays is just plain fugly in my book.
  20. modsquad
    27 Feb 2004
    I am not sure if you have seen the "drive cage" area of my machine.
    I do want some attention (lighting) on this area. Perhaps just a single 4" CCFL mounted above the laser etch.We will see. The real reason I posted the "lighting pictures" was to say I was unhappy with the orange (I want red) color. That was the reason the pictures are soo dark. Also, I don't plan to have ANY CCFL's on all the time. I want to be able to hit a switch and get a little "shock-factor". I have two units set up. One for the front lighting and another for the interrior of the case. The reservoir will have a red led and two more red leds mounted on the bottom of the case. Those will be the only lights that will be on all the time. Once again thanks for your feedback..and perhaps you are correct (2) 12" CCFL may be "too much"..
