project : Blackmesa HL²
Discussion in 'Project Logs' started by piloux, 24 Feb 2004.
  1. Incorpirate
    Incorpirate What's a Dremel?
    2 Jan 2004
    been busy with school atm but this mod has kept me checking back to BT as offen as i can
    its looking serperb pills... you have tallent.
  2. toand
    toand What's a Dremel?
    17 Feb 2004
    So sweet man.. :brrr:
  3. Abom
    Abom What's a Dremel?
    15 Jan 2004
    I know your in a different country, but in america for paint there is a "Flat Clearcoat" basicly its a spray paint that you could cover all your rust parts in that would not be glossy.... might be an idea so you dont get that stuff all over your house and inside your comp :)
    Love that Case BTW, cant wait to see HL2 playing on it :)
  4. irsekz
    irsekz What's a Dremel?
    23 Feb 2004
    you should put like more of that shatered orange plexi around the buttons to make it look like an emergency happened or something
  5. th3madc0w
    th3madc0w What's a Dremel?
    7 Oct 2003
    it would only ever settle out if ur pump was off for several days, and being white, i don't see it staining anything
  6. fillip
    fillip What's a Dremel?
    9 May 2002
    ok cheers, when i said staining i meant more leaving a nasty white residue all over the inside of the tube, i didnt make it very clear in last post.
    Guess all i can do is give it a try and see hwat i get.
  7. piloux
    piloux What's a Dremel?
    12 Nov 2003
    in fact this is just a clear tube , it is just the water inside which makes condensation and thats why it appear "white"
  8. piloux
    12 Nov 2003
    I m still thinking about the right way to mod the tubes :)
  9. fillip
    9 May 2002
    awwww... i', slightly disappointed now :sigh: i thought piloux the supper modder had found some ingenious way of making the water milky.
    still, may try condensed milk powder or sumthing and see what i get.
  10. piloux
    12 Nov 2003
    Well, so sorry :D but you can test water with white watercolor , I don't think this will be bad for the blocks and rad...
  11. jonesie
    jonesie What's a Dremel?
    24 Nov 2003
    and won't stink quite so much when you come to service the watercooling :)
  12. fillip
    9 May 2002
    I wouldnt have thought condensed milk wouldve been as bad as real thing, but then i dont know for sure.
    I presume you were talking about water colour paints?... hmmm...
    I would try white food colouring but i'm not sure that it's even made?!?!
    will look in tesco's nxt time i'm there :D
  13. Hokuem
    Hokuem Guest
    water
    Yeah, and the vernish you will apply could maybe create the "watter effect" you had on your wallpaper on the beginning! ;)
  14. piloux
    12 Nov 2003
    hi , little news : I have tested the ampermeter and this is not an ac / dc one , it is for continous current :(
    I think I ll try to get another one...
  15. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Contiunous current and Direct current are the same thing, lol! :hehe:
    i think you are just mistaken. After all, Direct current means continuous same voltage flow. That meter must be really old for it to say that :eyebrow: But, yeah, they are the same thing, so no worries :)
  16. Cereal
    Cereal What's a Dremel?
    28 Feb 2004
    That Drive just blows my mind, it looks liek one of the props you see on the SiFi shows...Half Life 2 will be awsome, but how will this be a Lan PC? its looking to be pretty heavy.... well anyway, the paint job caught me right away...i love it, and will be following...
  17. Garbach
    Garbach What's a Dremel?
    22 May 2003
    And if you can't get it to work properly, maybe you can change the mechanism with a new one. So put in a new meter, but keep the old housing and dial plate. You could then also buy one in miliamps so that your needle wil actualy move without having to shot cirquit something.
    Garbach
  18. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    piloux Simply put it Fantasitc. I wanted to register for the chance to say how impressed Im with ur work...
    Myselfe I love the felling with Half Life so the thought of having a PC remindig of the game is glorius.
    :thumb: and :jawdrop:
    Keep the pictures glide in. :D
    And I wish I lived near u so I could dropp in and look at the becoming masterpiece.
    /Dave
  19. piloux
    12 Nov 2003
    ok sorry if I made mistake by express myself :duh: this meter use continous current and the one use by psu is alterbnative current ( tell me if I m wrong) ... I will try a diode with it to make it work...
    I had not enough time to make lot of work this week , but I started building the fanbus , here are some pics of it :baby:
    this is not finished yet .... I still have to find switches and to paint it...
  20. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    That looks awsome... now for some aging...
