Project Blacklight Demons (plexi fulltower)
Discussion in 'Project Logs' started by [WP@]WOLVERINE, 11 Dec 2003.
  1. Atomic
    Atomic Gerwaff
    6 May 2002
    Holy s**t! that's really quite amazing!
  2. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    wow :jawdrop: thats very dope!
    top trumps on this mod keep those updates rolling!
    PLEASE DO NOT TRY AND WORK AROUND THE BAN ON SIGNATURE PICTURES.
  3. Tacritan
    Tacritan What's a Dremel?
    6 Jun 2003
    Oh my! That's about the sweetest etch i've ever seen! The best mods comes from scandinavia ... (both Zap and G-gnome are undercover swedes actually... :p ) But uhm... Nice work, can't wait to see the whole thing assembled and glowing. This is modporn! :D
    Edit: on another side, wtf is wrong with the forums? It's like totally TOTALLY changed. :p
  4. piloux
    piloux What's a Dremel?
    12 Nov 2003
    :jawdrop: there is no words to tell how it rocks :thumb:
  5. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    :rock: :rock: gotta be the sweetes custom etch i ever saw!! :jawdrop: :jawdrop:
  6. Theo
    Theo What's a Dremel?
    12 Jun 2003
    ... she covers the world in darkness?
    WHOA! btw :D Good work, chap!
  7. richman
    richman What's a Dremel?
    17 Sep 2003
    man that is one sweet ass case i like the etching you have done very impressive for a first go. Hope to see some updates soon :thumb:
    Richman
  8. at_b
    at_b What's a Dremel?
    28 Mar 2003
    sweeeeeeeeeeeeeeeet dude
    as i said before, your skills are absolutely(sp?) amazing
  9. zachypoo
    zachypoo What's a Dremel?
    12 Jan 2004
    Very gothic and gothic is cool
  10. TMM
    TMM Modder
    12 Jan 2004
    OMG! thats the most awsome case i've ever seen! also the largest :D
    i don't think the black "doors" on the front tie in very well with the rest, but that just My opinon :p
    great work dude! got any more pics?
  11. 3vil-Grin
    3vil-Grin What's a Dremel?
    25 Jun 2003
    SWEET A$$ ETCH!!!!
    :clap: :rock:
    This man got skills...
    So are you using this in the project or is this gonna be wall mounted for now?!
  12. Sir Overclock
    Sir Overclock What's a Dremel?
    10 Jan 2004
    Several things I wish to say...
    Firstly, well done on having the guts first off to build a plexi case from scratch. They don't always turn out as good as on paper, but I think we can all say that your workmanship is fantastic. The case shape is very good, and your hole cutting :dremel: is perfect!! How you use up that ammount of hard disk space is beyond me, and I can't help but think how much heat os going to be generated by them. How close are the disks from eachother? This is definatly somthing that needs to be thought about. But apart from that, wow. Your etching belongs in a hall of fame, truly. Although not my choice of drawings, the detail is amazing.
    I can't wait to see the finished product. So far, it's brilliant. Keep the sweet work comming!!
    --Sir Overclock-- :cooldude:
  13. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    Sir Overclock-
    The harddrives has about 1cm space between them and is cooled by 2x80mm fans that keeps the air flowing around them. I have 7 80mm fans cooling the case and the temp is
    35 celsius chassie and 46 idle/cpu so its cool enough :)
    3vil-grin-
    the uv etch turned out so good that i tink ill use it in the case :)
  14. mod-ern man
    mod-ern man What's a Dremel?
    12 Nov 2002
    Beautiful work on the case Wolverine! Your engraving skills are superb. :rock:
    I've been thinking about methods & dimension for making the drive supports for my own project. What dimensions did you use to layout all those holes for the drive bays? and how/where did you get those dimensions? :confused:
    Cheers
  15. [WP@]WOLVERINE
    18 Oct 2003
    I got the measurments froman old case i had lying around and then added a few mm to get more space between the drives for better airflow. The holes are drilled with 3cm distance Center to center.
  16. ohcyt
    ohcyt What's a Dremel?
    7 Jan 2004
    re:
    Those etches are a nice job =)
    I like the way you're using tubes to tidy up your cables, will use something similar for my fan cables (yep, also inspired by g-gnome - I fell in love with the tube/jackplug combo ;) )
    mod on, I can't wait to see the final result! =)
  17. [WP@]WOLVERINE
    18 Oct 2003
    -==UPDATE==--
    Ive finished yet another small part of my mod now. The tubes that contain the powercables for my fans needed to be fastened. I cut a 1,5cm plexi strip and went to work on it.
    After some drilling and sanding i covered the edges with some hobby clearcoat and this is what i came up with. Theese will work nice to keep the cables separated and going exactly where i want them.
    Heres another picture of the cable separators in action :)
    This was just a small update but a big one will come this weekend ive recieved all the components that i need now and will try to finish this project within a week.
  18. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
    Those cable guides are slick. Very nice work :thumb:
    <edit>
    heh your quick :)
    </edit>
  19. Sir Overclock
    10 Jan 2004
    Nice job on the cable separators. The finish is great. Keep it comming!
    --Sir Overclock--
  20. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    Smoooooth, :thumb: very nice :)
