Project Blacklight Demons (plexi fulltower)
Discussion in 'Project Logs' started by [WP@]WOLVERINE, 11 Dec 2003.
  1. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    Ah i missed that one :) But now ive seen it and it looks good :) The only thing i can say is that you should use a different etching bit to get even better results.
    I use theese for plexietching
    Examples:
    One made when i was bored
    Sidepanel for the BLackligth Demons case
    And i use various diamond etchingbits for etching on metal i dont have any pics of theese etching bits but they come in all shapes and sizes.
    Examples:
    Sidepanel on a Antec PLusview 2 made for Antec as a prize in a giveaway at Dreamhack
    Sidepanel on an Lian Li pcv1000 from my article here on bit
    http://www.bit-tech.net/modding/2005/08/01/star_wars_etching/1.html
  2. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Thanks
    Nice engraving :thumb:
    I'm gonna buy a flexi shaft and more engraving bits for xmas :D
    Edit:
    Are there big difference to engrave on plexi and lexan?
  3. [WP@]WOLVERINE
    18 Oct 2003
    PLexi is just the brandname its actually Acrylic
    The main difference is that Lexan is harder and more scratch resistant wich means that you can run the dremel at a much Higher rpm than you can on the softer Acrylic. But Lexan costs a bit more but if youre building a whola case the lexan is definetly best.
