Case Mod - In Progress Project Black Rain: RIP 2008
Discussion in 'Project Logs' started by modsquad, 14 Sep 2006.
What to do...
Poll closed 30 Jun 2007.
  1. Finish the machine entirely:
    87 vote(s)
    91.6%
  2. Finish the case mods only:
    3 vote(s)
    3.2%
  3. Just go away:
    5 vote(s)
    5.3%
  1. Glengarry
    Glengarry What's a Dremel?
    10 Nov 2006
    Well said.... I couldn't have put it better myself :)
  2. customh
    customh conflagration.
    22 Oct 2005
    Well now that I understand its gonna be in the tube, it looks good in there, NEEDS that spike imo. Looks good, keep it up!!
  3. Firehed
    15 Feb 2004
    Glad to see even more progress on this. The little spike on the vent seems to fit in nicely now that you've given us a good idea of how they'll come together - if anything, it might be a bit small. I like the look... it really fits in with everything else. Hopefully those grills won't be too restrictive to airflow :worried:
  4. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I have to agree with your assessment of the spike-size. Bigger is better. My first thought was to use Trotta spikes.
    these:
    problem I need (4) and have only (3)..They are the perfect size, hell.. I will have to order more!!
    The hole-size on the brass stuff is the same as a LL V1000, so should not be a problem..
    Sorry to say No progress to report. Did some real world stuff then played STALKer and drank (still-drinking) beer..
    CF4 in a few days!
  5. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    Even more spikes on this case... They are really amazing, but the small spike inside the blow hole is damn small... I agree with you, you need more big spike (and more free time to mod) :-]
  6. 2JSC
    2JSC What's a Dremel?
    14 Dec 2006
    I donno about the flat black on the grills though... with them sitting on the "polished looking" acrylic they look sort of bla.... But I'm loving the concept.
  7. modsquad
    27 Feb 2004
    Thanks 2J..
    the grills- I like contrasting shades of the same color (black in this case)..
    there should be a small update (CF4) in about 24hours.
  8. modsquad
    27 Feb 2004
    Small Update:
    Bit-tech's infrastructure update on 3/30/07 prevented me from my update. Today was my first chance since then.
    The dual 120mm radiator fits quite well:
    I want to start working on the side window for the case. Yes, there will be a small side window on the MB side of the case as well as the dual blow-holes for the radiator intake. Disclaimer: none is this is finished. we are just doing the rough-metal work at this point. everything will get cleaned-up and painted at a later date..
    Before that, I need a panel to bridge the gap between the MB and the lowered divider plate. The first thing was to cut the bottom edge of the MB:
    removing the rolled edge.
    ending up with:
    The window will allow a view of the Aqua-Computer acrylic aquatube. The material more of the ACRyan mesh. Cut to size:
    using my favorite new tool:
    a slot to allow the panel to slide into place:
    then C-strip (I use a lot of this stuff):
    installed (it gets bolted in under the MB):
    viewed for the other side with some light on the aquatubes:
    Tomorrow, I should have what will become the bezels for the side panels window. I will show you then.
    So, work should began on the panels window and blow-holes this weekend.
    Until then:
  9. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    that lit aquatube behind that mesh just looks amazing!
  10. customh
    22 Oct 2005
    Agreed, awesome work MS!!
  11. 2JSC
    14 Dec 2006
    o0o0o - Now that aquatube lite up white looks nice! Something kind eery about it.
  12. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    In the pictures the far edge of the Modders mesh doesn't have any c-strip. It probably will never be seen but I know you like the little "extra" finishing touches
  13. Fozzy
    25 Jan 2005
  14. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Just a question about the spikes on the rear aluminum fan: Do they come in UNF, where can I get them, and do they come in Chrome, black chrome, and/or brushed stainless/alu ?
    it's pretty much exactly what I need for a mod that I'm going to be starting soon. Lots of spikes.
  15. modsquad
    27 Feb 2004
    That 10mm c-strip gap is the point at which the MB tray is pop riveted to the I/O plate bracket. Could not run the c-strip past that point, but that region is still under construction.. :dremel:
    @ BoD: the same pike/spikes from Distinctive
    @2J: eerie sounds good to me.. In Fact, just what I want.. THanKs!
    waiting for Indian Larry to ship the other "shiny-parts" I ordered. Machine-time, I guess.. In the interim, I will endeavor to push-forward with my little project. The weekend will be my next-available free time..
    Until then...
  16. Mino
    Mino Ganzerli Mino
    5 Sep 2006
    The mesh is wonderful, but with the light that came from aquatube gives a fantastic mood to the pc... As usual, you're doing a good work, take your time :-]
  17. Fozzy
    25 Jan 2005
    I was actually talking about the vertical side of the mesh more towards the middle of the bottom compartment.
  18. modsquad
    27 Feb 2004
    Thanks, did not even think about that!
    UPS dropped off a few packages today..
    only purchased (1) would need another. I wanted to see what they look-like..
    1939 Ford (reproduction) tail light from JEGS
    The size (150mm long X 70mm high) is about right for a aquatube window-bezel..
    exploded view.. The tear-drop shape has made these 39' tail lights very popular with the Hot-Rod set since the 1950's. I think they may-work for my little project as well.. What do you guys think? (feedback)..!!
    second package, from IL
    more soon:
  19. itsjustacompaq
    7 Sep 2006
    wow, those are some QUALITY parts. im not sure what ur gonna use either of them for, but im excited to see! [​IMG]
  20. modsquad
    27 Feb 2004
    Will take care of that ASAP justa..
