Case Mod - In Progress Project Blue by rrmitko
Discussion in 'Project Logs' started by rrmitko, 7 May 2015.
  1. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Hi Bit-Tech comunity!
    My name is Dimitar. I'm almost new in modding ( last project was years ago).
    Hardware involved:
    - Phanteks Enthoo Primo
    - Corsair HX 750W
    - i7 4790k
    - ASUS Z97 PRO-WIFI AC
    - EVGA GTX970FTW ACX2.0
    - Corsair Vengeance LP 8gb DDR3 1600 2x4gb
    - Corsair force gt 60gb
    Water Cooling Parts:
    - EK-SUPREMACY EVO Blue Edition
    - XSPC RX360 V3
    - Alphacool Monsta240
    - E22 tubing
    - EK-FC970 GTX ACX-Acetal+Nickel
    - EK-D5 X-RES TOP140 CSQ-Acetal
    Sponsored by
    I hope you will like the project and the work I'm doing! Ok,lets start modding:dremel:
  2. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    First the tools. Variety of hand and power tools
    The phanteks case which I purchased few months ago.
    Totally stripped
  3. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    I decide to replace most of the rivets with m4 screws
    And the drive bay cage
    That is all for now:dremel: Stay tuned for more:thumb:
  4. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Here we go,some more photos of my project.This time I'm dealing with perspex acrylic.
    This button head screws are just temporary,before I tap the holes for countersink screws.
    Here is the reservoir bracket almost done.I have something in mind to cut in the acrylic :D I'm not planing any laser cutting, everything will be done by hand :dremel:
    So far so good:thumb:Stay tuned for more:dremel:
  5. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Ok,just a teasing photo of what is coming next to be done :cooldude:
  6. SiberianGhost
    SiberianGhost What's a Dremel?
    1 Mar 2015
    Nice job with the modding!
    Subbed
  7. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Thanks!
  8. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Hey lads,another update from project blue. As I promise there will be cutting,not metal but acrylic.Which is more hard to cut,mine opinion. Ok, enough of talking lets do some work :dremel:
    Usual tools
    And what I'm going to cut
    Yes EK logo :thumb:
    One peace down
    One blade also down :)
    Job done :thumb:
    But then,when I was filing and polishing disaster happened :wallbash:
    Back from point A
    This time I was more careful
    This attempt was more successful :)
    Still need to tap the holes for the screws :thumb:
    Ok that is all for now. Stay tuned for more updates :thumb:
  9. Icelander
    Icelander Minimodder
    3 Mar 2015
    nice job
  10. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Tnx :)
  11. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Another update with photos. This time I'm cutting aluminium. I will replace the phanteks plate with my own.Here we go :)
    Some filing
    Final cuts
    And on the case. Still need to be painted but painting will come later :)
    Hope you guys like the project so far :thumb: Soon will be more :dremel:
  12. Freebee
    Freebee What's a Dremel?
    6 Nov 2014
    if your calling yourself "the sailor man" what and where do you sail?
  13. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    I use to sail years ago on the cruise ships :)
  14. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Hey guys, another update from Project Blue :) It is time for painting :thumb:
    Firs task is to clean the rads
    Spray paint and primers
    Main colour, of-course Blue :rock:
    But fluorescent blue.Glows really nice under UV light.
    Few coats of white primer
    That is all for this update lads :) Stay tuned for more :thumb:
  15. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Wow, that's some really precise sawing and filing.
  16. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Thanks!
  17. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Hi lads,
    Another update with photos from my project :)
    Rads painted
    I have to say,that this blue colour is really nice :thumb: Still many parts need sanding and painting.Here is some progress on that direction :dremel:
  18. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Hi guys,
    Small update. Terrible weather today in London,raining all day:( I can't do any anything outside ......but I have something in mind ;)
    Any ideas what this can be :)
    And one more closer :)
  19. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Ok,what is this white peace of something.....no one? This is .999 pure silver :D And this will become silver kill coil :)
    Let's start
    Firs the tools,usual ones for my project
    The silver is very hard after the rolling mill,so need to become softer.For that reason one more tool is added
    Cutting
    Filing
    Even more filing
    Scraping
    One side ready,marking the other one
    Cutting
    More scrubbing
    Time for sanding.I will start with 600 up to 2500.Reason for that is,silver is very hard to polish.Especially the pure silver is almost mission impossible , always goes back to his original colour.
    Sanding with 2500 sandpaper by hand
    Polishing
    Success :rock:
    And the final product :thumb:
    That is all for today lads. Hope you like my new silver coil. Stay tuned for more :dremel:
  20. stealth80
    stealth80 Minimodder
    1 Feb 2015
    looking good, keep up the work
