project : Blackmesa HL²
Discussion in 'Project Logs' started by piloux, 24 Feb 2004.
  1. piloux
    piloux What's a Dremel?
    12 Nov 2003
    yes, THIS is the Half Life spirit :rock:
  2. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    I think there may be a problem with this meter. The scale says 6 amps. That is a lot of current to pass through the metre to get a full deflection. Form the images you have posted I cant see an obvious shunt (resistor to change the scale of the metre). Can you see a coil of wire any where near the contacts of this thing?
  3. piloux
    12 Nov 2003
    no , I dont see a coil of wire , is the shunt the big copper wire? it seems to be fix on the two contacts( in and out of the meter)
  4. Wicked Li'l Bender
    Wicked Li'l Bender What's a Dremel?
    9 Nov 2003
    So, what is the polygon count to render that crowbar? It looks a lot better than the one in the game.... the metal is too shiny.... it needs to be slightly abused and have some green tinted clear epoxy dripping off of it with some blood colored epoxy to approximate what you would see from running a level with no ammo! You could even splash the front or side where the bullet holes are with debris or (epoxy blood/slime) splatters to give it that whole "kicking mutant posterior look... That meter is very heavyduty looking there should be some sort of resister bank in there that would lower the current to a non coil burning level, if you could bypass that it would be able to moniter hdd activity without problem, and make an led driver bank that erraticly flashes, lighting the meter with r=true halflife charicter (sp). Looking awesome as usual! keep on modding! :dremel:
    Hope that helps some...
  5. The_Resetter
    The_Resetter I LIKE CAKE!
    6 Oct 2003
    About the meter, u can try putting 9 volts battery on the different connections points and see if its moves, so u at least know if it works and on what connections.
    I have used that method on about 9 old meters none broke so far :hehe:.
  6. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Wasn't the original crowbar hexagonal?
  7. jonesie
    jonesie What's a Dremel?
    24 Nov 2003
    wouldnt that effectively short the battery, leading to massive over-heating? I've burnt thru a carpet with one of those... :duh:
  8. Mr Joshua
    Mr Joshua What's a Dremel?
    6 Mar 2004
    I'm sure you've already thought of it but just in case you haven't; could you mount the crowbar in a way to make it look like its piercing either the metal of the case of as if its been ut through a window (if you are having a window)?
    Might be a bit of a problem with the weight unless you could make or buy a decent looking plastic one.
    Just a thought :).
  9. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    DUDE thats a real crow bar moron :D
    not a render
  10. Morphine
    Morphine weeee!
    23 Feb 2002
    i think hes poking fun at the whole game theme.
  11. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looking badassashell man.. lvoein it.. osrry i'm srunkd.
    keeps up the goods owrks.
  12. Mord
    Mord What's a Dremel?
    7 Mar 2004
    Wow man, what type of paint did you use? and what sort of techniques? ive got an old case lying around and id love to try something like yours.
  13. piloux
    12 Nov 2003
    hi , you can check how I made it in the firsts page of the thread, there are some pics of the paint I used too
  14. sqaulidhummer
    sqaulidhummer What's a Dremel?
    11 Sep 2003
    omg :eeek: that is sweeeeeet :jawdrop:
  15. tortuegeniale
    tortuegeniale What's a Dremel?
    7 Nov 2003
    it's made from aluminium so the weight is not quite the same as a real crowbar
  16. The_Resetter
    6 Oct 2003
    Hell no, I shorted so many battery's, non blew up or get to hot, obviously you don’t put the battery on it for like one hour. So a small short-circuit should hurt.
    p.s. Piloux u tried it already?
  17. Rain
    Rain What's a Dremel?
    16 Jun 2002
    Ohh my god :jawdrop:
    It looks really rusty :hehe:
  18. piloux
    12 Nov 2003
    No , I haven't try it ... I need a 10 kohms res to try...
  19. kplonk
    1 Mar 2002
    This metre is currently set up to measure current though a circuit, to test just get a battery and a torch bulb, connect all in series and see if the needle deflects at all.
  20. The_Resetter
    6 Oct 2003
    Yea but a torch bulb isnt going to pull 1A, so just short it with a battery.
