Project Blacklight Demons (plexi fulltower)
Discussion in 'Project Logs' started by [WP@]WOLVERINE, 11 Dec 2003.
  1. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    drool :brrr:
    i cant believe the quality of those fan holes in the front... their amazing.
  2. vonkaar
    vonkaar What's a Dremel?
    6 Oct 2003
    Very nice ^_^. That engraving work is second to none.
  3. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    Im currently engraving the rightside panel now. Actually i just took a break for som coffe and a cigarette :) So tonight the rightside artwork will be posted so keep an eye out :)
  4. MrShake
    MrShake What's a Dremel?
    3 Nov 2003
    I heard somewhere once that when bending tubes or pipes, fill them with sand to help keep shape and not kink... just an idea!
  5. [WP@]WOLVERINE
    18 Oct 2003
    :cooldude: :cooldude: UPDATE :cooldude: :cooldude:
    So after a few hours of constant engraving the dremel has left my arm feeling like spagetti but when i firered up those red leds and saw the result the pain seemed to go away :hip:
    I still have some edges to finish of and some fiting of the bits that are done. I will also add some shading to both sides later on to bring out the details a bit more but it will have to wait until i regain the use of my arm.
  6. vonkaar
    6 Oct 2003
    Now that is downright inspirational... if... demons inspire you that is =p.
    Very beautiful ^_^.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    :eeek: :jawdrop:
    (again)
  8. Tacritan
    Tacritan What's a Dremel?
    6 Jun 2003
    What can I say? :jawdrop: :baby:
    Quote from 2F2F: "That's some artistic ****!"
    Keep up the good work. :)
    Edit: just found a website which sells the saws for 109NOK ($14)!! Finally! :D
  9. [WP@]WOLVERINE
    18 Oct 2003
    You should check this site out this is where i got my holesaw
    http://www.harald-nyborg.dk/
    Its located in Denmark and i noticed that youre Norweigan so you should have no trouble ordering.
  10. Tacritan
    6 Jun 2003
    Actually, I couldn't find the holesaw anywhere on harald-nyborg.dk. :( Just non-adjustable ones and different sets. :( Can you give me a direct link? (Not that it really matters as I found a norwegian site that sells the same holesaw, but just to make sure I haven't overlooked anything ;) ).
  11. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Wow, incredible. You are obviusly very good at working with plexi (at least....now you have some experience :D. That must have taken a lot of sanding to complete.
    I assume you are gonna blowtorch the edges to get them clear?
  12. HardModd
    HardModd What's a Dremel?
    16 Nov 2003
    Dam i TOLD YOU you are ready 4 Bit -Forum "magsår" :clap:
  13. Solarius
    Solarius What's a Dremel?
    3 Oct 2003
    Gasp. Holy cool. :rock:
  14. Bob 1234
    Bob 1234 What's a Dremel?
    5 Aug 2003
    Sorry, I missed most of this, but what did you sue to cut out the shapes and not crack the arcrylic? It looks like a jiggsaw, but then if so, what blades did you use? Sorry for allt eh Q's I am trying to do somthing liek it on my own and have no idea what to use for cutting out stuff like the psu hole. :sigh:
    Thanks,
    -Bob
  15. avsfan733
    avsfan733 What's a Dremel?
    16 Nov 2003
    ok ...dremel master :jawdrop: :dremel: :jawdrop:
    the most incredible part is that you did it by hand, and the straight lines are actually straight...thats incredible!
  16. Axl
    Axl What's a Dremel?
    8 Nov 2003
    Awsome :rock: :rock:
    How thick are the plexi? 4-5mm?
    Are the clearance between the sides of the case and the fastening holes to the IDE units large enough to fit the screws by hand?
    What do you use to join the sides of the case? gluegun or epoxy?
  17. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Judging by the closeup of the blowhole, I'd say that's 10mm plexi.
  18. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    my god... amazing.. I love it man :jawdrop: :rock:
  19. [WP@]WOLVERINE
    18 Oct 2003
    I used a jigsaw with a fine teeth metal cutting blade to cut the straight lines. As for the psu hole that was made by first cutting a hole with the holesaw and then the jigsaw. I drilled alot of holes with a 10mm drill to get startingpoints for the jigsaw. The really tough bit is then to get the final shape and thats made with files and sandpaper.
    The plexi is 8mm thick. The whole case will be put together with the original plexicubes from my old Sunbeamcase no glue of any kind will be used it will be held together with brass screws.If i had glued it together i would not be able to mount anything in the case. but how i put it together will soon be revealed.
    I will try to get an update done this weekend so stay tuned :)
  20. ATi Loyalist
    ATi Loyalist Who throws a shoe?!
    9 Nov 2003
    wow man, u do alot of tedious time consuming work, alot like me, i know how the spaghetti arm feels, lol. nice cuts on the blowholes, extremely smooth and professional man!
