Case Mod - In Progress Project Black Rain: RIP 2008
Discussion in 'Project Logs' started by modsquad, 14 Sep 2006.
What to do...
Poll closed 30 Jun 2007.
  1. Finish the machine entirely:
    87 vote(s)
    91.6%
  2. Finish the case mods only:
    3 vote(s)
    3.2%
  3. Just go away:
    5 vote(s)
    5.3%
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Thanks Greeny, all this stuff is hit and miss.. In my project logs I like to speak of the mistakes as well as the cool-stuff.. Things never ever go ultra-smooth..
    highs and lows..and-thus..da good and bad..
    I willl "bounce-back" with something for the MB.. rest-assured..
    @G42: The only "stuff" I am willing to add to the H20 in my loop is AC Fluid: My advise, stay-away from the color-dye-crap..It's just that.. :thumb:
  2. modsquad
    27 Feb 2004
    Thanks Capt.. It was not than I failed to get the cover to fit, but instead it covered too-much... Ended up looking very-antiseptic..
    (IMHO) H20-blocks and tubing are SEXY... I want to see some of that stuff and cover-over the ugly-MB-bits..
    So, it's a matter of design and not dimension...
  3. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Hmm, I saw something a Long time ago, it was a guide on modding chrome spiked nuts (Basically, a stud/spike, with a hole in the bottom, then threaded.) That could have the possiblity to look amazing. Maybe securing the mobo cover.
    Then again, I know you know what you're doing. This project log, along with the previous ones, show. Keep up the good work.
  4. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Exactly. I used the same process to figure out what it is I want to cover and what I cannot due to spacing, or do not want to cover for aesthetic reasons. It may be as simple as starting out with a photo of the motherboard.
    http://www.almico.com/forummotherboards.php?man=264
    The problem is that it's a very tight mix of design work and dimensioning.
  5. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Hm what about actually using oil?
  6. Dustin
    Dustin What's a Dremel?
    22 Apr 2006
    Great start,cant immage what it would look like in the end.
    Good luck!
  7. RonaldoR9
    RonaldoR9 What's a Dremel?
    17 Dec 2006
    love the tygon tubing why not use 1/2 inch tubing better cooling ???
  8. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    O Fo Sho im going to buy myself a shark , and put in my basement with all my babes :>
    Looking foward to seeign it finshed ;)
  9. RonaldoR9
    17 Dec 2006
    _______________
    I dont get it (lol)
  10. modsquad
    27 Feb 2004
    True-enough.. I started out trying to cover everything and just ended up with a "box".. also only used one material (Alu)..
    Next go-around will be different.. I have a ebayed Asus M2N-SLI Deluxe for mockup, so it is justa matter of a design I like... Hopefully I have learned from my mistakes. I think instead of one cover the answer maybe two-or three covering specific areas of the MB. It will not be sheet-Alu this time either..I got an idea for that as well..
    @ RR9: bigbore VS smallbore, the question for the ages.. For me I like the look of the SB gear, it's Ezer to design with and I would never use anything other than compression fittings for H20-cooling. I have yet to see them available in a size larger than the 11mmOD I will be using..
  11. alejo
    alejo What's a Dremel?
    4 Nov 2006
    I have to agree there. I just bought some compression fittings along with 11mm/8mm Tygon and I'm liking it better than AC 8/6mm p&c fittings. They are a little bit on the hard side though to screw down (the nut that is.)
    Cheers on another excellent looking mod.
  12. Mod_God
    Mod_God What's a Dremel?
    7 Dec 2006
    some killer work parts look pricey but nice
  13. RonaldoR9
    17 Dec 2006
    lol they beacuse they are vERY pricey
  14. modsquad
    27 Feb 2004
    True-enough RR9. Three months in, I have a good-amount of cash invested in this project. Lots of chrome-plate and biker parts from the elite-builders makes for a "pricey" machine.. Those guys are my inspiration.. My Hero's..
    Worth every-penny, in my book..
    With 12-25-06 inching closer, it's hard--but--I should have some time for an update later today (Saturday).. I have some "new-stuff" to show you as well as a idea for the MB wire-chase.. With any-luck the Dremel will-turn.. :dremel:
    Stay Tuned..
  15. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    I love the idea of running the lines through the IL, very nice and clean, great idea
  16. modsquad
    27 Feb 2004
    Thanks, I like it as-well.. I am all but sure no-one else has IL "water-wings"..!!
    I think U will like my MB wire-chase as well..
    BUT, first about (6) more beers..
    MS
  17. Guest-23315
    Guest-23315 Guest
    just one thing. I can't read german, but i was taught that the Anschluss or whatever was the union between Germany and Austria, that Hitler tried to make in the Second World War, before he was stopped by Moussolini. ( i know i can't spell)
  18. ShadowWings
    ShadowWings What's a Dremel?
    22 Jan 2006
    The sense "ohne anschlüsse" in German means "without connectors" in English
  19. Guest-23315
    Guest-23315 Guest
    ok. thanks.
  20. dirty_harry
    dirty_harry nothing beats german engineering
    1 Jul 2006
    :wallbash: :duh: :D :hehe: :waah: :jawdrop: :nono:
