Project: Black Zodiac | Update: 30. jan. 2007
Discussion in 'Project Logs' started by Mec, 21 Dec 2006.
  1. Mec
    Mec What's a Dremel?
    21 Dec 2006
    Continued bottom panel:
    I made a dust filter and fixed sunbeam feets.
    [​IMG] [​IMG] [​IMG] [​IMG]
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  2. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    im sorry, i think you misunderstood me. i meant it would be cooler if it were etched mirror. i know it is clear polycarbonate. just a suggestion for your next mod, as you seem to have etching nearly perfected!
  3. Mec
    21 Dec 2006
    ok :D
    thanks :thumb:
  4. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    This is coming along very nicely. Good job with all of the engraving so far. I have a question though, could you possibly describe how you made those LED stick things? Thanks a lot.
  5. Mec
    21 Dec 2006
    Hi. I made this from printed electric circuit panel. I graved the circuit, but you can buy a special fluid to eat the brass from the panel. Check this: http://www.pcbfab.com/
    Look at this:
    On first, black is brass, yellow is bakelite.
    Some macro pics (I've got a new camera yee :) )
    soldering
    good enough
    blue led
    Resistor depends on the type of leds, I used hi-bright blue leds with 100 ohm resistors, and I connected this to 5V.
  6. Mec
    21 Dec 2006
    News: back io panel is ready :)
    I fixed this into the back polycarbonate.
  7. Mec
    21 Dec 2006
    All gravings are ready, so I made the Mobo's place. I used M4 screws to fix the motherboard.
  8. Mec
    21 Dec 2006
    wood style sticker:
    [​IMG] [​IMG]
    Front USB connector:
  9. Mec
    21 Dec 2006
    Front panel is ready. I fixed alu sheets with epoxy.
    Light test:
    I changed psu fan, I bought a Noctua NFS121200 ultra silent fan, and I removed the fan grill to reduce noise:
  10. Mec
    21 Dec 2006
    I've got a Scythe Kamakiri cooler from my sponsor. It's good, but not quiet enough. I changed the original scythe fan with Noctua NF-R8.
    I made a little upgrade, I bought new VGA.
    My current config:
    AMD 2200+ @ 200*11 :) @ 1,92V >:)
    Abit NF7 2.0 SL
    Hynix 2x512/400 DDR
    Asus GeForce 6800
    MAXTOR 80 GB sata
    Pioneer 111d DVD-RW
    Black mobile rack with 3 fan
    The original VGA fan was tooooo loud, so I bought a silent Accelero X1. It was good, but there is not enough place in the case. I cutted 8mm from the blower.
  11. Bluefan
    Bluefan test 123
    25 Feb 2005
    That front-panel just rocks :jawdrop: :jawdrop:
  12. Mec
    21 Dec 2006
    fanduct -8mm :thumb:
    I bought new vga, but this have an external power, so I made new power cable for it.
  13. Mec
    21 Dec 2006
    The case is ready, these are final pics. I want to make 1 more thing, a front panel door to hide black dvd and rack.
  14. Mec
    21 Dec 2006
  15. Mec
    21 Dec 2006
  16. Mec
    21 Dec 2006
  17. itsjustacompaq
    7 Sep 2006
  18. RonaldoR9
    RonaldoR9 What's a Dremel?
    17 Dec 2006
    very nice i like the ethcing in the glass reminds me alot of the house in the movie
  19. Bluefan
    Bluefan test 123
    25 Feb 2005
    WOW, that's one impressive case!
    That plexi just looks great :thumb:
    Just curious, why the name Black Zodiac?
  20. Mec
    21 Dec 2006
    The group of ghost is the Black Zodiac. This case is a cage of ghosts, graved text from Bible keep them in. :)
