project : Blackmesa HL²
Discussion in 'Project Logs' started by piloux, 24 Feb 2004.
  1. tm36usa
    tm36usa What's a Dremel?
    21 Jan 2004
    Ya it is pretty big.
  2. modderman
    modderman What's a Dremel?
    2 Mar 2004
    Hey, like the case alot. However, I must say that it really hurts every time that you attempt to speed up the rusting process on beautiful metal. LOL, but seriously, you shouldn't do rust throughout the entire case. I'm not saying that you should leave any parts unpainted, however, to provide the proper amount of accent to certain parts it should be painted in a contrasting color. So far, the only contrasting colors will be the case's lighting and the red thing for your resevoir (correct me if i am wrong). Don't get me wrong, I understand where you're coming from with the rust, but alot of your incredible mods will just be missed if you don't do something to make them stand out, for instance, why don't you paint the silver shower hose that goes to the upper exhaust fans black, green, or leave them the original color. This would create an awesome effect - especially the black or green. I mean, I've never played Half Life, but I've seen some screenshots and it seems to be pretty high tech... not all rusted out, although I do see where the theme is coming from.
  3. MechWarrior
    MechWarrior What's a Dremel?
    13 Oct 2003
    ^^ Its still early in its stages, he just started the wires too. I understand what you are saying but im sure he has a few tricks left to do :)
  4. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    looks nice :thumb:
    Sorry if this has bene asked before, but how loud are those Enermax 120mm fans? Im thinking about getting one. Is it worth the price?
    Keep up the good work!
  5. kestrel
    kestrel What's a Dremel?
    9 Nov 2003
    I have one and when you use the speed adjustment inluded with them they can get pretty quiet.
  6. Skaal-tel
    Skaal-tel What's a Dremel?
    12 Jan 2004
    I say rust it aaaaalll the way! All of the underground missions in HL are all rusted pipes and walls and radioactive goop.
    HL2 is in a distant future... presumable less rusty pipe, more carnivorous city.. but oh well :) I LIKE the rust everywhere!
  7. dudeyourmomiscute!
    dudeyourmomiscute! What's a Dremel?
    14 Dec 2003
    i think he got the idea, a blur of rust with signs of the hl2 logo just to give it that weathered aged to perfection look he probably wants. he design after all is supposed to be like his half-life 2 wallpaper. possibly valve itself may want it for display with half-life 2 someday :naughty: nice mod there piloux
  8. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    wow 10 pages and only like 5 updates >_< nice work as usual.
  9. truechaos99
    truechaos99 What's a Dremel?
    6 Feb 2004
    Amazing... Simply amazing... cant wait for the next update.
    -Cameron
  10. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    more updatage.. plz................... :waah:
  11. pranks7er
    pranks7er mange tout
    25 Dec 2002
    i wanna rust my computer, ( actually i have a case naturally rusting outside (not intetional) but please give me few tips!!!
    awesome work mate :clap: :clap: :clap:
  12. Providence
    Providence What's a Dremel?
    23 Jan 2004
    He already said how he painted it on there...mainly its spray paint, but I think somewhere he changed his methods and now he's using a paintbrush. It's not hard, you just have to find the paint you like. Go to a junkyard, look at the rust on parts, take a picture or two, then study that rust. You can achieve the same thing with some elbow grease.
    I mean, any fool can cut a window and sleeve his wiring. It takes work to do something of this caliber. Good luck piloux, it looks great right now. What are your plans for the boxy resevoir? Will it be in the case or on top, and will you paint it or age the glass? I would scuff up the outside and paint the acrylic to look like it was half buried in mud...dark, murky water inside, then the tubes show it to be UV green or blue or something, whatever. Just an idea. :thumb:
  13. Madyeti
    Madyeti Supermodder & sig shrinking victim
    1 Dec 2002
    Excellent work so far! I am looking forward to seeing more of this case development! :brrr: ~David
  14. tm36usa
    21 Jan 2004
    Hey Providence i think im a bit rusty on my rust. :lol: Ok very bad pun. :lol:
  15. instant rice
    instant rice What's a Dremel?
    20 Jan 2004
    You can buy plastic electrical conduit at home improvement warehouses with inner diameters of up to 1/2" (12mm or so). Those could easily be painted and rusted and drilled through for the leaking goo effect. Excellent work, piloux.
  16. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    Is the bit, looks sooooooooo real
  17. xrain
    xrain Minimodder
    26 Jan 2004
    :D nice mate on the rusting i think you accualy thought about it befor painting, because you put rust where it would rust first (on the bolt fittings) i think you did a great job,
    if you want some realistic bullet holes just take it to ur local shooting range and take a couple cracks at it with your 12 gauge shot gun :D id be more then happy to do it for you.... just hope i wouldent get "too" carried away :naughty:
    "sends back a fews shot up rusty piceses of metal..."
    "my shotgun malfuntioned :worried: "
    good luck great job, and i just think i might use the hl2 theme to give a new look to a much used thing ;)
  18. CooLJoE
    CooLJoE Minimodder
    20 Mar 2002
    dang that mod is AWESOME!!!
    the rust looks perfect and the hl2 logo is sweet!
    :rock: :dremel: :clap: :jawdrop:
  19. piloux
    piloux What's a Dremel?
    12 Nov 2003
    hi everybody :)
    well , I must say that's only the beginning of wiring, it is a lot of work to do, don't worry about it I ll give them an old damage aspect that contrast with rust parts
    thank you,
    these fans are pretty quiet on low speed
    :rock: :rock: :D
  20. piloux
    12 Nov 2003
    I hope the next will be this weekend.... I m very busy this week :duh:
    thank you , thats right , to paint rust effect, you have just to buy the paint and make some try to see the best way to do it, may be other method is better than what I did ...
    about the reservoir, I m always thinking about differents possibilities but I like the idea to put it inside the case :)
