Case Mod - In Progress Project: Black Oil - 2nd Dec - Switches Installed
Discussion in 'Project Logs' started by Dark Sun, 4 Nov 2008.
  1. Dark Sun
    Dark Sun What's a Dremel?
    4 Nov 2008
    Welcome to Project: Black Oil
    A very warm welcome.
    I thought I would add my work log to the forum.
    I've been away from the PC scene for about 4 years due to other commitments. Now I've decided to build a new water cooled PC for gaming and to get in touch with my creative side. I've been blown away by some of the other mods out there.
    My aspiration is to produce a sleek, sophisticated, and high quality design. I guess my inspiration is to move away from bright UV tubes and dazzling lights, which I have used in projects in the past. I will be using three core colours - black, metallic silver, and a splash of blue - in its design. While some may think, "oh, another Lian Li mod", I hope I can show you that this mod will be unique, stylish, and deserve your appraisal through fine workmanship.
    I chose the Lian Li PC-A05B mainly because its much smaller and compact than other cases. It fits snugly on its glass stand and doesn't dominate the room too much. Fortunately, the case shares the same length and depth as its larger brothers, so there is a good amount of room to work with if your creative and use the space efficiently. If you wanted to install multiple hard drives combined with an SLI/Crossfire GPU configuration, and extensive water cooling, then this case isn't for you. However, if like me, you just want a simple rig with one HD and a graphics card then its more than suitable.
    Here is the stock case from the Lian Li website
    This project will be ongoing for as long as it takes. I won't be rushing it for a quick result. I will update this thread each time I make some significant additions/mods.
    In the mean time, any tips or advice would be warmly received!
    Thanks for looking!
    Part 1: Case Fabrication
    Summary:
    Internal powder coating in matt black - completed
    Custom window - completed
    2X120 radiator cut in top panel - completed
    HD cage removed - completed
    Chassis cable sleeved - completed
    Lian Li Drive Bay Bezel fitted - completed
    The case stripped down to its bare bones
    The stock pci slots have gone and I will install some custom ones instead
    I'm thinking about installing some custom switches
    All the internals are powder coated in matt black and the HD cage was removed. It's not really necessary for one HD and it restricts the airflow
    Rear powder coated black and fan mesh removed
    2X120mm fan cut
    A nice little window mod. I wanted to keep the drive bays hidden when looking from the side
  2. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    Dude, I can't wait, I'd love to watercool one of these cases myself, they look really nice and fun to work with. Definitely looking out for this!
    Looking great so far, the colour is excellent and real clean rad' cut!
  3. badje
    badje boni
    30 Oct 2006
    Always when I see topic names like this, I think: 'aaah a lian li mod.'
    I don't no why I think that.
    Anyway Good luck with it. Looking good already.
    It's a small case isn't it?
  4. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    Nice start and good choice :clap: for the lian-li case i wait the to see the next update :thumb:
  5. Dark Sun
    4 Nov 2008
    Yep, it's a small case, which I think pushes creativity and innovation. Some may see it differently though.
    New update! 04/11/08
  6. The boy 4rm oz
    10 Apr 2008
    Very clean radiator cut and window. Looking great so far, nice start. I will be watching this.
  7. acey
    acey What's a Dremel?
    6 Mar 2006
    Nice cut and the brushed metal panels and those fans looks good.
  8. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    Excellent case was looking at the before i built my system, i decided on a cheaper one and went micro atx. definitely watching this not only for the eye candy but for ideas. did you powder coat it your self or take it some where? if so how much did it run you?
  9. Dark Sun
    4 Nov 2008
    I live in the UK, so I guess I can't help you much. It cost a fair bit, but I think it's worth it, and it looks beautiful. The case itself (Lian Li PC-A05B) is pretty cheap compared to some of the high-end cases out there, so I guess it works out a similar cost with the powder coating. That's how I looked at it anyway.
    I think you can get it done at any kind of custom paint shop though. Just strip down the parts and let them know what you want them to do. I got the internals and the rear powder coated.
  10. Dark Sun
    4 Nov 2008
    I received the HD enclosure today.
    Box is nothing special really. However, the box isn't going in the case ; )
    The HD enclosure is made of high quality aluminium. It feels sturdy and well built.
    Shiny copper on the inside!
    Nothing too whacky or cheesy.
  11. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    But seriously, those letters/front will have to go, right?
  12. Dark Sun
    4 Nov 2008
    I don't find anything particularly wrong with the letters.
  13. Coldon
    Coldon What's a Dremel?
    14 Oct 2006
    a razor blade and a lot of patience maybe?
  14. ComputerKing
    8 Sep 2006
    Very Very Professional paint job i can see. looks very dam promising :) I must keep my eye on this project . keep it going buddy.
  15. wbdog206
    wbdog206 not me
    15 Jan 2007
    nice start, the powder coating looks great.
    nice hard drive case.
    can't wait to see more!
  16. The boy 4rm oz
    10 Apr 2008
    Love the HDD enclosure.
  17. Dark Sun
    4 Nov 2008
    Just a little update this evening. I'm still waiting for some significant items to arrive.
    I got some more heatshrink and braid in the post so I set to work sleeving the rest of the fans.
    A shoe box filled with random bits and pieces
    My little work area on my desk
    My trusty heat gun
    A nice result. Yate's slim fans are quality.
    Some noiseblocker fans. They are nice but I'm not sure if I will use them. The Yate's slim fans take up less room and might suit my theme better.
    That's it for now. I hope I have a new update at the end of the week.
  18. Nolimited
    12 May 2008
    nice work done on the cables and clean :clap:
  19. minilogoman
    minilogoman Wannabe Modder
    18 Nov 2008
    i like the black look to it, looks real good hope it makes the front page because it has alot of potential
  20. jhanlon303
    7 Sep 2006
    Sorry for not commenting before. This is nice. I have 2 Lian-LIs and watch all the Lian-Li threads.
    The YL fans are a good choice for quiet. A lot of the forum members recommend them.
    john
