Project Blacklight Demons (plexi fulltower)
Discussion in 'Project Logs' started by [WP@]WOLVERINE, 11 Dec 2003.
  1. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    I must say this to all of you that doesnt think the front fits the case. Theres still alot of work to be done and youll see that in the end the front will fit the overall look perfectly. Both the top of the case and back will get the same treatment as the front, there will also be some black tribalplexi bits on the sides.
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
    well that's cool - it just didn't seem to fit, and i thought you were basically finished. keep up the good work
  3. Confusitron
    Confusitron What's a Dremel?
    22 Dec 2002
    Wow! That is some great work! I like the new front!
  4. Gedron
    Gedron What's a Dremel?
    31 Oct 2003
    What... two weeks and no update?
    BUMP I SAY!!!
    :brrr:
  5. [WP@]WOLVERINE
    18 Oct 2003
    Sorry about that :) But ive been kinda busy with some other stuff like my Family and my job. Ive also upgraded the hardware to a xp2400, not much of an upgrade but atleast its better than the old xp1800. Ive also put together a new pc for my wife and im currently putting one together for the kids. So the modding has been on hold, but i promise i will get some modding done in the week to come,the next update will be the last one.
    Then ill be starting a new project! :D I will remake the wifes computor in to a Thin Lizzy Tribute Pc (Shes a big fan of thoose guys and so am i) complete with Thin Lizzy logo window and a Thin Lizzy custom paintjob. Ill also will be throwing in som other goddies as you will discover when the new log is posted :D
  6. -SilentNight-
    -SilentNight- Hardcore pro gamer
    24 Jan 2004
    niceee... i wish i had same skills....
  7. [WP@]WOLVERINE
    18 Oct 2003
    -=Small update=-
    Ive been messing around abit with som small stuff lately, i designed a project namneplate for my case since im about to take the official competitionphotos for the swedish Mod championship
    Heres the Namesign
    I also monuted the two tubes that i originally made for the front, on the inside of the case and lit them up with a blue ccdkit since the uv light wasnt bright enough.
    And the it was on to my old MS Natural keyboard some black paint and some transparent uv paint did the trick
    Lights on :)
    Lights off :D
    The keyboard now fits the rest of the case abit better than the crappy grey original color :)
  8. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
  9. tekcajder
    tekcajder What's a Dremel?
    1 Mar 2004
    i love your case. i gotta say though, plex cases scream water cooling to me. especially with all the uv lighting ... you could lightly dye the liquid so its not so intense and doesn't interfere with your engraving ... it looks great either way ... i'm just a sucker for WC in cases like that. :D (its expensive though, so i'm living through other peoples mods before i can afford to start building my box)
  10. piloux
    piloux What's a Dremel?
    12 Nov 2003
    wow :jawdrop:
    this is trully exellent man , I love it like the whole case :clap: :clap: :clap:
    it seems you re on the best way about the championship :thumb:
  11. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    Looks so good!!!!!!!!!!!!!!!!!!!!!!
    Varför är inte du med på utställningen på Tekniska i Stockholm??
    Kan du ge mig länken till modding tävlingen , har inte ens hört talas
    om den.
    I bet you winn the competion.
  12. naelq
    naelq What's a Dremel?
    14 Oct 2003
    that's one of the MODS that i have ever seen! :D
  13. [WP@]WOLVERINE
    18 Oct 2003
    heres the link
    http://www.moddningssm.webb.se/
  14. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Sorry to bring this up again, but wow...what an awesome job with the etchings!!! :jawdrop: :jawdrop: :jawdrop:
    Any updates since you last posted???
  15. Goblin Tinkerer
    Goblin Tinkerer What's a Dremel?
    24 May 2004
    Glad you pulled this one back up for us to see! Very nice!
  16. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    damn mate great work mate. Lovely use of light. Doing well.
  17. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    [skandinavian mode]wow! det ser ekstremt bra ut!! håper du vinner!
    Og til alle svensker, grattis med kvartfinale plass i em![/skandinavian mode]
    Looks sweet, that etching is amazing, I could use youre skill!!
  18. SMOVE
    SMOVE What's a Dremel?
    17 Apr 2004
    Good job, this is really a rocking plexi-case :rock:
  19. [WP@]WOLVERINE
    18 Oct 2003
    Thx for all the positive feedback!! This project is now completed and im moving on, im currently sketching on how to transform an old burnt out Epson C70 printer into a kickass htpc :) Ill post a worklog as soon as the project gets on its way :)
  20. WaZzUp115
    WaZzUp115 What's a Dremel?
    12 Feb 2004
    woha.. a printer.. sounds kewl :)
    also the case is awesome :thumb: by the way :D
