Project <<| Black3d |>> | Update 14/04/207 | Completed final pics
Discussion in 'Project Logs' started by kempez, 13 May 2006.
  1. kempez
    kempez modding again!
    4 Aug 2005
    Here are the Blue elbows and other bits I ordered. After a touch of paint of course ;)
    As always - comments welcome :)
  2. kempez
    4 Aug 2005
    Dodgy as hell dry test loop. Doesn't look too bad and at least it all fit in ;)
    Decided against the elbow in the pumps/res
    Put some plumbers tape on the barbs
    Then fitted them :)
    I'm going to see if I can cut this window today :)
  3. clocker
    clocker Shovel Ready
    21 Dec 2003
    You don't need plumber's tape (i.e.Teflon sealing tape) on barbs that use o-rings.
  4. kempez
    4 Aug 2005
    I know but I like to be on the safe side :)
  5. kempez
    4 Aug 2005
    Hope you like this update :)
    Masked up:
    Cut it out :D
    Sanded the window from the back and added a trim :)
    Don't think its too bad for my first go :)
  6. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Thats a great job Kempez; what kind of rivets did you use?
  7. Guest-23315
    Guest-23315 Guest
    perhaps some more filing to try and get it as straight as possible...?
    good though....
  8. olly_lewis
    olly_lewis What's a Dremel?
    19 May 2006
    Very good job for a first timer! Very smooth, even and fine sanding on the plates, very good in need but i cant see if the grains and grooves are even and in the same direction and not just all over the place.... perhaps a close picture?
  9. kempez
    4 Aug 2005
    @Markz - its straight but the screws are making it slightly bent. I will get a sharp knif and solve this :D
    I used some nice bolts that came with my AC grill :)
    Thanks guys. Just waiting for my swiftech block for my GPU :)
  10. Guest-23315
    Guest-23315 Guest
    its the black stuff round the side thats not straight i think....
  11. kempez
    4 Aug 2005
    Yeah thats right the black stuff is being pushed out by the screws.
    I'll try to cut it :)
  12. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Just loose it.......Take a black filtpen and go round the edges to make them black. That should do it...... :thumb:
  13. Guest-23315
    Guest-23315 Guest
    that would work-
  14. kempez
    4 Aug 2005
    I'm going to take a look at it and see if it would be ok to leave bare. I do have a feeling that it may need that rubber surround though I got it fairly smooth :)
  15. kempez
    4 Aug 2005
    Hey guys thanks :)
    Last night I decided to cut some additional holes in the case side. This was really out of necessity rather than anything else in all honesty - the setup just wasn't getting enough air in. I was going with one hole but decided on two for effect :)
    This hole will be filled with 2 x 120mm silenX fans and a grill. Please ignore the orange fan that was a test fit. Also some rubber surround is going to be added.
    Caution: dodgy phone image ;)
    Also managed to sleeve up a whole lot of cables too
    Also decided that seeing I haven't seen hide-nor-hair of my replacement GPU water block I'm going with a CPU loop on its own for the moment. Another reason for this is due to the fact I am constantly switching out my cards for reviews etc.
    EDIT: All dremel cut
  16. Bullitdodger
    9 Oct 2005
    Looking good.......Whats the ketchup for?
  17. kempez
    4 Aug 2005
    mmmm dinner :D
  18. Guest-23315
    Guest-23315 Guest
    drinking ketchup?
  19. thedragon7786
    thedragon7786 What's a Dremel?
    18 May 2006
    lol
    Great mod you got here! I would go with a bigger window, but that's just me. Keep up the good work!
  20. kempez
    4 Aug 2005
    Thanks for the comment :) Always welcome :thumb:
    I did think about a bigger window but I kinda knew I would end up putting some fans in the case side. Plus I liked the look of the smaller window. Ah well just recieved an Antec P180 for another rig so mebbe then ey :dremel:
    @ Mankz_91: I don't know why but every time I mod I have pies with ketchup!! I usually eat very well with nice fresh food but when I'm on a modding session I eat easy stuff :)
