project : Blackmesa HL²
Discussion in 'Project Logs' started by piloux, 24 Feb 2004.
  1. Immy
    Immy What's a Dremel?
    13 Nov 2003
    Looks really nice mate, up to par with gnomes work in my books keep it up :dremel:
  2. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    Wonderful work, piloux...
    I really admire your attention for details and your skills in painting.
    Only one thing: I think you could improove the fanbus look by increasing the gap between the bezel and the orange plexy or, better, by adding another plexy sheet between the bezel and the original plexy, so the pots are screwed to the hidden one and you reduce the amount of "shiny" metal...
    But that's just my opinion.....
  3. Lord Kordir
    Lord Kordir What's a Dremel?
    5 Nov 2003
    Got me subscribed to another thread pilloux. You have some real skills man! :)
  4. Jewno
    Jewno industrial designer
    4 Feb 2004
    Sweet Lord! Your project is going to be the best mod of the century!
    Huge props for you! :clap: :clap: :clap:
  5. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Dude, you rock!! :D Another awesome mod, can't wait to see the final product. IMHO - YOU > ZapWizard :worried:
  6. RefleCsM7
    RefleCsM7 What's a Dremel?
    17 Mar 2004
    Way to c :brrr: :brrr: :brrr: :brrr: l!!!!!!
    :rock: :jawdrop: :jawdrop: :jawdrop: :rock:
  7. Spook
    Spook What's a Dremel?
    17 Mar 2004
    Love ur work, m8! /me subscribes!
    MOD ON!
  8. Mr Joshua
    Mr Joshua What's a Dremel?
    6 Mar 2004
    If you have access to a mill you could try to change the knobs on the baybus to look like valves (maybe like the one on the cover of the HL box).
    If not I'm sure you could buy something like it from a model shop (boats) or if you have a load of time you could file it!
  9. piloux
    piloux What's a Dremel?
    12 Nov 2003
    Hi guys here is the next update :D
    I have found what I m going to use for the tank reservoir :thumb:
    here it is
    this thing get the industrial look I was searching for :rock:
    this is used in compressed air applications... then it needs some transformations to received liquid...
    I also found plugs for the tubes ...
    and I put silicon into the passages I will not use
    here is a test to see the outflow, I had to drill bigger hole to get this flow
    It seems to be good, but there is some water passing there
    Ill put silicon to end with it
    :dremel:
  10. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    Nice! I suggest you dont keep those blue if possible.
    Or if you are keeping them blue, how are you making them fit in with the rest of case.
    Other than that, Well done!
  11. piloux
    12 Nov 2003
    these buttons will be paint too ;)
    it seems to be good , no problem by touching it
    I don't use the window but the white panel of the gauge, just with the oxidant paint ;)
  12. piloux
    12 Nov 2003
    a window of course :D
  13. H4wk1e
    H4wk1e Minimodder
    7 Jan 2004
    Nice mod, like the idea with the tank reservoirs, :thumb:
  14. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
    Are you going to paint up the bottles like the other guy that posted his project in this thread did? Not to the extent, but it would rock :rock:
    Very nice project, I'm looking forward to seeing it completed :clap:
  15. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    i would paint the bottles red, to make them look like a fire extingusher (spelling?), then paint the holders/bottoms with the oxidant. It would make it feel more HL
  16. instant rice
    instant rice What's a Dremel?
    20 Jan 2004
    As far as bullet holes go, why not see what it looks like when you fire a round through plexi? If you got a good bullet-hole-through-glass effect (with spiderwebbing around it, not just a clean hole) you could back it with another sheet to keep it stable. That would suit the look pretty well, as well as plexi with wire mesh inside/behind it.
  17. 1st time modder
    21 Dec 2003
    i dont like the whole idea of shooting a gun at a piece of plexiglass, for a computer modification. Come on, you can't just do it in your backyard, obviously someone will call the police
  18. Abom
    Abom What's a Dremel?
    15 Jan 2004
    LOL the explination would be the coolest.... "Well see officer Im modifying my computer and needed to shoot a gun at it for airflow.... uhh...."
  19. instant rice
    20 Jan 2004
    Have NONE of you goons heard of a silencer? :rolleyes:
  20. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    silencer = illegal...
