My apologies...looks like a firewall configuration issue. I'm not allowed to access the site that's hosting your pics. Will have to wait until I get home, I guess... SharkBait
Great work. The rusty case is a tough thing to pull off well. Looks like you are on your way. Good luck.
update the painting job is on good way, here is the case and one of my enermax 80 mm with the 3 1/2 disk drive bezel the valve which will go on the wc tank I wanted to create a HL² logo to fix on the side panel behind the motherboard, this logo will look like in the same spirit that the wallpaper I show you at the beginning of thread, here it is : here it is after the paint job and with an orange uv react acrilic logo without flash with flash I m sorry but for now I can't show you the uv effect because I had to buy new ccfl psu... see you soon for the continuation
OMG thats pr0. I have a black mesa themed PC to, it's got the BMRF logo on it, and all thats stuff, will dig out my digi cam and take some pics, but that rust effect is the most realisitc paint i have ever seen, its like you left it in water for years...
OMG AMAZING!!!!!! That is some amazing paint effects you get their and that fan looks real cool aswell. Cant wait to see the thing finished.
supreme mate supreme looks better with teh flahs off (natural light) cant wait to see your finsihed project
thank you guys! yes this paint is really cool , I m really happy how it turn out , especially over the plastic pieces like the fan and dvd drive because it is indicate that it is only wood or steel paint but not for plastic stuffs...I try it and I got it
what an amazing artwork on the hl2 logo... how`d you go about making it - dremel + needle files? `cause if you did then this is some AMAZING handy work! like i said before - this is one mos to watch out for!
Wow!!! I am so happy you are doing another project. Your last case was wonderful but this... absolutely amazing!! Keep up the good work I can't wait to see what is next!
Now that I can see the pics, all I can say is wow! Great job! Looking forward to seeing more! SharkBait
I cut the logo with hacksaw and drill some holes to fit rivet/metal bolt, for the cut out of the "2" I drilled holes all along the 2 and finished it with limes
Wow, thats pretty kewl, i like the orangey mobo tray and the HL logo looks spot on, it must have took you a while doing that paint job
