Project Black Narcissus: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 28 Jun 2004.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Thanks. I like it as well. I will try to finish-up the window Sunday, but I won't promise..SuperBowl__=DRUNK........
  2. Firehed
    15 Feb 2004
    Looks awesome as usual! I hope you're not planning to fill the loop with bottled water though... Just got back from winter camping (we were all in shorts and a t-shirt it was so warm!) so no work started on my case :( That window is looking spectacular.
  3. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    Looking great. Can't wait to see it finished. :rock:
  4. modsquad
    27 Feb 2004
    I would think bottled H20 would be fine. Water cooling guys get nervous about the science of purified H20:
    distillation
    deionization
    reverse osmosis
    Bottom line you want H20 with very low levels of minerals, salts and calcified elements. That is why tap H20 is a no-no...
  5. Firehed
    15 Feb 2004
    Yeah, I've just heard that bottled isn't much better as far as minerals than tapwater. Distilled is only a buck or so for a gallon and probably a better bet. Still, if bottled doesn't work then just drain it and refill it with something else.
  6. modsquad
    27 Feb 2004
    I never heard that. I would think Big Brother regulates such things (EPA,FDA).
  7. Firehed
    15 Feb 2004
    I would think so too, I just remember reading something like that. Maybe it was on the electrical conductivity and not the purity. Actually, more than likely that was it. However I think some bottled water is straight from the spring (I belive Poland Spring brand is... I *should* know as it's from my state but TBH I'm not sure)
  8. modsquad
    27 Feb 2004
    Yes, bottled spring water or mineral water would be a bad thing. Perhaps even worse that tap water.
  9. modsquad
    27 Feb 2004
  10. angelorus2000
    angelorus2000 What's a Dremel?
    14 Nov 2003
    I love that the tubes go into the floor, with that red acrilic
    That window looks good
  11. modsquad
    27 Feb 2004
    Thanks. The laser etch mod (drilling/tapping) was a Kamikaze mission. That etch can't be replaced, if something bad happened (aka acrylic crack) it would have been the END.
    http://www.xport1.com/ laser etched the "devil-boy" (as well as the skulls on my front panel) and as been closed for about 3 months. I am unsure if they will reopen. Shame, they did/do wonderful work. I can only hope they get back on there feet.
  12. crimandevil
    crimandevil What's a Dremel?
    30 Jun 2004
    As do I, I was hoping to get soem work done by them since I first read your thread but they've been down for a pretty long time. :(
    Anyone know of a similar place that does great work at an easy price?
    Your case is looking great and I'm glad to see that the window didn't crack. :)
  13. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    It must have been scary indeed to drill some holes in it. I don't think there are many places where they make etches like that. I know only one shop in the Netherlands where they do it. I'm thinking about getting an etch too. I want to use a drawing I'm gonna make for my project. I saw you used one from Deviant Art. I've had an account there myself a year ago.
    I will have to come up with a good idea for that drawing. Drawing it will not be a problem, but all the drawings I have are from birds and flowers. Like this one.
    You're MOD is a great inspiration for me modsquad.
  14. -=tHaRgOr=-
    -=tHaRgOr=- What's a Dremel?
    21 Jan 2005
    wow
    hi modsquad,
    I´m speechless:jawdrop:...this project is amazing. Can´t wait when you finished it.
    This is one of the best moded cases I ever seen....you have my respect...
    and like Franklin said
    this is for me too.
    Goodluck..cu thargor
  15. modsquad
    27 Feb 2004
    The Maltese Falcon (damn,that is a GREAT project name!!).. If my "little mod" was inspiration for your (kick-ass) machine, you have made my day!! That is high praise indeed Franklin, you have one of the TOP-5 projects on this site. Go Forth and Modify....................................................................................
  16. modsquad
    27 Feb 2004
    :blush: I am justa guy with a Dremel. Thanks!!!!
  17. Firehed
    15 Feb 2004
    damn, so close. I need the inverse of that... that's BSP male to NPT female, I need NPT make to BSP female (or just to 8mmOD). SO close...
    ah well, my hacksawed barbs should work well enough. On a random note... I'm stunned how heavy my new PSU is... heavier than my fanless by at least a pound. Even the power cable is heavier guage than any I've seen before. I guess an antec made for servers was a good choice :D
  18. Derelict
    Derelict What's a Dremel?
    29 Jan 2005
    Gawd, this project looks too pretty :D Keep up the fantastic work! :rock:
  19. mafia11671
    mafia11671 What's a Dremel?
    7 Feb 2005
    Your case is looking great, really clean! I am kinda new to watercooling and was wondering, do you think the hoses would work a little better with the 90d coming out of the GPU block and a straight fitting coming out of the pump? Just thought it would take a little bit of the bend out of the hose.
    Looking great, keep up the good work!.... :eeek:
    mafia
  20. Uber_K
    Uber_K What's a Dremel?
    7 Feb 2005
    Holy crap... that's a lot of pages! Very good looking mod, by the way. A very clean, professional look, I like it. Keep it up.
