Hi guys,I m happy to see greats comments one more time well the gauge is raelly dead , I broke a little piece which that I can not repair or replace... may be if I see another to the right size I ll change it no, I paint it first with the brown paint (tamiya paint for models) and then the rust paint and yellow bands , 2 clear coats more and once dry , the paint is really strong
He Piloux, if you want to replage the gauge I'd suggest going to a local antiques shop. I found 4 old gauges (round ones, but they also have square ones) and 3 of them still worked! Also those were miliamps so that would make it easier to hook them up. I also understood that most of these guages are single current (as in opposed to alternating current) but that that is also the kind of current your PSU produces, so hooking them up should not be a problem. If you're realy interested and give me some dimensions I could go look for a square one, cause the shop I went too in the Netherlands had a ****load of old guages lying around!! Happy moddin!! Garbach
ok thank you , if I ll not find it around here I ll tell you here are three more pics with the side panel ( I re-paint it to give it a better look ) the pics are 1024x768 so if it is too big tell me... I ll change it for links
[off topic]could you post a link to the full sized verion of that desktop wallpaper posted on the fist page?[/off topic]
Cant say anything more than what has been said, didnt think you would top your last project.... man was I wrong!! In the last picture, there is a gap between the fan controller and the case, light is coming through it, duno if its ment to be there or what. And what goes in the last drive bay?? Great work... as always, you, amoungnst others, have really pushed the level of modding to a whole new realm! -cLoWn
mmmmmm it hard to judge this pc by looks ............ i will wave to give it a OMFG vote .... i wached your first pc and have been away for some time very glad i poped in to se it done . you have (and i really mean this m8) done your self proud with this one , valve you really want to pay this man for his efforts on promoting your game (and the forth comeing one ) infact i am going to tell valve about this stunning bit of work .... scott
absolutely incredible. i love how it the water glows so well. so many little details make it one stunning piece of art.
Well, all i can say is that your computer is a runaway hit Piloux Hey G-Gnome, you better get up off your arse and finish the Orac 3; I think your case has met its match in sheer spectacular style
Thank you very much ! here is it http://www.hlgaming.com/image.x?img=/images/potd/200308/13.jpg this is because I have cut the original front bezel ... in the last drive bay will come the dvd drive when I get it and paint it.
