Project <<| Black3d |>> | Update 14/04/207 | Completed final pics
Discussion in 'Project Logs' started by kempez, 13 May 2006.
  1. kempez
    kempez modding again!
    4 Aug 2005
    Conroe Installed and running
    Too tired to do a detailed post...but it's going well. Redone Water loop and installed Conroe :D
    No problems so far at stock. Mobo ran fine with the 2gig of GSkill
    One quick pic before bed...stock speeds remember and RAM running on Auto - muchas throttled
    :D
  2. kempez
    4 Aug 2005
    Quick Pics
    Pics quickly :) More pics and detailed comments to follow tonight or tomorrow
    The loop sticks out a bit unfortunately :( But I'm getting the eddie EK block soon so hopefully that would be better for routing. I can just put the case side on without one of the fans :mad:
    We'll see...
  3. huren
    huren What's a Dremel?
    14 Aug 2004
    Mm nice dude.
    Super pi 21 was what i got stock as weel and on 3 other systems.
    Crank that puppy to 3ghz and bring on the 17secs like i pulled on air today ( 23 while dual priming ).
  4. kempez
    4 Aug 2005
    I plan on going well past that 3GHz barrier for sure :D
  5. kempez
    4 Aug 2005
    Conroe in and clocked!
    Thanks man
    Max Stable OC 3.6GHz (400 x 9)
    http://valid.x86-secret.com/show_oc?id=111144
    What I may run it t 24/7 is 3.375GHz (375 x 9)
    http://valid.x86-secret.com/show_oc?id=111180
    Not bad
    Here's t3h sex:
    It's worth noting that there is still work to do on this. The eddie ek block is yet to go in and I have to sort out that hole where the fan was: it didn't fit on the case with the alphacool block so I'm hoping it will with the eddie...though not confident. I spose i could just make it into a nice window :)
  6. yahooadam
    yahooadam <span style="color:#f00;font-weight:bold">Ultra cs
    21 Mar 2006
    simple yet effective :) nice work
    and nice on the conroe, somone has lots of money :p
  7. kempez
    4 Aug 2005
    Thank you :)
    And not a huge amount of money - I just tend to sell my old setups and get new stuff :)
  8. kempez
    4 Aug 2005
    Soz about the lack of updates. Been busy with review and stuff.
    I have some new RAM and a new chipset cooler but I also managed to break a CCFL :duh:
    Awaiting stock as AC Ryan is the only make I'll have :thumb:
    I'm moving soon so hopefully I'll have some time to get some work done then :dremel:
  9. kempez
    4 Aug 2005
    Update finally!
    Right update. Pics don't do this justice as it looks very nice in real life.
    Not fiddled properley with the mobo yet but it installed Windows fine. The temps are a bit high on the CPU but I think I need to adjust the fixings a bit.
    Added some drive bay stealthing and still lots more stuff to do like doing the floor in carbon fibre and some more black alu inside but it's looking good so far imo :)
    New hole cut in mobo for cabling:
    Dremeled that up as well as some more alu to cover the drive bays
    There's a couple of scratche that I can polish out (this is my workhorse PC after all), but it's very nice shape apart from that, despite these terrible pics :p
    Quick UV view:
    Current hardware is:
    Core2Duo E6600
    DFI RD600 motherboard
    2 x 1gb Mushkin HP2 6400
    MSI 8800GTX 768mb
    OCZ Gamextream 850w
    Hitachi Deskstar 7K160
    2 x Hitachi Deskstar 7K80's (in RAID 0, not installed yet)
    Sound Blaster X-Fi fatal1ty edition with breakout
    Crystalfontz LCD drive bay screen
    Pioneer DVD-RW
    Custom Water Cooling:
    Swiftech Apogee CPU Block
    Laing D5 Pump
    Aquacomputers EVO 360 RAD
    5 x 120mm SilenX High Performance fans
  10. Guest-23315
    Guest-23315 Guest
    have you had any issues with the R600 temps then ??
