Project Black Narcissus: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 28 Jun 2004.
  1. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    thats sweet, and its the 1300th post in your thread! Congratz! :thumb: :jawdrop:
  2. shplade
    shplade What's a Dremel?
    10 Dec 2004
    I reckon that if you covered the remaining PCI slot cover plates with the same red acrylic cover, it would really set the back of the case off, and make the whole thing look more complete.
  3. Firehed
    15 Feb 2004
    Cool! Very good idea with the red acrylic. IMO it might have looked better to put another bolt where the probe is and then put the probe dead-center between them. Just a thought.
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Next up make a chrome bolt for the Innovatek temp probe. I used a chrome 3mm LED clip.
    Threaded the LED clip with a M4 tap and then Dremeled off all the back section of the clip.
    so you basically have a chrome bolt.
    Screw it on the probe, finished..
    Thats it for today.. :thumb:
  5. modsquad
    27 Feb 2004
    That is the plan shplade. It's on the to-do-list.. GOD is in the details.. TIME. believe it or not, I spent about 5-6 hours for that little mod..drilling/filing/tapping/polishing acrylic. The Aqua-Computer Aquaero VFD is on the horizon, I can see it through the fog & mist :hehe:
  6. modsquad
    27 Feb 2004
    I have to disagree this time Mr. Firehed. When I do the other blank PCI covers with two hexhead-bolts each, it will all look uniform. The sound card will take one of those PCI slots, not sure which one..
  7. Firehed
    15 Feb 2004
    Good point you make there... didn't realize you were doing the others. I just thought it looked a bit odd with the piece sticking out further than the bolt.
  8. Franklin
    Franklin What's a Dremel?
    24 Oct 2004
    You keep amazing me with your level of details and new ideas modsquad. I like the idea of the ambient temp measurement a lot. Temps of the system don't mean much if you don't compare it to the temp from the room.
  9. scifi3018
    scifi3018 Minimodder
    6 Feb 2005
    That is a-freakin-mazin this is an awesome job, and i have bn subscibed for a while... but wow.
    I cant wait to see the finished product.
  10. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    finally updates... I don`t have any words for this case.. I tlook well in every little detail... very very very nice !!!
  11. modsquad
    27 Feb 2004
    That is the reason this project is taking so long to complete. Honestly I did not plan on doing the other PCI slot covers, but I like the look and will do the rest.
    No Aqua-Computer Aquaero display this weekend. Just not enough time. I still have one more temp probe to sleeve/shrink. The flat probe will be used to monitor the Eheim 1046 pump's temperature. The other, case temp..
  12. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Sems you gona get al AC gear in that coolingsystem of yours :thumb:
    Secondly, what are these screw sheelds cald?, they look fantastic! I have seen it on other builds and it never gets wrong :thumb:
    Thanks!
  13. modsquad
    27 Feb 2004
    I am a little lost here, to be honest. Are you asking about the LED clips? They are some sort of pot-metal, chrome plated. Available here:
    http://www.frozencpu.com/ele-25.html
    Question answered Razor_cut?
  14. modsquad
    27 Feb 2004
    Thanks Franklin. I hope it will work, the probe is really designed to measure the H20 temperature of a Innovatek Hard drive cooler. I will also use one to check a "case" temp, so I should have some idea of temperature inside/outside the case.
  15. Razor_cut
    12 Mar 2004
    Jupp, thanks!
    I was hoping u had find it in a local metal stor, with different sizes and so. But that will do. Thanks!
  16. D3mon_Hunt3r
    D3mon_Hunt3r What's a Dremel?
    31 Mar 2005
    I can't add much more. I have watched all the project from the begining and it is amazing... :clap: :clap: I have a V2000B which i'm planning to do some modding, it will have Prommy and WC, As soon as i got the case i started of a red theme just like yours but the red acrylic details are just astonishing :jawdrop: . Excelent work keep it up. Waiting for more updates...
    PS: You are a :dremel: Master :thumb:
  17. monkeyharris
    monkeyharris What's a Dremel?
    14 Apr 2004
    just a quick question on the ambient temp probe, wont the fact that it is at the top of the case, above the oulet for the psu on the outside, and also all the hot air that has risen on the inside of the case, affect the accuracy of its reading quite a bit? i.e. make it read higher than ambient really is.
    nice work on all the rest tho! looks top! :)
  18. Firehed
    15 Feb 2004
    Probably not by enough for it to be significant. Heat dissipates into the air pretty quickly, and it's a good 14" (I'm guessing) from the PSU's exhaust fan, not the two or so where you can notice it being warmer.
  19. modsquad
    27 Feb 2004
    I would agree with Mr.Firehed. I think the probe is far enough away from the heat generated by the PSU. That should not be a problem..
    Just a heads-up:
    I may not have time for the weekly update this go-around. I am slated to began painting BN's sister project Soylent Green over the weekend.
    http://forums.bit-tech.net/showthread.php?t=72728
  20. Firehed
    15 Feb 2004
    hey, if you're working on a project, it's all good :D
