Some realy nice switches has arrived a for a few days ago I big thanks to Exim AS Here are some pitures of the swithes: What do you think about the switches? I'm gonna use it for the DVD and for a reset switch. I'll work out some drawings of the front later Any comments? Comment tread
Update 26.02 Today i finaly got something done on the project Drilled holes for the feets Here you can see how high it is. Then i cuted the screws Polished the switches Here you can see the differense on a polshed foot and one unpolished But the camera tricks you, looks much better in real life This is how it look atm, and what i got done today. This is how it's gonna look when it's finish Any comments? Comment tread
Update 16.03 The finish on the drive bays after sanding, ramaning rubbing and polishing One more Got some unused Sharkoon katodes from a friend Any comments? Discussion tread
Yes i want;p Looks okay the last one, i would have sanded and used some polishing on the drive bay's and the mobo-shield Thinks that looks wicked when its polished^^ KUTGW! Øyvind
Cool, somebody who wants to comment Thanks, well I'm gonna use some rubbing compound before polishing with autosol. The rubbing "eliminates" the scratches I only wish steel was as easy to polish as aluminium, but I'm hoping on some good ressults
Thanks, I'm hoping on some good temps when I'm finish with the project The bottom window will be finished tomorrow And I'll polish the feet's too *droll*
HDD case, with 1* 120mm fan HDD case, with 2* 80mm fans Most likely I'll go for the HDD case with 2* 80mm fans. Any comments why I should take the 2* 80mm insetad of the 1* 120mm? Comments?
SketchUp Drawings Under Inside, the "Black Box" are a Singel Danger Den Heatcore Radiator The front Comments?
Update 14.04 The backside, placement #1 of the switch Placement #2 of the switch The switch, I made it myself The inside I moded the PSU a little, only remaning some mesh on the backside Some more of the inside The front I was gonna sleeve a fann, but one of the pins are broke. So I had to do some soldering. But I diden't go far, i couldn't find the solderingbolt I diden't get farther on the soldering of the GPU cooler I managed to brake one pin one a fan, whel then the 32dB Zalamn fan had to go Then i sleeved one fan Any commetns? Post them here!
