Project Bling
Discussion in 'Project Logs' started by Quinten, 3 May 2005.
  1. Quinten
    Quinten What's a Dremel?
    20 Jul 2001
    Always wanted to have a digital picture frame, but unable to fork out £££ for one? Here's my feeble attempt at saving a few bob ;)
    Remove all unneccesary bits
    Put it into a frame of your choice
    Add the keyboard as well (it wouldnt boot without it)
    It works!
    More pictures here.
    Still got some stuff to do like inventing a on/off switch, reducing hdd noise (either a CF or solid state disk most likely) and find a way of controlling it with a IR remote, but that's just minor details ;)
    Q.
  2. advance
    advance What's a Dremel?
    18 Apr 2005
    Pretty interesting, where will you put it?
  3. Quinten
    20 Jul 2001
    Due to its size probably hanging on a wall. For now it just stands on a drawer.
  4. jezmck
    jezmck Minimodder
    25 Sep 2003
    like it!
    I reckon it must be possible to convince it that the KB still attached...
  5. Quinten
    20 Jul 2001
    Maybe if you know electronics, you may be able to, but as I don't... Fortunately with the keys removed it isn't that much thicker.
  6. BrokeEnthusiast
    BrokeEnthusiast What's a Dremel?
    28 Mar 2005
    did you have to buy an extension cable for the LCD to reach the computer? The one on my laptop is really small
  7. SJH
    SJH Minimodder
    24 Dec 2003
    Have you tried looking in the BIOS settings for an option to boot without the keyboard present? It could be that such an option exists (it did for me when I was setting up my server).
  8. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    its a laptop so its not that feature on a laptop
  9. Quinten
    20 Jul 2001
    No extension cables needed. As you can see from the pictures on my site it was just long enough for the motherboard to be flipped behind the screen. These flat cables are a bugger to get hold off, and I'm not even sure if they have some sort of standard between them.
  10. Quinten
    20 Jul 2001
    As TTmodder rightly says, it is a laptop, it normally doesn't come without keyboard ;).
    But even if it did, the BIOS on these Thinkpads is very basic; just boot order and perform internal tests are possible.
  11. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    you could always dismember an old keyboard, and get the controller from it and just plug in the control, thus fooling the comp into thinking it has a keyboard pluged in.
    nice idea for the picture by the way :)
  12. Quinten
    20 Jul 2001
    Tried that, but it wasn't having any off it.
  13. GuardianStorm
    26 Apr 2005
    damm intelligent computers :\
    unless the controller, needs to have some of its pins wired together/to ground/to power
