Project: Blackhaze
Discussion in 'Project Logs' started by max001, 8 Dec 2004.
  1. max001
    max001 What's a Dremel?
    8 Dec 2004
    well i starded with one of these:
    [​IMG][​IMG]
    and yes its quite boring...he has no idea i'am about to pimp this case(srry looking to much pimp my ride :rolleyes: ) :dremel:
    this is the *junk* that goes in the case :D:
    Case: Midi Tower 2059 ATX PIV 300W
    PowerSupply: Q-Tec 450 watt ATX voeding dual fan
    CPU: AMD Athlon(TM) XP 2600+
    Motherboard: Asus MB A7N8X-X AMD Athlon
    Memory: DDRAM 512Mb PC3200 400MHz
    Graphics: GeForce FX 5200 128mb
    HDD: maxtor 40Gb 7200rpm and maxtor 120gb 7200rpm
    Heatsink: Spire AMD socket A CPU cooler
    and some other stuff like a sharkoon controler,4 neon tubes(green) and some extra fans.
    Here is my motherboard and stuff working on my desk(hey i got to log right :naughty: ):
    and another big pile of messy stuff that have to fit in:
    ok lets start with my fresh green painted frame:
    [​IMG] [​IMG] [​IMG]
    this will be my side panel(1st pic nearly done 2nd pic all done):
    [​IMG] [​IMG]
    the fan in the side panel looks like this(only my has a strobe effect):
    here is the lower part of my front pannel with windtunnel and mash:
    instald the fan for the fronttunnel:
    it comes quite together now :D:
    almost every thing instald:
    my fronttunnel in the dark(little hard to see but in real it looks better):
    and my sidepanel in the dark:
    so let me know what you guys think of it,any hinds/tips/comments are welcome.
    ps.dont look at my English couze its my second Languish :worried:
  2. max001
    8 Dec 2004
    and i am planning to tiddy the cables up,this are the things on order for it;
    Sunbeam RCFG-UV Fan guard with UV ccfl:
    ACRyan ACR-FK3824 FlexSleeve Kit UV green:
    ACRyan ACR-CB7570 Connectx Floppy Power 4pin Female UV glow:
    ACRyan ACR-CB8553 Connectx 4P Molex Male connector huls UV green:
    ACRyan ACR-CB7808 Connectx 4P Molex Female connector huls UV green:
  3. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Good work (and paint), but maybe too many colors for BLACKhaze... hehehehe
    it`s my opinion, but don`t mix pure blue light with green light if each color not cover 50% of the available lighting (degradations with CCFLs, for example). otherwise don`t match very well, i think.
  4. max001
    8 Dec 2004
    wel normally the ccfls are not on @full but quite weak fanting in and out,but thats a little hard to take a pic of :p
  5. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    Thats a sexy green for the frame. I like it.
    I was going to scream about the rats nest of wires, but you said you are working on that, so I'll let it slide. This time. :hehe:
    As a side note, it appears you are hotlinking the picture of the blue fan. You might want to do something about that. EDIT: and all of the other component pictures. You can use them, just host them yourself.
  6. Henrymonaghan
    Henrymonaghan What's a Dremel?
    6 Nov 2004
    uh man, u realise that fan on the side of your case will get hardly any airflow. maybe open it up a little more, part from that looks good, once the wires are tidy should look nice
  7. max001
    8 Dec 2004
    srry dont know that,i fix it as soon asposible :rock:
  8. max001
    8 Dec 2004
    thx :p but i like to invite you here and put your hand in front of it,and tell me it does not got a good airflow(and yes its not max,but hey the eye wants something to :worried:)
  9. max001
    8 Dec 2004
    added a new fan for the front intake, looks much better now(i think):
    before:
    after:
  10. max001
    8 Dec 2004
    the fangrill and cablesleeve instald:
    the rest of the cables and molexconectors wil be done soon
  11. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    You still have quite some nasty cable mess going there.
    Sleeving the cables won't tidy it up on it's own. Your current positioning of the cables is still highly airflow restrictive.
  12. Muon
    Muon What's a Dremel?
    1 Dec 2004
    congratz! you sleeved your own cables and thats a pain, cause its sooo easy to screw up. i think you've done a good job, now the challenge is to keep them organized, but show cause they look good, good job and keep it up!
  13. max001
    8 Dec 2004
    what would you recoment me to do couze i'am quite a noob in this :rock:
  14. max001
    8 Dec 2004
  15. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    cable ties! :dremel:
