project : Blackmesa HL²
Discussion in 'Project Logs' started by piloux, 24 Feb 2004.
  1. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    How many volts?
  2. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    This thing is looking better all the time... how about the harard logo from a caar on the botton... the would look cool.
  3. Garbach
    Garbach What's a Dremel?
    22 May 2003
    I really REALLY like the way you're putting this thing together. It looks great!!
    I have one more question about the paintjob, and it's about the primer. Did you prime everything or just the plastic parts? Is the red/brown paint I see in the pictures the primer and what kind of primer did you use? Did the colour of the primer influence the final result of the rust effect you got?
    I'm planning to do some small rust effects on my case and your instructions about the timing between the iron paint and the oxidant were most helpful. By the way, how thick did put the paint on. Really thin like on the test piece or very thick, like on the blowhole panel?
    Keep it commin' cause it's awsome and we want more... ;)
    Garbach
  4. Lupine
    Lupine What's a Dremel?
    18 Dec 2003
    I've seen one or two people say they want to rust their own cases...
    So, I went looking...
    http://www.artmail.co.uk/craftp.shtml
    Scroll down to "MODERN OPTIONS TRUE PATINA FINISHES"
    Or, alternatively,
    http://www.burhouse.co.uk/products2.asp?cat=WOOD FINISHES&subcat=GLAZES
    Not cheap per pot, but if you must make your case look like it's been swimming in industrial crud for a decade... :)
    Hope that's of use to those of you out there who've been drooling over the paintjob and wanting to try it yourself.
    Oh, and I mustn't forget the obligatory "OMG, SWEET" :)
    I'm not sure if gorgeous is the right word to use to describe such a 'distressed' case ;) , but it's definitely unique, and an incredible piece of work.
    Congrats on the work so far, piloux.
  5. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    NP m8! Its just a small idea compared to the inspiration for your mode anways. :rock:
  6. Da_Rude_Baboon
    28 Mar 2002
    ffs double post. :sigh:
  7. Garbach
    22 May 2003
    One more thing I noted: when you're all done it's like REAL rust; including that when you touch it your hands get rusty too!! Not to mention rust (oxidated IRON) particles flying through your case, potentially shorting things out. Are you gonna give it somekind of protective varnish layer to prevent any flaking and also preventing getting your clothe's dirty when transporting the case?
    Garbach
  8. piloux
    piloux What's a Dremel?
    12 Nov 2003
    Thank you :)
    I have primed the case and the plastic parts, not the aluminium panels on the front and the logo ... yes the primer is the red/brown paint , it is metal primer color and there is no influence about the final effect; about the timing I paint with the oxidant when the iron coat is dry, it take about 1/4 hours...and I apply it with paintbrush,You have to put a thick coat to get the best effect
    UPDATE :
    I made another crowbar to place into the case, it isnt paint but it will ...
    Ihave worked on the psu too , this is a 300w psu I bought because it is smaller than other ones ... the case is not too big more over the radiator is just in front of the psu ...
    here the sleeving of wires with yellow thermoshaft, I gave to it an industrial look with the black stripes :D
    I still have give an old dirty look to the sleeving...
  9. piloux
    12 Nov 2003
    well, I must say that I haven't thought about this... :duh: this may be a problem .... I have rather to spray varnish on it, thank you to make me thinking about :thumb:
  10. KONIJN
    KONIJN What's a Dremel?
    30 Nov 2003
    that psu is sweeeeeeeeeeeeeeeeeeeeet
    oh and you should make the crowbars look like they have been used in half life 1
    make them used and don't the new red color
  11. SugarBear
    SugarBear What's a Dremel?
    20 May 2003
    once you paint that crowbar red, do the entire world a favor and take it outside and bang the rounded part on the ground, preferably cement, to give it that used look, just enough to peel a little of the paint off, then get a little black, and drybrush it on around the handle where you would hold it, it will make it appear more worn in, you could actually dry brush some black and brown and green across the whole thing so it doesn't look all shiny and new
  12. instant rice
    instant rice What's a Dremel?
    20 Jan 2004
    This is definitely showing some progress. I especially like the design of the piece around the optical drives. Also, have you thought about taking the cover off that meter and doing some very minor rusting to the white backplate? Maybe in a drip pattern it would look like there was a leak at the top of the meter.
  13. piloux
    12 Nov 2003
    Yes I will change the white font by another one, but first I have to make it working... I ll go to my fathers workshop to get a lamp to test it
  14. piloux
    12 Nov 2003
    ok thanks, i LL try to do something like that :)
  15. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    This is already a great looking project.
    The PSU looks great, but I would get rid of the blue sticker on the fan.
    (Or you may have plans to change the fan anyways)
  16. piloux
    12 Nov 2003
    thank you , I must say that in the hurry up to see how the psu looks like , I forgot to take off the stiker but it will be done :)
  17. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    wow. mod god lol. i love it piloux :jawdrop:
  18. fillip
    fillip What's a Dremel?
    9 May 2002
    Piloux, in that piece of tubing at the top of the case (coming from the water cooling radiator presumably) it appears to be filled with a white liquid. Is this indeed the case, have you found some kind of coolant/water dye that is white to use in your water or is it just the colour of the tube?
    I'm really intrigued because i want a white water effect for my rig i'm building in the summer but havent found anything i could use to make the water white and cloudy.
    Case looks awesome - but you already knew that!! :rock:
  19. th3madc0w
    th3madc0w What's a Dremel?
    7 Oct 2003
    1 tablespoon of condensed milk!!! :D
  20. fillip
    9 May 2002
    really?? i'd be slightly concerned about the effect that would have on the system. does it have any ill effects that you know of? if not, i may well use it.
    Oh yeah, does it settle in the tubes and stain them?
