Project: Black Pearl, The Curse. [08.11]
Discussion in 'Project Logs' started by Klekkus, 5 Nov 2005.
  1. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    This is my Chieftec case i started moding
    A big thanks to my sponsors :thumb:
    SHG.NO
    They sponsed me with 700 NOK discount :D (700 NOK=107.1253 USD)
    This is the list with things I ordered:
    - 4x Sharkoon Fan Grill Blade 120mm
    - 4x Sharkoon Fan Grill Blade 80mm
    - Revoltec Fan-Adapter 80-120mm
    - 6x Revoltec Thumbscrews Silver, (4x) RZ006
    - Sharkoon Laser led's blue
    - Zalman VF700-CU-LED
    - 2x Revoltec 80mm fan, dark blue RL021
    Vendur.no
    They sponsed my with one free silenX 120mm fan with blu leds :D
    3dfxcool.no
    They sponsed me with:
    2x Y-spilt for my fans
    8x Fan screws
    1x Avance Frontpanel
    hobbyelektronikk.no
    20x Ressistors
    4x Uv leds on 8000mcd (5mm)
    2x Blue leds (5mm)
    HCS.no
    Akasa PAX sound proof mat kit
    2x Akasa standard 80mm fangrills
    Exim AS
    2 Realy nice fake Bulgin switches without light
    From before i have
    - 2x 80mm Revoltec fans with dark blue leds (21dB)
    - 2x 120mm Mist fans with red leds (16 dB)
    - 120mm MIST fan with blue leds (16dB)
    - 90cm UV blue ATA cable
    - 45cm UV blue ATA cable
    - 45cm UV blue FLOPPY cable
    - 4x Sunbeam UV/Blacklight katodes
    - Sound Control and 2 analog fan controls in a lian li 5.25
    - Cooler Master Aerogate III fan controler in Black
    The hardware thats going into the case: :eyebrow:
    - ASRock 939A8X-M
    - AMD 64 "Venice" 3000+ s 939 (1.8 GHz @ 2.45 GHz)
    - Thermaltake Golf325 (with a MIST 120mm fan (blue leds, on a 80-120mm fan adapter)
    - 2x 512 mb Kingston Hyper X (2-3-2-6)
    - 2x 160 GB WD ATA 133 (Mabye a WD 300GB SATA after my birthday (9 march or to chrismas)
    - Sony D23A
    - ASUS N6600GT/TD
    - MIST 500W
    Sorry my English is'nt so good. I'l hope you understand it all.
    I started this project because I was so god damn sick of my old Logisys Dracula the "chrome" is plastic :grr: .
    So bad on track, I wanted to have a custom case. With my of design and ideas, so I started drawing to design to the side window. I used one religion class at school, thats one good used religion class.
    Here you can discuss my worklog ;)
  2. Klekkus
    5 Nov 2005
    Update 15.10
    I ended up with this design, I'm almost proud of it. because I haven't seen nobody else with the same window.
    Here I cuted it with my :dremel: :rock:
    The design on the paper and the side panel are not the same because it's easyer to draw it with no limits, than to draw it one the side panel. As you can see the cut around the handle isn't perfect, it's because I hadn't the hadle in my hand when i started to draw and cut. It was when I was working on engineering workshop for a week.
    As you can see here the cut isnt perfect because this was my first time with a dremel, but a was pleased with the result. Is this a OK result to be my first time?
    I think there wil be much work to make all the marks disapear, I'm thinking al the cuts thats over the edge.
    Update 18.10
    Here i cuted a fanhole but the holes diden't match :duh: I could make one new hole but I didn't want to, i got the idea of making a laxan platen and driling a fanhole in it from Pain193 project (on the link there you can see the fanholes he made to his project)
    So I stared making my own fan oles to my project of lexan, I got some free lexan, that i used.
    Blue Lightning
    Here i cuted a big hole.
    Update 30.10
    Here i made a fan hole of lexan :thumb:
    Here i made one more, but i wasnt straight :wallbash: but it's good enough for me.
    Here i made one new fan hole, the last one did broke :duh:
    Here i cuted a hole in the back for a dual fanhole
    Here I started making the dual fanhole.
    Edit:
  3. Klekkus
    5 Nov 2005
    Update 25.10
    Here is the dual fanhole finish
    And it did fit perfect :thumb:
    I tested with some old fans
    CloseUp picture :naughty:
    Edit:
  4. Klekkus
    5 Nov 2005
    Update 01.11
    Here I'm cuting the plexi :p
    Then it was almost finish, but I have to straight it up :eeek:
    Here i'm cuting to make it fit with the lock on the door
    The back side
    Look, isnt that nice? :naughty:
    Edit:
  5. Klekkus
    5 Nov 2005
    Update 05.11
    This was the motive i drawed in paint :dremel:
    Here i'm marking the cuting
    It took very long time
    Here i drawed the patthern :p it's not 100% like it's on the paper but the fan took so much space som i had to modfy it.
    My tools
    This is my bench and my light
    One patthern cuted
    Here i fixed the edge
    It isnt finish no, I'm gonna fix it tomorrow :rock:
    Look at me after cutting the patthern :eeek:
    Edit:
  6. infered101
    infered101 Minimodder
    30 Oct 2004
    Nice windows good designs. Just to give you a heads up you should probally wear a mask when cutting stuff out with a dremel. The dust isnt the best stuff to get in your lungs or for that matter anywhere inside yuor body. I use to not where a mask and ended up spending 30 minutes after cutting anything trying to clean out my nose and eyes of all the metal particles. Anyways good original designs and keep up the work.
