Project <<| Black3d |>> | Update 14/04/207 | Completed final pics
Discussion in 'Project Logs' started by kempez, 13 May 2006.
  1. kempez
    kempez modding again!
    4 Aug 2005
    Was thinking about engraving one of the bay inserts
    But as stated at the front page the PC needs to look professional as well as being a modded case. I actually like the understated looks and I really like the silver-black contrast.
    I will be tidying up the inside soon and adding a small switchbox for LED's and CCFL's
    Hmm...Black3d logo on top bay cover :)
  2. malccy72
    malccy72 Minimodder
    9 Jan 2005
    I personally think it looks finished; it's very easy to go on and on and knowing when to stop is a skill in itself. Understated is a far better look imo than 'busy' or 'cluttered'.
  3. malccy72
    malccy72 Minimodder
    9 Jan 2005
  4. kempez
    4 Aug 2005
    Yep totally agree. I was sitting beside it last night and thinking: yeah it looks nice :)
    still a fair bit to do inside to make me happy tho :)
  5. kempez
    4 Aug 2005
    Project Update/refresh
    Update:
    Been a little busy with reviewing and deciding what to do with the project. Am moving soon so modding is on hold but I'm going to do a parts refresh
    Just got my replacement Alphacool NexXxos GPU block. The first one was lost in transit :( But Alphacool sorted it :)
    Looks friggin sweet :eek:
    I will certainly be making a GPU loop somewhen soon. It's either the Alphacool or the Eddie EK block :)
    New Parts for a refresh:
    Gigabyte GA_965P_DS4 (Socket 775) Pre-ordered
    Conroe E6600: Awaiting Stock
    RAM Still Deciding
  6. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I'd definitly go with the EK block as it's the most impressive block I've ever seen.
    Nice parts you got there. :)
  7. kempez
    4 Aug 2005
    I've also got the EK block on the way for a review so I'll then decide which one I want :)
  8. Heero195
    Heero195 What's a Dremel?
    12 Jun 2006
    I would put a second res in the top 3.5 slot to complete the look. other then that I think you have a great case. Those new parts should be badass..
  9. kempez
    4 Aug 2005
    They should be pretty nice :) and thanks
    I see your point about the top bays. They are a bit plain at the moment. I don't really wanna add another res to further complicate the loop (plus there isn't really enough room) but yes: something needs to go there. Something that doesn't take up too much room inside the case, but completes the look. Maybe a cathode switch and some LED's?? What dya think?
  10. Heero195
    12 Jun 2006
    I agree the second res would complicate things. I switch panel would work really well with the added functionality of it. I'd go with that :)
  11. kempez
    4 Aug 2005
    Just to prove that conroe is REAL and we do actually have some in the UK ;)
    Just got to wait for a board and decide on my RAM now :)
  12. Guest-23315
    Guest-23315 Guest
    LUCKY BUGGER.....
    go for some G-skill NR 2GB PC2-6400 and one of the 965 Gigabyteboards...
  13. kempez
    4 Aug 2005
    Parts list is above but ye that's what I'm thinking :)
  14. Stwongbad
    Stwongbad What's a Dremel?
    8 Jun 2006
    So lucky , I cant wait to see one of those!
  15. kempez
    4 Aug 2005
    I know!!
    Finally decided on RAM and mobo
    Cancelled: Gigabyte DS4 (going to take too long and I need Multi-GPU for reviews)
    Have ordered: Asus P5w DH Deluxe (again) and some GSkill PC2 6400 (CAS 5). Going to tighten it up and run my sexy 6600 very fast :)
  16. huren
    huren What's a Dremel?
    14 Aug 2004
    I hate you :waah:
    New Zealand is like end of August for even the 64 : \
  17. kempez
    4 Aug 2005
    GSKill RAM arrived, parts tomorrow
    It's green so my loops going to be green to match :D
    And here goes the Abit AT8 32x to our lucky competition winner :D
    Parts tomorrow: Asus P5W DH Deluxe WiFi
  18. kempez
    4 Aug 2005
    Small Update - Cathode switch installed inder USB Cover
    Cut away part of the USB Holder in the front of the Lian Li with my dremel to put in my cathode switch. Trimmed with blowhole trim. Looks pretty sweet IMO :)
    Tomorrow's the Big Intel Day...plus I'll be "going green" in my loop :)
  19. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    what about a white (or light blue if they exist?) ccfl to go with the UV blue one you're using? From the pic with the case lit up it doesn't seem to do the window justice. I think a bit of light and shade (so to speak) would do your case justice immeasurably :thumb:
  20. kempez
    4 Aug 2005
    I have a couple of LED's on me actually. I think I will put some in there...but today is reserved for hardware installation and water loop :)