  11. kempez
    4 Aug 2005
    Well I'll post up some pics of the mess DFI made of the NB later on, but yes they're pretty high (50°C idle stock) even with that SilenX fan I have on the NB. An alternate cooler is being sourced right now :)
  12. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    good work there, I see you have an ICFX3200, yeah the paste isn't really nice, should change it before the first post, and a HR-05 would be very nice because you're watercooling ;)
    I'm still waiting on my ICFX3200...
    please post the temps here too :D
  13. kempez
    4 Aug 2005
    Aye it didn't even get booted without changing the TIM on the NB and SB.
    Need to reseat my Apogee then I'll post some temps
  14. 1e8o
    1e8o What's a Dremel?
    13 Oct 2005
    nice, I like your style :D
  15. kempez
    4 Aug 2005
    Some people wanted to see what the NB looked like before I cleaned it up:
    I used plenty of tissues at first as there was so much, then some TIM and a clean cloth when it got to reasonable levels.
  16. kempez
    4 Aug 2005
    About time for an update!
    Right then big bundle of stuff from my good friends at SpecialTech :D
    I did manage to forget to ask them for Green UV Dye tho :(
    My X-Fi card had an IDE like wire but I had to make it better
    I got the CF off of eBay. The bloke cuts it to size for you. High-quality automotive Carbon Fibre :)
    Got the insides fairly sorted. Damn annoying that the nice short IDE cable ST got me wasn't quite long enough to fit :mad: Still the lil green Sata cable was :)
    The OCZ cooler didn't fit either due to the board having the RAM slots in a weird place. Getting tempted to use my 680i board in my main PC...
    Here's the finished insides:
    Not too bad imo.
    Fitted wheels to the old girl and put the cathode switch out of the bottom of the case so I can turn em off easier:
  17. kempez
    4 Aug 2005
    Final Update - completed
    Right not doing anything more to her so here she is. Got a few scratches and scrapes on but that's cause I haul it around a lot :(
    Full Build Thread Click Here
    Specs:
    Case: Lian Li PC71B
    CPU: Intel Core2Duo E6600 @ 3400Mhz (24/7)
    Motherboard: DFI Lanparty iCFX3200
    RAM: Mushkin XP2 6400 @ 800MHz 3-4-3-10
    GPU: MSI 8800GTX 768mb
    Sound: Creative X-Fi Fatal1ty FPS edition
    HDD: Hitachi Deskstar 7K160
    Optical: Pioneer DVR111BK
    PSU: OCZ GameXstream 850w
    LCD Bay: Crystalfontz CFA 635
    Screen: Dell 2405FPW
    Input: Logitech G5 + Saitek Eclipse II
    Watercooling:
    Swiftech Apogee GT CPU Waterblock
    Laing D5 Pump
    Aquacomputer Evo 360 RAD + Grill
    ClearFlex 1/2" ID tubing
    DangerDen Clear Bay Res
    Zerex racing Coolant
    Green UV Additive
    Additional Cooling:
    NorthBridge: Thermalright HR-05 + SilenX 80mm fan
    3 x SilenX 35mm 14dba Fans (rad)
    2 x SilenX 25mm 14dba Fans (case side)
    The front:
    The side - too many scratches :(
    view of the front and side
    View of the top as well
    The insides (ignore the fan wires at the top they're tidied away)
    A little detail on the CPU and NB area
    Detail on the PWM area
    The Carbon:
    Wheels
    Some UV action
    Front bay res and LCD
    Side with the "smoked" window and fans
    All lit up - looks better in real life but I did the best shot I could
    Gratuitous Desk Picture:
    Been a long project and would have been better done all together but never mind :)
    Big Thanks go out to SpecialTech for all the help with the Project bits and bobs - GJ Guys
    Now to start the next one :D
  18. picio71
    picio71 What's a Dremel?
    19 Sep 2004
    nice works
  19. kempez
    4 Aug 2005
    Thanks dude
    I forgot this pic when I edited the post:
  20. Regidet
    Regidet Awesomenesstrocity
    8 May 2008
    use a 1/8 inch drill bit, go right through the rivets