    Oh and if you cant read some of this(seeing as your from norway and your english is ok but not perfect(no ones is) just use bablefish to translate it all.
  7. Fly
    Fly inter arma silent leges
    31 Aug 2001
    coming along nicely dude. :)
  8. Klekkus
    5 Nov 2005
    Thank you. god you like the design :clap:
    I didnt find a mask, it was gone.
    I used gogles for a litle while, but the gogles was so dark that I coudnt use it :waah: .
    BTW I used only 10 minutes cleaning my face and eyes, but the worst was the dust in the eyes
    I wrote this 03:00 last night, some i'm gonna se if something i wrong there and fix it ;)
    BTW I have no probleem with reading English, it's harder to write ;)
    Thank you :D
  9. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Looking great, nice to see a fellow Chieftec modder...:D
  10. Klekkus
    5 Nov 2005
    Thank you :rock:
    I read you chieftec project and tryed to get some ideas, I got one. witch sanding paper i shoud use :hehe:
    Im gonna put some lexan in the front (3mm), and the side and top window are gonna be mirror/black plexi (5mm)
    Im gonne paint the case black :thumb:
    Here's a picture of the lexan and the front
    I'm gonna have lexan in the door and in front of the HDD's, it's gonna be 2 80mm fans there with ble leds.
    This is the fan grills, it's gonna be 8 of them in the whole case :cooldude: 4x80mm and 4x120mm.
    It's gonna be 2 80mm fans in the front (ble leds), It's gonna be 2 80mm fans in the back (ble leds), 2x120mm fans in the sidedoor in the plexi, one on the CPU cooler (blue leds) and one 120mm in the top window in the center of the plexi. Im gonna use fan grills on all of them, Etch 80mm grill costs 30 NOK (4.59 USD or 3.85 EUR) and Etch 120mm grill costs 50 NOK (7.65 USD or 6.4 EUR). I get 50% on them al, beacous www.shg.no is my sponsor. I can make a list of al things i ordered :D
    Edit:
    Who is in the Chieftec Crew? Can i join? :D
  11. Leeum
    16 Feb 2004
    Yup, 'cors you can! :rock:
  12. Klekkus
    5 Nov 2005
    Where do you sign up? :duh:
    :dremel: :rock:
  13. Klekkus
    5 Nov 2005
    Update 06.11
    Here you see how my case is now :eeek: :worried: :confused:
    One more picture
    I found this tool i daddys basement, what do you cal it on english? I didnt evwn know that we had it. :idea:
    Thanks to NaThro for teling me its a Rivet Gun.
    A in action picture :rock:
    Here you can see it after the cutting
    Look at the nice pice thats left, can i use it to some thing? :dremel:
    This is how it's gonna look.
    Here you can se the cuts, i wil fix it strate tomorrow or later.
    One more.
    So what do you think?
  14. Klekkus
    5 Nov 2005
    Update 07.11
    Then I got me one kick ass logo to this project :thumb:
    Great logo made by Glisevask.
    This picture where made by Caliber :D
  15. Klekkus
    5 Nov 2005
    Update 06.11 and 07.11
    2 Updates and no replies :waah:
  16. Leeum
    16 Feb 2004
    Looking great! :)
  17. Klekkus
    5 Nov 2005
    Thanks, i'm hoping to get finish with the front tomorrow.
  18. Klekkus
    5 Nov 2005
    Update 09.10
    Yesterday i tryed to make my logo.
    Here are all the pictures ;)
    This is everyting I used on the first engraving
    The result of the first logo engraving
    This is try nummber 2 on the engraving, there was al the tools i used
    Here it was finish, only had to clean it
    Here the engraving is done :cooldude: , what do you think?
    Here the lexan with the logo engraving over my front
    Bye bye old front
    Here I had cuttet it
    This i how it was
    Edit:
  19. Klekkus
    5 Nov 2005
    Today i got a package
    The boks
    Here is the stuff :D
    4x Sharkoon Fan Grill "Blade" 80mm
    6x Revoltec Thumbscrews Silver, 4 stk RZ006
    1x Sharkoon Laser LEDs, Blue
    1x Zalman VF700-Cu-LED, Cobber VGA Cooler
    2x Revoltec 80x80 Fan, Dark Blue RL021
    1x Revoltec Fan-Adapter 80-120mm
    1x RJ45 T.Pair 30 m uskærmet
    1x RJ45 T.Pair 15 m uskærmet
    1x Revoltec Cold Cathode Twin-Set, Blue
    1x Sharkoon Fan Grill "Biohazard"
    1x Revoltec Thumbscrews Gold, 4 stk RZ009
    1x Sharkoon 80x80mm Fan, UV LED, Green
    1x Floppy Cable, 45cm, Round, Black
    1x Floppydrive Alps 3.5", Black
    1x KOSS SB45 Headset M/MIC[/quote]
    Edit:
    A BIG!! thanks to
    www.shg.no
    who sponsed me :D
  20. Klekkus
    5 Nov 2005
    Any comments on the last update?
